| MarJay |
 MarJay But it's British!
 Posted: 15:09 - 01 Feb 2009 Post subject: AAAAARGH! I hate wire piston circlips!!! |
OK, here's the situation:
I'm rebuilding my 350 powervalve. Old pistons are now sitting on my bookcase looking pretty. I've put the new piston rings on the new pistons with an amusing claw shaped tool that I bought. I've covered the whole shebang in castrol TTS. I soaked the small ends in TTS for a while, and then put 'em in the con rods. I put the inner side circlips in each piston, and eased in a freshly 2t oiled gudgeon pin (it seems more modern to call it a wrist pin, but that doesn't sound as good as a gudgeon pin!).
Ok, so how in the name of f*%K do I get the wire circlips in the outsides of the pistons?
I've done the top end before on an RGV250 and I recall that the circlips went in easily. I can't remember if they were flat circlips with little holes in the end or not, but I recall that it was pretty easy.
These RD wire ones are a total f%£king nightmare! They are way to large to fit in place without compressing them right down, and every time I try that the flipping things ping off somewhere. Once I thought I had lost one of them (inconvenient as I only have four new ones) and once I dropped it into the crankcase (now I've got a plastic bag covering the crankcase opening - lucky I have a magnetic grabby widget!)
How in the hey-ull are you supposed to fit 'em? Is there a prescribed technique for doing it? Or is it just a case of swearing, cursing and having a magnetic grabber to hand?  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Ant132 |
 Ant132 World Chat Champion
 Posted: 15:26 - 01 Feb 2009 Post subject: |
Are they the e-shaped ones? I just put the open end in the groove and use a pair of long-nose pliers to pull the bend of the 'e' and pull it down until it slips in.  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| stinkwheel |
 Posted: 16:18 - 01 Feb 2009 Post subject: |
They just a circle of spring steel, like this?
https://www.mfgsupply.com/img/snowmobile/engine/tn/cwclips.jpg
If so, I usually hook oner end in the groove, grip the other end in some needle-nose pliers and kind of twist it in, pushing the edge into the hole in the piston as I go (a bit like pressing the bead on a tyre down).
EDIT:
Google images to the rescue! Like this, notice where his thumbnail is going white from pressing it in, that's the bit people miss out:
https://www.crrcpro.com/image/gf40i/Manual/11.jpg
EDIT#2: If it is too hard, they might have sent you the wrong size, I don't usually have any trouble fitting them. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Ant132 |
 Posted: 16:25 - 01 Feb 2009 Post subject: |
Aha, never had them like that before
Always had them in an actual 'e' shape. Same as the second pic  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| MarJay |
| Kickstart |
 Kickstart The Oracle
| salty21 |
 salty21 World Chat Champion
 Posted: 20:20 - 01 Feb 2009 Post subject: |
| stinkwheel |
| MarJay |
| Vincent |
 Vincent Banned
 Posted: 21:14 - 01 Feb 2009 Post subject: |
Yup, stick the open end in the groove then use yer finger or a pair of pliers to push it in starting from the open end. Make sure you position the clips correctly once in the groove, I've seen a few pop out before
I all ways find myself singing this song for some reason when replacing piston circlips:-
https://uk.youtube.com/watch?v=VTi2hbUlq1Q |
| Blau Zedong |
 Blau Zedong Banned
| stevo as b4 |
| Vincent |
 Vincent Banned
| MarJay |
| hmmmnz |
 hmmmnz Super Spammer
| Lone-Wolf |
 Lone-Wolf World Chat Champion
| MarJay |
 Posted: 09:42 - 02 Feb 2009 Post subject: |
Thats funny Lonewolf, I was going to christen them "Bastard circlips" because when you lose one as it pings off you shout "Bastard!"  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| lukamon |
 lukamon World Chat Champion
 Posted: 18:25 - 02 Feb 2009 Post subject: |
for fuck sake make sure you position them properly, on my ped the clip popped out - took two hours and a lump hammer to get the piston out of the bore, and needed a rebore and new piston
agree with bastardclips - once lost one of the kmx, put another in, rotated the crank a few times, then noticed the clip sitting on the crankshaft, held on by the coating of oil
edit - found a pic
https://i36.photobucket.com/albums/e1/lukamon/DSCI0017.jpg ____________________ killa wrote: Im an ass man myself |
| Robby |
 Robby Dirty Old Man
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 23:20 - 02 Feb 2009 Post subject: |
Piece of piss when you have the correct tool  |
| MarJay |
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 11:38 - 03 Feb 2009 Post subject: |
Stuff the case with rag so when one pings off it does not ener the engine. I find that cocking them so one end is in the groove and then putting your thumb over it helps locate it ready for a push with the screwdriver. Of course if you slip the screwdriver goes into your thumb  ____________________ Bikers make great organ donors, get 115 on your licence today. |
| D O G |
 D O G World Chat Champion
The last post was made 17 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
