gs500e keeps cutting out!!
veze
PostPosted: 20:57 - 21 Jan 2009    Post subject: gs500e keeps cutting out!! Reply with quote
hi guys, my 91 gs500e keeps cutting out.
the bike runs fine, the carbs are clean, air filter is good and so on.
if im riding, every so often the bog will bog down and cut out.
ive got an in line filter on so i can see if there is any fuels coming through. but when it cuts out there is none.
i switch it to prime, and still no fuel coming through.
but ive found if i suck on the vent hose coming out of the top of the carbs, the feul starts coming through, then i can switch it off prime and back onto main and it will run fine.
then after a while it will ahppen again, what could be the problem? cheers,
josh.
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
metal ken
PostPosted: 22:32 - 21 Jan 2009    Post subject: Reply with quote
Try cleaning out the feul tap and the gauze feed inside the tank, also check the tank breather,
Ken Thumbs Up
My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400
lonner
PostPosted: 22:51 - 21 Jan 2009    Post subject: Reply with quote
does it work with the filler cap open?
if that works its just the breather Thumbs Up
failing that its clean the fuel tap and tank out Thumbs Up
veze
PostPosted: 20:09 - 22 Jan 2009    Post subject: Reply with quote
oh so simple, i was woried it mite be one of the feul daphrams or somthing.
whats the best way to clean the gause? with an air line? they look a bit fragile, would that damage it?
lonner
PostPosted: 08:22 - 23 Jan 2009    Post subject: Reply with quote
if poss just clean it with a bit of petrol as its only there to stop debris getting into the carbs.
not had to clean one for over 20yrs so cant remember Confused hth
veze
PostPosted: 20:57 - 26 Jan 2009    Post subject: Reply with quote
ive just had the tank off and everything, but the gauze was clean but i gave it a blow out anyway, and the breather pipe isnt blocked because i blew through it and even looked right down through the pipe out the bottom of the tank, no blockage. ahhrgg im so confused! i think the only thing left is the scrap heap.!
i was wondering what the best way to free up a seized bolt it, because i cant undo the bolts to my headers, because there all corroded any seized and need to get them out because my zorst is shafted harcore, its blowing out of where the heders come out the engine, and the weld has cracked whe the pipe meets the silencer, and know my bike just pops, coffs, makes a rite old racket and runs as rough as bagers!
cheers
josh
veze
PostPosted: 20:42 - 27 Jan 2009    Post subject: Reply with quote
ive just swilled my tank out and checked the breather and there all good so i thought the inline filter mite be block so ive took it out for now till i get another one, im gunna see if it has cured it in the morning.
The last post was made 17 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 52.31 Kb
