 muffy Borekit Bruiser
 nightshaddow Nearly there...
 Posted: 19:22 - 01 Feb 2009 Post subject: |
best thing is to start from the top pull them all off and check every hose every tank and radiator in the cooling system,
start with the thermostat drop it in hot water (from a kettle, at boiling point) if it opens its good if it stays closed its not
take of the header tank and flush it out then fill it with water check it and check it all drains out with no clogging (if no water comes out see why not that your problem.
next the hoses once removed just attach a hose and sprey water through if it builds presure and blows back water theres your problem,
next you need to check the radiator, take it of the bike and fill with water make sure all the water drains out every outlet without blockage,
then the cylinder with all the water system removed fill the cylinder water chambers with water make sure it flows in and out smoothly.
my money personal would be either on the thermostat or put together wrong once you have checked all these rebuild the water system taking care the hoses and everything are in the right place and the water is traveling the right direction, dont forget your anti freeze its cold out there, if you still have the problem if no one else has any suggestions its time for a garage ____________________ "WHAT DO YOU MEAN 100 MPH THATS IMPOSSIBLE Its chinese OFFICER."
Current rides CB 125 TDE(the next project) NS125RK ( now on the road ) CB125TDC (soon to be project 17) melody ( the nephews ) |
 lukamon World Chat Champion
