AAAAARGH! I hate wire piston circlips!!!
PostPosted: 15:09 - 01 Feb 2009    Post subject: AAAAARGH! I hate wire piston circlips!!! Reply with quote
Evil or Very Mad Evil or Very Mad Evil or Very Mad
OK, here's the situation:
I'm rebuilding my 350 powervalve. Old pistons are now sitting on my bookcase looking pretty. I've put the new piston rings on the new pistons with an amusing claw shaped tool that I bought. I've covered the whole shebang in castrol TTS. I soaked the small ends in TTS for a while, and then put 'em in the con rods. I put the inner side circlips in each piston, and eased in a freshly 2t oiled gudgeon pin (it seems more modern to call it a wrist pin, but that doesn't sound as good as a gudgeon pin!).
Ok, so how in the name of f*%K do I get the wire circlips in the outsides of the pistons?
I've done the top end before on an RGV250 and I recall that the circlips went in easily. I can't remember if they were flat circlips with little holes in the end or not, but I recall that it was pretty easy.
These RD wire ones are a total f%£king nightmare! They are way to large to fit in place without compressing them right down, and every time I try that the flipping things ping off somewhere. Once I thought I had lost one of them (inconvenient as I only have four new ones) and once I dropped it into the crankcase (now I've got a plastic bag covering the crankcase opening - lucky I have a magnetic grabby widget!)
How in the hey-ull are you supposed to fit 'em? Is there a prescribed technique for doing it? Or is it just a case of swearing, cursing and having a magnetic grabber to hand? Evil or Very Mad Shocked Evil or Very Mad
Ant132
PostPosted: 15:26 - 01 Feb 2009    Post subject: Reply with quote
Are they the e-shaped ones? I just put the open end in the groove and use a pair of long-nose pliers to pull the bend of the 'e' and pull it down until it slips in. Thumbs Up
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
PostPosted: 16:18 - 01 Feb 2009    Post subject: Reply with quote
They just a circle of spring steel, like this?
https://www.mfgsupply.com/img/snowmobile/engine/tn/cwclips.jpg
If so, I usually hook oner end in the groove, grip the other end in some needle-nose pliers and kind of twist it in, pushing the edge into the hole in the piston as I go (a bit like pressing the bead on a tyre down).
EDIT:
Google images to the rescue! Like this, notice where his thumbnail is going white from pressing it in, that's the bit people miss out:
https://www.crrcpro.com/image/gf40i/Manual/11.jpg
EDIT#2: If it is too hard, they might have sent you the wrong size, I don't usually have any trouble fitting them.
Ant132
PostPosted: 16:25 - 01 Feb 2009    Post subject: Reply with quote
Aha, never had them like that before
Always had them in an actual 'e' shape. Same as the second pic Thumbs Up
PostPosted: 16:49 - 01 Feb 2009    Post subject: Reply with quote
Well, they came with the pistons sealed in the boxes. They do fit as I have fitted the left one on the right piston and vice versa. I did have to kind of fit them sideways and then use the gudgeon pin to turn them the right way round to fit into the groove.
The problem I've got is that with the gudgeon pins fitted and the engine still in the bike its really fiddly to get the clips in the right place!
PostPosted: 18:05 - 01 Feb 2009    Post subject: Reply with quote
What I normally do is put one end in and then use a small screw driver to work round pushing more and more in. Having had circlips pop out before (although that was the type with tails) I am not inclined to bend them more than I have to when getting them in place.
salty21
PostPosted: 20:20 - 01 Feb 2009    Post subject: Reply with quote
+1 for the small flat ended screwdriver
PostPosted: 20:22 - 01 Feb 2009    Post subject: Reply with quote
Could you not use the old gudgeon pin in a similar way?
PostPosted: 21:09 - 01 Feb 2009    Post subject: Reply with quote
The old gudgeon pins don't appear to fit in the pistons any more... Thinking
and it involves having room for the circlip to be at 90 degrees to the groove... Thinking
The old gudgeon pins are grooved and scored, and they were a pain to remove from the old pistons.
stevo as b4
PostPosted: 21:31 - 01 Feb 2009    Post subject: Reply with quote
Id fit them dry and make sure that there is no oil on the clips or in the piston circlip locating grooves. you don't need to oil anything other than the small end bearing race, until your ready to slide the barrels/ cylinder block on.
Just out of interest does the YPVS have separate barrel's or a one peice set set up, as i can't remember?
PostPosted: 22:12 - 01 Feb 2009    Post subject: Reply with quote
stevo as b4 wrote:
Id fit them dry and make sure that there is no oil on the clips...
Well I got a bit of oil on 'em. I'll just get some mechanics tissue and mop it up I guess. My needle nosed pliers managed to get oil on them too... which clearly didn't help!
hmmmnz
PostPosted: 06:36 - 02 Feb 2009    Post subject: Reply with quote
i hate those buggers as well,
i normally just go to my local helpful man and get a few proper circlips,
mucho easiness Mr. Green Thumbs Up
the humans are dead
I kick arse for the lord
Lone-Wolf
PostPosted: 07:24 - 02 Feb 2009    Post subject: Re: AAAAARGH! I hate wire piston circlips!!! Reply with quote
Wotcha.
Now you know why they are called "pingfuckits" Mr. Green
Cheers.
L.W. - www.moonshiners.org.uk
PostPosted: 09:42 - 02 Feb 2009    Post subject: Reply with quote
Thats funny Lonewolf, I was going to christen them "Bastard circlips" because when you lose one as it pings off you shout "Bastard!" Laughing
lukamon
PostPosted: 18:25 - 02 Feb 2009    Post subject: Reply with quote
for fuck sake make sure you position them properly, on my ped the clip popped out - took two hours and a lump hammer to get the piston out of the bore, and needed a rebore and new piston Embarassed
agree with bastardclips - once lost one of the kmx, put another in, rotated the crank a few times, then noticed the clip sitting on the crankshaft, held on by the coating of oil Embarassed
edit - found a pic Laughing Laughing Laughing
https://i36.photobucket.com/albums/e1/lukamon/DSCI0017.jpg
killa wrote: Im an ass man myself
Robby
Dirty Old Man
PostPosted: 21:24 - 02 Feb 2009    Post subject: Reply with quote
You may have heard me and Keith refer to them as oh shit clips.
Oh shit being the noise you make when they ping off into the darkest corner of your garage, or your eye.
No need for lots of 2 stroke oil, when you get down to fitting the oh shit clips you can generally lubricate the engine with blood and swearing.
ZRX61
Victor Meldrew
PostPosted: 23:20 - 02 Feb 2009    Post subject: Reply with quote
Piece of piss when you have the correct tool Wink
PostPosted: 09:18 - 03 Feb 2009    Post subject: Reply with quote
Care to provide a link to the correct tool? I have circlip pliers but they are useless as these circlips don't have holes in! Smile
Ariel Badger
PostPosted: 11:38 - 03 Feb 2009    Post subject: Reply with quote
Stuff the case with rag so when one pings off it does not ener the engine. I find that cocking them so one end is in the groove and then putting your thumb over it helps locate it ready for a push with the screwdriver. Of course if you slip the screwdriver goes into your thumb Mr. Green Thumbs Up
D O G
PostPosted: 14:12 - 03 Feb 2009    Post subject: Reply with quote
Woah there MarJay, that would actually be offering useful help, rather than just being a smug bastard!
The last post was made 17 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 129.43 Kb
