| funmonkee |
 funmonkee Super Spammer
 Posted: 00:40 - 25 Jan 2009 Post subject: Big Thumper problem |
I have an MZ Baghira. It's been off the road for a month or two. It starts up fine on or off the choke. Will idle without problem, but if I rev the engine a little it cuts out
I would guess the bike will trundle about 20-30mph, but other that I think it'll cut out
Any advice on what I can check  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b] |
| Jamie S |
 Jamie S World Chat Champion
| Slinn84 |
 Slinn84 Scooby Slapper
| funmonkee |
 Posted: 01:29 - 25 Jan 2009 Post subject: |
Thanks dudes
I put a new air filter on and that didn't help.
I changed the plug
Has plenty fuel
Fuel tap is ON (in case anyone asks)
Sprayed some carb cleaner..near the carbs...but I don't know enough to know what needs cleaned
How would the ignition timing problem happen? What would cause that The bike suffered a bit of an accident before it went off the road. basically I had the bike a week and a half and didn't check the rear disc bolts... they must have been finger tight as two worked lose and embedded themself in the swingarm Swing-arm now fixed, new rear carrier now on the bike, just waiting /hunting for a replacement disc bolt as I had to cut one free
^^ would this cause engine damage  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
| Slinn84 |
| Gawain |
 Gawain Nitrous Nuisance
| lonner |
 lonner Spanner Monkey
 Posted: 08:51 - 25 Jan 2009 Post subject: |
hi m8 it sounds like carb to me
if you loosen the small drain screw at the base of the carb and let the fuel run for a minute it may solve your problem as it may be water and gunge in the float bowl try this first.
although you may need a full strip and clean of the carb hth  |
| tafflade |
 tafflade Nitrous Nuisance
| funmonkee |
| Lone-Wolf |
 Lone-Wolf World Chat Champion
 Posted: 11:10 - 25 Jan 2009 Post subject: |
Wotcha.
Sounds like a blocked jet.
I had one block up yesterday - bike would run fine, but as soon as it came off the pilot jet it would cut out. Took the carb off, stripped it down and boiled it in detergent. Seems fine now. ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
| Ariel Badger |
 Ariel Badger Super Spammer
| smegballs |
 smegballs World Chat Champion
| virus |
 virus World Chat Champion
 Posted: 20:19 - 25 Jan 2009 Post subject: |
| Bittern wrote: | I know that everyone says, NEVER stick any wire up a jet to clear it out as it will enlarge it.
However would a nylon strand, say from a toothbrush, or indeed and stiff hair, do any damage to the fine brass hole?
Rich |
One strand of copper wire, from internal house cabling for example, will do precisely bugger all to the jet,apart from get the crap out that carb cleaner wouldn't touch.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| funmonkee |
 Posted: 20:09 - 26 Jan 2009 Post subject: |
I was going to take the advice above, and strip the carbs and clean out the float bowl and jet... but instead I dropped a good load of redex in the fuel and sprayed the carb with carb cleaner I got from halfords... few minutes later it's revvin all the weay without stalling
BRILLIANT  ____________________ **** Don't ride faster than your angel can fly Get this Free Space
The last post was made 17 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
