desrestricting zx6
Rufus
PostPosted: 16:33 - 31 Jan 2009    Post subject: desrestricting zx6 Reply with quote
hi, tried taking the restrictors out of my zx6 today. got as far as taking the top half off the air box so i could see the slides in the carbs. what do i do now?
also, when taking the fuel tank off there was a loose tube at the rear end of the tank (which would be under the seat) what does it connect to?
(it's on the right hand side in this pic, the little metal bit sticking out)
https://www.netspace.org/users/bkd/picts/tmp/zx6r_gas_tank_left_small.JPG
thanks for any help Thumbs Up
CG125 > ZX6r > GSX600F > CB250n + ZX7R+ Bandit 1200
mad4it028
PostPosted: 17:51 - 31 Jan 2009    Post subject: Reply with quote
over flow pipe links to a pipe that comes out near bottem of swing arm iirc
mr.kris
PostPosted: 18:47 - 31 Jan 2009    Post subject: Reply with quote
thats ur over flow pipe dont worry next step is to take the rest of the air box off then the carbs come off then you will see some rubber tubes the cabs conect to the motor with just inside these are some big silver plates with a hole cut in them whip them out re asemble evrything and ur done! sorry new technical terms dont know how much you know or dont know if u need any adivce or get stuck just PM me and will explane what you need to do hope that helps
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
Rufus
PostPosted: 00:11 - 01 Feb 2009    Post subject: Reply with quote
so i have to actually take the carbs out? right. i'll try it tomorrow then when i have time and don't have to reassemble the bike ultra quick because i've remembered i need it to go to work. Mr. Green
MaybeGuy
PostPosted: 00:13 - 01 Feb 2009    Post subject: Reply with quote
put it back together and find someone who knows what they're doing.
Phoenix
Twisted Firestarter
PostPosted: 00:19 - 01 Feb 2009    Post subject: Reply with quote
It's not always just washers, they sometimes fit slide stops under the diaphragm caps too. Check your restrictor certificate, it state whether it's inlet blade (washers) and stops which I think are referred to as caps, this is usually done on bigger engines I think so not sure if it's used in the ZX6R.
Rufus
PostPosted: 00:28 - 01 Feb 2009    Post subject: Reply with quote
thanks, this is really helpful.
MaybeGuy
PostPosted: 00:52 - 01 Feb 2009    Post subject: Reply with quote
probably the best comment so far actually.
otherwise we'll get another thread about ''i took my wheels off to derestrict my bike and now it wont roll, why is that?''
Rufus
PostPosted: 00:58 - 01 Feb 2009    Post subject: Reply with quote
not quite mate. i've got a haynes manual and was following that. didn't want to take bits off that weren't necessary and as for the overflow pipe, it didnt mention anything about it so i wanted to know what it was.
we've all gotta start our knowledge somewhere.
mad4it028
PostPosted: 02:04 - 01 Feb 2009    Post subject: Reply with quote
you dont learn by not doing and by doing you somtimes need advice keep at it mate we all had to learn some how
The last post was made 17 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 66.53 Kb
