Is this common gsxr600 problem?
Yarri
PostPosted: 17:53 - 25 Jan 2009    Post subject: Is this common gsxr600 problem? Reply with quote
Ok, i was really annoyed today but not sure if i should be or not.
Anyway, back 3 days ago on my way home from my mum bike suddently became quite jerky for no reason on slow speeds, below 30. This was durring my fuel light coming on so i though that i am meters away from running out of petrol, even gsxr reserve tank is 40miles and i'we done not more then 5-6... Refueling didn't help to sort the problem. Next day i decided to go for a ride and i completely forgot that i had this problem, so as i went bike was jerky again so i took it to a garage. Mechanic had a quick ride on my bike and said its slow on the start and jerky, must be spark plugs so i ordered them and had them fitted next day (This was chief mechanic of the place so he should know this stuff). After new spark plugs fitted bike was just fine, so i been riding around on Saturday and parked up for a night, lazy me didn't bother putting cover on the bike and it was raining durring the night. So there we go again today i start the bike and revving it was clear that engine didn't rev properly and quite slowly like its was really cold but i start riding normally when temperature hits 50 and usually its fine but not this time. So i was riding around really pissed off with life for 20minutes with all this jerkiness and temperature was around 70-80. Then i decided to give it few high revs so i rev tits out of it and after i hit 40 all jerkiness is gone... And just as i sit in traffic bike temperature starts to increase to 90-100, bike becomes less jerky and by the time i get home temperature is around 105/110 and all jerkiness is pretty much gone...
What kind of problem is this?
Was mechanic just taking a piss and he knew about the problem but wanted some extra money?
My best guess is that rain have something to do with this but this didn't happen before even when it was raining... I am still not sure if problem is gone or not, i'll have to start the bike up tomorrow and see, and i did put cover over it for tonight.
Hope this make sense, advice needed
Theory Passed: 23/10/2008 Very Happy 49/74 Bike Test Passed: 05/01/2009 Very Happy 1 minor
Theory Car Passed: 22/07/2009 Very Happy 48/74 Car Test Passed: 22/10/2009 Very Happy 2 minor
Few minutes of life of the biker could be more interesting then the whole lifes of many people
Ichy
PostPosted: 18:17 - 25 Jan 2009    Post subject: Reply with quote
What advice do you want? Its a fueling/ignition problem that goes away when the bike is warm. You could try spraying the HT leads with WD40 or igniton sealer to see if it helps.
Is the bike FI or carb?
MaybeGuy
''chief mechanic'' means fuck all
mechanics are scum.
probably the ''chief of false diagnosis to get more money''
is the bike ok if just left to idle? what about riding along below 4000rpm?
if so, you've probably got a blockage somewhere in the fuel line, i had a simiar problem... turned out when i put my tank back on, i didnt attach the fuel line properly, meaning the stopcock didnt open, allowing full flow of fuel.
another thing... like i said before, but you disregarded in a ''knowitall fasion'', was that it could have a fucked fuel pump.
i know mine needs a new one, as when i get to reserve, my bike acts like this after a few miles, but then again, when i had the pump out, i did drop it Embarassed new one on its way though
so yeah...
good luck
Yarri
PostPosted: 18:30 - 25 Jan 2009    Post subject: Reply with quote
Gonna see what happens tommorow when i start the bike from cold... I really don't wanna go back to this garadge as those trips can be quite expensive with all the ripoffs which are going around there...
Yarri
PostPosted: 18:31 - 25 Jan 2009    Post subject: Reply with quote
Bike is carb as its a srad
Phoenix
Twisted Firestarter
PostPosted: 00:03 - 26 Jan 2009    Post subject: Reply with quote
Sounds like you haven't given it long enough to work out if it's rain causing the problems or not. Originally it sounds like it was your sparkplugs, the mechanic swapped them and it ran fine afterwards. Now it's rained it's jerky again, until it got hot then it ran fine, that might indicate there's water gathering in the plugholes and shorting the HT leads occasionally causing a misfire, when it got hot the water evaporated so problem went. If that is the problem then if you keep it dry it shouldn't reappear which means get new plugcaps or seal them.
