| Askura |
 Askura Nova Slayer
 Posted: 23:35 - 25 Jan 2009 Post subject: Cagiva fix up project. Advice from those who know would rock |
Well, long story short, I got hit by a car. Now as some of you may know, it's not so long ago since I got wiped out by a bit of metal. Some may be discouraged by that and quit, but not me. I'm stupid.
I would love advice from where to go, and how to seek the best deals. You guys have always given me sound advice for the most part so I thought I'd ask again for your support/i.e. HALPS!.
The bike in question is a Cagiva 125 planet, 2001 model. It may not be much, but it means a lot to me as I've put a fair amount of effort into getting this bike if anyone remembers the many miles I put into fetching it. You may not think much of these bikes, but I love them. Or rather this one, I don't have the money to buy a new one outright, and would rather stick with this one.
So to continue my biking career I need to fix up my bike. Main points of interest of damage are the following:
- Left indicator will not work, front or rear. -What is the most likely cause, how should I fix it?
- Rear brake seizes up if I try to use it. -What is the most likely cause, how should I go about fixing it?
-Clutch lever, rear brake lever snapped. Where is the best place to buy from? Is £16 reasonable for p&p for said parts or should I look elsewhere?
-Exhaust is bent but intact. Should I just bend it back out and use it or replace?
-Headlight works, but highbeams don't. Is that just a replace a bulb job? or wiring etc?
-Engine sounds pretty rough. It doesn't sit idle very well and takes more revs to go from 0-15mph than usual.
-Speedometer isn't working. Where should the cable go
Some of this may be pretty basic to you, so don't just think I'm being bblatantlystupid for the sake of it or lazy. I genuinely don't have a clue how to go about most of the fixing, yet cannot really afford to prices of our local mechanics. I'm willing to what I can myself, but need some guidelines or advice or where I should start.
Thanks in advance for the time some of you may or may not put in.
Askura. ____________________ Honda CG 125 - Cagiva Raptor 125 - GS500 - Cagiva Raptor 650 - Honda Bros 400. |
| Itchy |
 Itchy Super Spammer
 Posted: 23:52 - 25 Jan 2009 Post subject: Re: Cagiva fix up project. Advice from those who know would |
| Askura wrote: | - Left indicator will not work, front or rear. -What is the most likely cause, how should I fix it? |
Look at the bulbs first did you go down on this side? , then wiring , then relay, if it still doesn't work BUILD your own circuit some wiring about £2 a soldering iron and a £3 car indicator relay can rebuild your entire indicator circuit which is pretty simple and you wire it directly to the battery , my NTV650 had this.
| Askura wrote: | - Rear brake seizes up if I try to use it. -What is the most likely cause, how should I go about fixing it? |
Could be :
Dirt in the seals = strip down job
Bent and warped pedal such that when you push down on it it gets stuck (happened on my NTV also)
| Askura wrote: | -Clutch lever, rear brake lever snapped. Where is the best place to buy from? Is £16 reasonable for p&p for said parts or should I look elsewhere? |
Anywhere really I pay £5 for levers but they are pattern ones that snap if you crash , rear not so sure wemoto probably.
| Askura wrote: | -Exhaust is bent but intact. Should I just bend it back out and use it or replace? |
If it works and doesn't blow and isn't touching anything ie the suspension compressed does not push the wheel or the swing arm into the zorst and the zorst is not touching any plastics leave it.
| Askura wrote: | -Headlight works, but highbeams don't. Is that just a replace a bulb job? or wiring etc? |
Bulb probably check the filmaments are intact first then trace it back through the wiring perhaps the switch.
| Askura wrote: | -Engine sounds pretty rough. It doesn't sit idle very well and takes more revs to go from 0-15mph than usual. |
dunno about this.
| Askura wrote: | -Speedometer isn't working. Where should the cable go |
on many but not all (my CBR has a cable to the gear box) , it is a cable that goes into the back of the clocks which leads to the hub of the front wheel. Your new fandangled super sports don't have this though. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Askura |
 Askura Nova Slayer
| nightshaddow |
 nightshaddow Nearly there...
