 Posted: 14:43 - 31 Jan 2009 Post subject: Copper base gasket? |
I can't remember if I asked this before or not.
Any engineering reason* why I shouldn't fit a base gasket cut out of a single piece of copper sheet to an air cooled 2-stroke? (In this case, a Jawa 350 twin)
To avoid argument, let's assume it is the same thickness as the proper fibre one and that I'm going to clag it with blue hylomar anyway.
*Other than the obvious "because it would take ages to cut out", it's halfway done anyway, just needs the holes putting in and annealing. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 MarJay But it's British!
 Posted: 15:06 - 31 Jan 2009 Post subject: |
No reason that I can think of. Might do well to anneal it before use, but since it's not holding combustion pressures that might not even be necessary. ____________________ a.k.a 'Geri'
| tatters |
 tatters Exxon Valdez
 Posted: 15:15 - 31 Jan 2009 Post subject: |
Would,nt the compression of the copper gasket be different to that of a fiber gasket when the cylinder is bolted down. increasing/decreasing the squish. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| MarJay |
| tatters |
 Posted: 16:13 - 31 Jan 2009 Post subject: |
thats a big difference, currently trying to work out endfloat of 0.05mm on a R100 gearbox bloody nightmare. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
 Posted: 16:19 - 31 Jan 2009 Post subject: |
You have 2 thou endfloat and it's a problem? - or you are trying to achieve 2 thou endfloat? ____________________ a.k.a 'Geri'
| lonner |
 lonner Spanner Monkey
 Posted: 18:12 - 31 Jan 2009 Post subject: |
Woot. Reduced the squish difference by a factor of 4 from standard by lapping the LHS head.
LHS: 2.12mm
RHS: 1.90mm
NB: For anyone reading this who doesn't know much about engines. A difference of 0.22mm in squish between either side of a 2-stroke twin is still absolutely appalling.
A squish band of over 2mm is fecking enormous.
You should not need to use red hermatite to join your crankcases, nor should you have to use it on your cylinder head. You should most definately never use green permabond on any part of your engine at all.
Blue hylomar on the base gasket is acceptable however. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 Posted: 19:33 - 31 Jan 2009 Post subject: |
Am I sensing the beard twitching urge to put on a pair of socks and sandals and geek off over two stroke motorcycles?
What bike is this? I assume its the Jawa?  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| stevo as b4 |
 Posted: 21:52 - 31 Jan 2009 Post subject: |
People find it hard to believe, but as i've said before the H100 is a lightweight tool of choice in the sub 125cc catagory for 1st&2nd gear wheelies without the clutch!  |
The last post was made 17 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
