| Cigaro |
 Cigaro World Chat Champion
 Posted: 16:09 - 29 Jan 2009 Post subject: |
Assuming it is a cable speedo driven from the front wheel.
It is was the cable wearing then it would need to catch up to the right speed pretty rapidly to avoid snapping the cable.
That pretty much leaves a worn out speedo (basically is turns ones magnet inside another, so dragging the outer one round), or a front wheel / tyre that is rather smaller than it should be.
Or the speedo was just never that accurate.
| the grim reaper |
 the grim reaper World Chat Champion
 Posted: 16:16 - 29 Jan 2009 Post subject: |
If it is a cable from the front wheel then I would expect it to under-read rather than over read, if the cable was playing up. Assuming 1-2mph error in your mate's car speedo, yours is well over 10% over reading, which is outside the recommended spec.
Is it an import? Could be that someone has fitted a KMH to MPH converter or similar, you can buy mechanical ones of these. If not then I reckon the speedo is knackered/worn. The speedo will have a number of gears inside to convert the cable rotation to needle rotation, take the clocks apart and check these are not sticking, or that the needle mount has become twisted. Does the needle return to 0mph when you stop?
Cheers
Grim ____________________ Adverts don't always work: Remember that advert, where the army are running across the desert and they have a wounded man on a stretcher. They get to a ravine, the bridge is down and a caption pops up that says, 'What are you thinking?'. I don't know about you but I was thinking, 'Christ, I'm glad I'm not in the f***ing army'. |
| LanaTheGreat |
 LanaTheGreat Scooby Slapper
| LanaTheGreat |
| nightshaddow |
 nightshaddow Nearly there...
The last post was made 17 years, 253 days ago. Instead of replying here, would creating a new thread be more useful? |
