| veze |
 veze Trackday Trickster
 Posted: 20:57 - 21 Jan 2009 Post subject: gs500e keeps cutting out!! |
hi guys, my 91 gs500e keeps cutting out.
the bike runs fine, the carbs are clean, air filter is good and so on.
if im riding, every so often the bog will bog down and cut out.
ive got an in line filter on so i can see if there is any fuels coming through. but when it cuts out there is none.
i switch it to prime, and still no fuel coming through.
but ive found if i suck on the vent hose coming out of the top of the carbs, the feul starts coming through, then i can switch it off prime and back onto main and it will run fine.
then after a while it will ahppen again, what could be the problem? cheers,
josh. ____________________ tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300 |
| metal ken |
 metal ken Spanner Monkey
 Posted: 22:32 - 21 Jan 2009 Post subject: |
Try cleaning out the feul tap and the gauze feed inside the tank, also check the tank breather,
Ken  ____________________ My motorbike breakers metalken.co.uk
Current bikes, GSXR750 Fighter, GSXR7/12, RD350 race rep, KH400 |
| lonner |
 lonner Spanner Monkey
 Posted: 22:51 - 21 Jan 2009 Post subject: |
does it work with the filler cap open?
if that works its just the breather
failing that its clean the fuel tap and tank out  |
| veze |
| lonner |
 Posted: 08:22 - 23 Jan 2009 Post subject: |
if poss just clean it with a bit of petrol as its only there to stop debris getting into the carbs.
not had to clean one for over 20yrs so cant remember hth |
| veze |
 Posted: 20:57 - 26 Jan 2009 Post subject: |
ive just had the tank off and everything, but the gauze was clean but i gave it a blow out anyway, and the breather pipe isnt blocked because i blew through it and even looked right down through the pipe out the bottom of the tank, no blockage. ahhrgg im so confused! i think the only thing left is the scrap heap.!
i was wondering what the best way to free up a seized bolt it, because i cant undo the bolts to my headers, because there all corroded any seized and need to get them out because my zorst is shafted harcore, its blowing out of where the heders come out the engine, and the weld has cracked whe the pipe meets the silencer, and know my bike just pops, coffs, makes a rite old racket and runs as rough as bagers!
cheers
josh ____________________ tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300 |
| veze |
The last post was made 17 years, 26 days ago. Instead of replying here, would creating a new thread be more useful? |
