HEEELP!! Spark Problems..
robbobnob
PostPosted: 15:33 - 03 Feb 2009    Post subject: HEEELP!! Spark Problems.. Reply with quote
OK I'm stuck now. My RS 125 was not starting and now it is, sort of. I was checking if it had a strong spark so when i checked, it started but when i put the lead properly on the spark plug it died..What the hell could it be? Confused
Cigaro
PostPosted: 15:36 - 03 Feb 2009    Post subject: Reply with quote
Fecked HT lead?
robbobnob
PostPosted: 15:43 - 03 Feb 2009    Post subject: Reply with quote
I hope not. I thought that but then it's sparking perfect when it's not sitting on the spark plug proplery. If it's touching the outer rim or about 1mm away its perfect starts first time.
Cigaro
PostPosted: 16:03 - 03 Feb 2009    Post subject: Reply with quote
Exactly, which sounds like a faulty contact inside the HT lead. May as well replace it, they don't cost much.
robbobnob
PostPosted: 16:04 - 03 Feb 2009    Post subject: Reply with quote
OK, I'll give that a go. Cheers.
ninja_lover
PostPosted: 16:25 - 03 Feb 2009    Post subject: sparkin problems Reply with quote
hey all i had my lil jm star 50cc 2006 for bout 6 months, was runnin perfectly, it was turnin over and nuthin was there wudnt even start, so first thing i checked spark plug nd changed it n im stil not getin a spark atall, been told it myt b bcoz of my immobiliser cos its aftermarket one but cant find anythin with a wirin diagram??? or is there any other possibilities to why it wont start? has plenty of fuel n oil n recently been serviced so:S please get bak if u can help oh and im not even gettin any power thru the starter coil wen i checked on voltmeter readin bout 3 volts wen shud b between 9 n 12:s
Cigaro
PostPosted: 17:27 - 03 Feb 2009    Post subject: Re: sparkin problems Reply with quote
Do you mean ignition coil?
Sounds like a faulty CDI unit to me, could indeed be related to immobiliser. Unfortunately without a wiring diagram or at least a make and model for the CDI and immobilliser there's not much you can do except bodge a different CDI on to it. Note that the immobiliser is usually part of the CDI unit.
ninja_lover
PostPosted: 17:35 - 03 Feb 2009    Post subject: Reply with quote
yea sorry lol engines talk messes wit my brain lol cant do the simple stuff but wen comes electrics its a no go lol i did have problems wit immobiliser before it only worked wen i had to jump start of cars the alarm wud disable and work but now its not working so thinking thats the main problem or as u can say cdi unit, il jst take it off n get replacement if i can find it lol i think its aftermarket one cos there no light saying wen it is on or off. thanks anyway lol
is fed up of being on his 50cc durin the winter and also avin many faults:( roll on april wen me ninja comes out:D
Blue_SV650S
Have you tried a new/different spark plug?
After that my next try would be a new plug cap. (I assume it is a lead and cap job not an all in one?!?!).
ninja_lover
PostPosted: 17:59 - 03 Feb 2009    Post subject: Reply with quote
yes iv tried new plug i tryed standard ngk one and a high performance one, if you look it at previous comment u can see i said i tryed new spark plug,
Blue_SV650S
PostPosted: 18:16 - 03 Feb 2009    Post subject: Reply with quote
Ah, I was actually addressing the OPs problem, sorry for the confusion!
Must admit I didn't read your posts properly as I find excessive 'text speak' a little irritating and frankly with limited punctuation, hard work. Sad
That is not a 'dig' by the way, write how you like, I am just too lazy to try and decipher what you put to then try and offer advice!
If you wanna spend the time to try and re-write your problem a bit more traditionally so it is easier for me to read/understand your problem, then I'll spend the time thinking about it and trying to offer some advice .. Thumbs Up .. I am not trying to be a cnut and saying it has to be perfect English or I won't read it (this is a forum, so we can be pretty lax in prose) but just try and write it a bit clearer and I'll try and help.
ninja_lover
PostPosted: 18:59 - 03 Feb 2009    Post subject: Reply with quote
lol its ok, im 19 so going to be all teenager talk Razz i think i got it all sorted got new cdi unit n immobiliser on order so shud b sorted
robbobnob
PostPosted: 19:04 - 03 Feb 2009    Post subject: Reply with quote
I havn't tried a new spark plug as i got to order the thing cause our local aprilia dealership has closed down. I got a new lead/coil on order. It's all in one hopefully it'll solve the problem.
Blue_SV650S
PostPosted: 20:55 - 03 Feb 2009    Post subject: Reply with quote
Is it a special plug then? (I really doubt that) Halfords do a reasonable spread of the most popular bike plugs ...
edit: after a quick google:-
NGK/BR10EG Spark Plug - Aprilia RS125 (All Models) 91-02
A BR10EG is a very popular plug, I'd put a very high probability on halfords stocking it ...
I'd have tried the plug before splashing out on a coil pack ...
Even if it wasn't your problem (and it is the coil/HT lead/cap), a new plug is never going to do any harm ... particularly in a 2-stroke, so it won't be a waste of cash! Wink
If I were you I'd get yourself down halfords regardless of having the coil on order ... ...
Or if Halfords will be difficult to get to and you have an eBay account ... https://cgi.ebay.co.uk/NGK-spark-plug-BR10EG-plugs-BR10-EG-tradeprice-3830_W0QQitemZ250364211912
robbobnob
PostPosted: 21:49 - 03 Feb 2009    Post subject: Reply with quote
Cheers for the help but i don't have a halfords. I live on an island. I got mine off Ebay.
The last post was made 17 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.36 Sec - Server Load: 1.75 - MySQL Queries: 13 - Page Size: 82.44 Kb
