Copper base gasket?
PostPosted: 15:43 - 31 Jan 2009    Post subject: Copper base gasket? Reply with quote
I can't remember if I asked this before or not.
Any engineering reason* why I shouldn't fit a base gasket cut out of a single piece of copper sheet to an air cooled 2-stroke? (In this case, a Jawa 350 twin)
To avoid argument, let's assume it is the same thickness as the proper fibre one and that I'm going to clag it with blue hylomar anyway.
*Other than the obvious "because it would take ages to cut out", it's halfway done anyway, just needs the holes putting in and annealing.
PostPosted: 15:53 - 31 Jan 2009    Post subject: Re: Copper base gasket? Reply with quote
As long as you seal it correctly with gasket sealant and the thickness is correct I don't see why not.
I have just received my copper head gasket for my RD, and apparently they are reusable etc.
PostPosted: 16:06 - 31 Jan 2009    Post subject: Reply with quote
No reason that I can think of. Might do well to anneal it before use, but since it's not holding combustion pressures that might not even be necessary.
tatters
Exxon Valdez
PostPosted: 16:15 - 31 Jan 2009    Post subject: Reply with quote
Would,nt the compression of the copper gasket be different to that of a fiber gasket when the cylinder is bolted down. increasing/decreasing the squish.
PostPosted: 16:19 - 31 Jan 2009    Post subject: Reply with quote
Squish is irrelevant on a base gasket, as long as the thickness of the copper is the same as the thickness of the base gasket I don't think its an issue. I doubt that a paper or fibre gasket would compress much more than an annealed copper one anyway.
PostPosted: 16:24 - 31 Jan 2009    Post subject: Reply with quote
Possibly, but given that there was a 1.00mm difference in squish between the two sides on a totally unmolested engine (which was running as well as they ever do), I'll assume the tolerances are wide enough to not only drive a bus through but for it to perform a 3-point turn while it's in there.
Everlasting base gasket it is then. Thumbs Up
Only place it can possibly leaking now is the crank seals (and it shouldn't be because they are new).
I even clagged green permabond on the centre bearing housing mechanical seal and red hermatite on the crankcase halves in a fit of temper. I'll never be able to split it again, but frankly, I don't want to. If it doesn't work this time I'm putting a match in the tank and pushing it off a cliff... Even if I have to put it in the van and drive 40 miles to find a cliff!
tatters
Exxon Valdez
PostPosted: 17:13 - 31 Jan 2009    Post subject: Reply with quote
thats a big difference, currently trying to work out endfloat of 0.05mm on a R100 gearbox bloody nightmare.
PostPosted: 17:19 - 31 Jan 2009    Post subject: Reply with quote
You have 2 thou endfloat and it's a problem? - or you are trying to achieve 2 thou endfloat?
lonner
PostPosted: 19:06 - 31 Jan 2009    Post subject: Re: Copper base gasket? Reply with quote
the only reason oe gasket was fibre is cost.
a copper gasket will be fine as the pressure will be no where near that of a head gasket and there copper for that reason so thumbs up mate i like your style Thumbs Up
PostPosted: 19:12 - 31 Jan 2009    Post subject: Reply with quote
Woot. Reduced the squish difference by a factor of 4 from standard by lapping the LHS head.
LHS: 2.12mm
RHS: 1.90mm
NB: For anyone reading this who doesn't know much about engines. A difference of 0.22mm in squish between either side of a 2-stroke twin is still absolutely appalling.
A squish band of over 2mm is fecking enormous.
You should not need to use red hermatite to join your crankcases, nor should you have to use it on your cylinder head. You should most definately never use green permabond on any part of your engine at all.
Blue hylomar on the base gasket is acceptable however.
PostPosted: 20:33 - 31 Jan 2009    Post subject: Reply with quote
Am I sensing the beard twitching urge to put on a pair of socks and sandals and geek off over two stroke motorcycles?
What bike is this? I assume its the Jawa? Very Happy
PostPosted: 22:12 - 31 Jan 2009    Post subject: Reply with quote
What's my user name again? Wink
Yes it's the Jawa.
I currently have two 2-strokes anyway. The Jawa and an H100.
I have also owned in the past a Minsk 125, a Tomos 50, a different Jawa 350, a suzuki T500 and a stage 3 tuned and bored RD375YPVS (in a 350LC chassis). My Dad also has a 1971 Kawasaki S2 triple which I am allowed a shotty of on occasion (although user privilages have been temporarily withdrawn because I scraped a load of chrome off the bottom exhaust last time I was out on it.).
The H100 is by far and away the most entertaining in terms of fun per cc. No 9bhp, 98cc bike should be able to wheelie off the throttle and do 65mph with me on it.
stevo as b4
PostPosted: 22:52 - 31 Jan 2009    Post subject: Reply with quote
People find it hard to believe, but as i've said before the H100 is a lightweight tool of choice in the sub 125cc catagory for 1st&2nd gear wheelies without the clutch! Laughing
The last post was made 17 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 83.6 Kb