 Posted: 00:37 - 26 Jan 2009 Post subject: |
ok as itchy said lol look at bulbs for your indicators or buy some new ones alround then wireing but it wont be relay as it runs on a one side if it comes to it though as the man says build it up yourself indicator wireing isnt hard
if i remember right the planet had disk brakes(i looked at one befor i bought my w8) likly hood is its seals or worst case the disc, if you can strip replace as nesesary,
clutch and brake leaver hien gerike is where i usualy use i get good quality though i have to order and wait
exhaust as ichy said if it aint broke dont fix it it may snap if you try bend it back if it is causing a problem replace(dont quote me but i hear the mito evo exhaust fits but check that out before you buy)
lights as itchy said
as for the rough engine check your carb air box and engine mainly clean carb clean out air filter box and check the filter itself (if need be get a garage to set up your carb
also maybe a service etc
and finaly the speedo, straight forward and simple on these, it goes straight from the frount wheel into the clock if i remember right they just scre straight into clock
hope you get sorted ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
| Askura |
 Askura Nova Slayer
| MarJay |
 MarJay But it's British!
| Askura |
 Askura Nova Slayer
| Gazdaman |
 Gazdaman I did a trackday!!!
| collywog19 |
 collywog19 Renault 5 Driver
 Posted: 19:29 - 26 Jan 2009 Post subject: |
It could be indi relay.
Postage is a bit high on the part mind.
Ive owned a planet, loved it. Got a mito now.
Good place for cagiva parts i found was
www.cagivaspares.co.uk
Hope this helps
Colin ____________________ 1996 Yamaha YZF750R, 1994 Yamaha YZF750R, 1989 Honda CBR400RR NC29, 1995 Kawasaki GPX 250R AND 1995 Cagiva Mito Evo SP! |
| Tricolor Fan |
 Tricolor Fan Trackday Trickster
 Posted: 21:39 - 26 Jan 2009 Post subject: Re: Cagiva fix up project. Advice from those who know would |
Check the bulbs, then check and clean the connections, then swap relay and finally trace wires.
The lever can catch on the exhaust mount if it's bent. As it's broken we'll skip that.
Strip, clean and rebuild. If you can't, don't bother paying someone to do it, just get another. You'll find a good one for less than the cost of an an hours labour.
A few quid for postage at most. Try Mito Mondo/MME for new and used parts or eBay for used items.
Bent how exactly? Are you sure it isn't a Mito Evo spanny, which is different to the one fitted to the Planet.
Check bulb, then check and clean connections, then strip and clean switchgear, then replace switchgear and finally trace wires.
Clean carb. Check that the jets are correct size. Check floats and needle position are correct. Adjust idle speed screw and air screw so it idles at 1800rpm (for winter). Check the air box tube and inlet manifold for cracks. Clean the air filter.
Are you used to strokers, power delivery is totally different to a 4T.
One end crews into the back of the speedo the other into the speedo drive mounted on the left hand side of the front wheel spindle. The speedo is reliable, but the cable and drives do break. ____________________ Give me ambiguity or give me something else.
| Tricolor Fan |
 Posted: 00:09 - 27 Jan 2009 Post subject: |
Fixed it for you! ____________________ Give me ambiguity or give me something else.
| Robby |
 Robby Dirty Old Man
| Tricolor Fan |
| Robby |
 Robby Dirty Old Man
| Askura |
 Askura Nova Slayer
 Posted: 03:12 - 28 Jan 2009 Post subject: |
Just a quick question, those places are good for parts, but do you know anywhere good for fairing/panels etc for the planet?
Thanks for the help altogether though, much more than I expected  ____________________ Honda CG 125 - Cagiva Raptor 125 - GS500 - Cagiva Raptor 650 - Honda Bros 400. |
| Askura |
 Askura Nova Slayer
| MarJay |
 Posted: 17:19 - 29 Jan 2009 Post subject: |
I know its working now and all, but you could always sell it to me for not a lot of money... I'll put a 350 powervalve engine in it!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Askura |
 Askura Nova Slayer
 Posted: 22:49 - 30 Jan 2009 Post subject: |
I'd love to but....then again I love the damn thing too much. I'll let you know when I've saved enough for that Triumph speed triple I've been keeping my eye on though  ____________________ Honda CG 125 - Cagiva Raptor 125 - GS500 - Cagiva Raptor 650 - Honda Bros 400. |
| Tricolor Fan |
 Posted: 20:15 - 31 Jan 2009 Post subject: |
Great!
Two things:
The spanny looks like the standard part with a different end can fitted.
You should get the belly pan that fits on to the spanny and hides it, it makes it look a lot nicer IMHO. ____________________ Give me ambiguity or give me something else. |
| GSF Jamie 600 |
 GSF Jamie 600 Scooby Slapper
| MarJay |
 Posted: 09:37 - 31 Mar 2009 Post subject: Re: Cagiva Planet for sale |
Very nice but its too much money. And I've never heard of Maserati Forks. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
The last post was made 17 years, 15 days ago. Instead of replying here, would creating a new thread be more useful? |