My 750 SRAD always ran a bit groggy in heavy rain so I don't think the plugcaps fit that well anyway.
Yarri
PostPosted: 00:35 - 26 Jan 2009    Post subject: Reply with quote
I'll be happy if that's the case, at least now i will stop being lazy fuck and use bike cover more often... But i have a worry that one of the cylinders might be failing, just a theory but i will update on this soon.
NiteMare
PostPosted: 02:34 - 26 Jan 2009    Post subject: Reply with quote
i'm not sure but i think you'll find that the holes the plugs drop into will have drain holes at the bottom to allow water to run out ...
on my old oil cooled gsx engine these got blocked up with crap stopping the water from draining, easy enough to sort ...
that doesn't mean the the HT isn't tracking down the leads/plug caps or over the coil bodies, electricity always takes the path of least resistance
it ain't broke...
i ain't fixed it enough
Davie_G71
PostPosted: 09:37 - 26 Jan 2009    Post subject: Reply with quote
1. It's normal, mine does it as well. Although mine is worse as i have an aftermarket can, have you got an aftermarket can?
2. Your bike doesn't have a reserve tank, when it's out, it's out. Start looking for a petrol station the minute you see the light come on. The light will flash faster the lower the fuel gets.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
PostPosted: 10:30 - 26 Jan 2009    Post subject: Reply with quote
is this an injected or carbed gixxer?
{edit} oops its carbed... I'll go back to being quiet now Embarassed {edit}
Phoenix
Twisted Firestarter
PostPosted: 11:32 - 26 Jan 2009    Post subject: Reply with quote
Yeah only 750 SRAD got injectors towards the end, 600 only came with carbs until K1.
Don't recall there being any drain holes in my sparkplug holes but then the oil cooled GSXR engine is totally different to the water cooled version.
It does have a reserve it's just a warning light rather than a tap it's about 4litres I believe, I had nearly 60miles from it once after the light came on, once you hit 2 litres it will start to flash.
Another thing to bear in mind but it doesnt sound like your problem is carb icing, mine suffered very badly in cold weather (below about 4 or 5 degrees) and not always just on a long motorway run, it'd gurgle and splutter and once it finally cut out you could see the fuel lines covered in loads of furry ice.
Yarri
PostPosted: 16:16 - 26 Jan 2009    Post subject: Reply with quote
Ok, here is the update, just been for a ride:
Bike is fine now, very smooth, revs properly blablabla so i thought i'll make a trip to a garage and ask the guy why this happened. Chief Mechanic wasn't there but i told the story to a younger guy who was on shift when my bike got new spark plugs... He said that when they have been doing the spark plugs the caps looked corroded and that must be the problem... So i say ok, bike is fine for now and i'll try to keep it off the rain but if i want job done how much would this be, he said 45quid labour + caps which are more expensive then it sounds he said...
Sounds to me like they are creating work for themselves
How much would the spark plug caps cost for gsxr600 ?
MaybeGuy
PostPosted: 19:53 - 26 Jan 2009    Post subject: Reply with quote
just so you're sure...
fuel light comes on and flashes when you hit reserve... you have around 40 miles from this point.
around 20 miles later, the light stays on constantly, meaning you have about 20 more miles before you're going to stop.
if thats not roughly right then somethings up.
unfortunatly, SRADs have stick coils, not plug caps. they're expensive, and you need 4 of them.
however, the mechanic seems to be trying to charge you a full hours labour to fit them, when its half that to replace stick coils.
The Artist
PostPosted: 21:09 - 26 Jan 2009    Post subject: Reply with quote
you could do it yourself. As explained above, sounds like water gathering around the plugs.
Remove the stick coils and see if there is any obvious damage. If not, wrap the seal in PTFE tape ir similar and replace, should stop water getting down them.
The last post was made 17 years, 13 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 89.18 Kb
