Water in my headlight...
Groove
PostPosted: 15:05 - 22 Jan 2009    Post subject: Water in my headlight... Reply with quote
For a week or two now my headlight has been misting up. Makes the bike look dirty even when its clean Confused
https://i256.photobucket.com/albums/hh163/adam673673/DSC00714.jpg
So, i took the fairing off:
https://i256.photobucket.com/albums/hh163/adam673673/DSC00725.jpg
And was suprised that with the amount of water in there i could of had a healthy gold fish in there...
https://i256.photobucket.com/albums/hh163/adam673673/DSC00718.jpg
This will be why then! I knew the headlight had been repaired. Obviously the person who repaired it wasnt any good! Any quick bodge ideas for sealing this?
https://i256.photobucket.com/albums/hh163/adam673673/DSC00724.jpg
So out comes the water:
https://i256.photobucket.com/albums/hh163/adam673673/DSC00720.jpg
My other question is, is the front clear plastic on the headlight designed to be easily removed as i think i will need to clean the inside of the lense so i do not get water marks there. I had a quick go but was getting nowhere and the water was making me wet Neutral
PostPosted: 15:12 - 22 Jan 2009    Post subject: Re: Water in my headlight... Reply with quote
No shit. Laughing
Use bathroom sealant/ or caulk or something to seal it. Thumbs Up
Groove
PostPosted: 16:27 - 22 Jan 2009    Post subject: Reply with quote
Ive got some silicone stuff so will use that for a tempory fix.
Upon closer inspection of the clear lense i found out that some of the fixings have also been repaired so even if it could come off, it wont now!
So looks like im stuck with water marks on the inside unless anyones got a bright idea?
binge
Emo Kiddy
PostPosted: 19:27 - 22 Jan 2009    Post subject: Reply with quote
Get a hair drier in the hole to dry it out fully.
Will still leave slight watermarks. But wont be as bad as if you let it dry naturally.
My mate Keith stunts a 636, His headlights are REALLY full with water. We were actually considering putting a Goldfish in there for comedy value. Laughing
Ben
Gazdaman
I did a trackday!!!
PostPosted: 21:31 - 22 Jan 2009    Post subject: Reply with quote
It's a real mission getting headlight lenses off. We did it to Podd's R6 once. Because he had 2 cracked sets of headlights, but between them had 2 good lenses. So we made up one good set of headlights from the two dead ones.
You have to heat it up for ages, and use some brute force too.
Gaz
Groove
PostPosted: 08:35 - 23 Jan 2009    Post subject: Reply with quote
I gave up on the idea of taking the lense off as soon as i noticed that some of the clips holding it on had been "repaired" also.
Seemed a bit dodgy to take off so ive just done a tempory fix till i find another headlight cheapish.
https://i256.photobucket.com/albums/hh163/adam673673/DSC00727.jpg
Better than it was! Thumbs Up
Gazdaman
I did a trackday!!!
PostPosted: 10:12 - 23 Jan 2009    Post subject: Reply with quote
Must get myself a b1h one day. They're definitely the sexiest of the 6rs.
In green too.
Gaz
MarkJ
PostPosted: 17:38 - 30 Jan 2009    Post subject: Reply with quote
When the insides of my lenses get dirty, I spray some windowlene in there and stick some paper towel on my finger and clean the insides that way. You could also use a pencil for the parts your finger can't reach (Shocked)
Ichy
PostPosted: 23:43 - 30 Jan 2009    Post subject: Reply with quote
Drill a hole in hte bottom of the headlight to drain the water out.
alun111
PostPosted: 01:07 - 31 Jan 2009    Post subject: Reply with quote
That's exactly what I was going to say... you beat me to it.
yankeedoodle
PostPosted: 23:50 - 31 Jan 2009    Post subject: Reply with quote
+1
thats what I was going to suggest.
just make a really small hole right at the bottom where it wont be noticed
Bandit 600
hmmmnz
PostPosted: 09:50 - 01 Feb 2009    Post subject: Reply with quote
or just fix the bloody leak!!!
fibreglass it, it'll be done in 10mins and you shouldnt have to worry about it again
the humans are dead
I kick arse for the lord
Rowey
PostPosted: 13:18 - 01 Feb 2009    Post subject: Reply with quote
What about one of those silicone packs you get in packaging? They're designed to absorb moisture. Chuck some of them in, leave um for a day or so, then tip them out and seal it?
ZX6R C6F.
NiteMare
PostPosted: 18:33 - 02 Feb 2009    Post subject: Reply with quote
you mean silica gel packs ...
don't bother ...
as said before a hair dryer works just fine
it ain't broke...
i ain't fixed it enough
The last post was made 17 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 86.16 Kb
