cbr 125 enging scraping noise
dwellernet
PostPosted: 15:31 - 28 Jan 2009    Post subject: cbr 125 enging scraping noise Reply with quote
from the engine I have a scraping noise, like two metal plates together, this is only apparent in a low gear (1 to 2) while at medium revs. any ideas what this could be or how to remedy it. I have to confess it started after it was ridden with little oil after a forgot to do something day. Thanks
PostPosted: 18:20 - 28 Jan 2009    Post subject: Reply with quote
That sounds bad to me.
I assume you've filled the bike with the correct level and viscosity of oil?
dwellernet
PostPosted: 19:46 - 28 Jan 2009    Post subject: Reply with quote
yep, was giving it a service, put a load of the correct oil in and forgot about it (ie starting and re-topping etc), then used it. when I looked at the oil after there the dip stick was dry
tutton
PostPosted: 22:56 - 28 Jan 2009    Post subject: Reply with quote
Thats done your pistons good then Laughing
dwellernet
PostPosted: 09:42 - 29 Jan 2009    Post subject: Reply with quote
will use it as a good excuse to get a proper bike when my restriction run out then Laughing
SoND
PostPosted: 10:19 - 29 Jan 2009    Post subject: Reply with quote
Did you hold the bike up straight when you checked the dipstick?
No oil leads to serious damage.
Sir Black Pig
PostPosted: 11:47 - 29 Jan 2009    Post subject: Reply with quote
Could be a bone dry shim, centralise the bike, check and adjust your oil level accordingly, and DON'T rev the bollox off it.
Scraping sound means unlubricated/worn metal faces. Which means heat, which means mechanical seizures!
Careful, careful.
Eurotrip 2009
Sportugal 2010
dwellernet
PostPosted: 19:26 - 31 Jan 2009    Post subject: Reply with quote
cheers for the help
The last post was made 17 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 54.59 Kb
