Electric help (Too many gadgets!)
PostPosted: 04:38 - 04 Feb 2009    Post subject: Electric help (Too many gadgets!) Reply with quote
Right Currently I have 4 things attached to each Battery terminal on my TDM.
I have
Air Horn
Heated Grips
Cigarette Adaptor
Loom
I want to attach a optimate adaptor to it as well but I think it's getting abit silly. I want to rewire and tidy it up, I'm looking for ideas how to group the lot together I only really want 1 extra wire coming off each battery terminal. Any suggestions?
iooi
PostPosted: 07:05 - 04 Feb 2009    Post subject: Reply with quote
Trip to scrapyard and pick up a cheap fuse box.
Find another thick cable to go from battery to fuse box, then rewire all from that fuse box.
Could you not just adapt the optimate to go to the ciggi adaptor..
PostPosted: 07:58 - 04 Feb 2009    Post subject: Reply with quote
I could but it is already a mess and wanted to tidy it anyway. How would you connect the 4 wires to 1?
finpos
PostPosted: 10:36 - 04 Feb 2009    Post subject: Reply with quote
The way it's generally done is to wire everything in [not serial, parallel - Edited for stupidity].
So have a wire run from the battery to the air horn*. Put two wires into the crimp terminal for that. You now have a loose end of wire. run that to the fag lighter, again, two wires into the crimp, run the loose one to the hot grips. Use fat wire and big crimps Smile
* via a single fuse of sufficient magnitude to take the load of all the accessories, obviously. Also you need to be careful you don't have the optimate powering anything, so everything on that wire needs to be switched. In fact, you'd be much better taking the accessory wire from a switched supply(e.g. at the fusebox) than the battery terminal. The optimate then goes straight to the battery.
f.
Cigaro
PostPosted: 11:30 - 04 Feb 2009    Post subject: Reply with quote
finpos wrote:
The way it's generally done is to wire everything in series.
Except that simply wouldn't work.
Wire them in parallel instead.
So the two wires would go to one device, then from there to the next one, etc.
Make sure you stick a fuse at the end that connects to the battery
Shit paint diagram attached.
NSR Mick
PostPosted: 11:33 - 04 Feb 2009    Post subject: Reply with quote
You would be best adding a second fuse box.
Some cheap ones here.
https://cpc.farnell.com/jsp/search/browse.jsp?N=411+500001+1001434&Ntk=gensearch_003&Ntt=fuse+box&Ntx=
Finglonga
PostPosted: 11:45 - 04 Feb 2009    Post subject: Reply with quote
I use my power socket to charge the bike, just a case of plugging it in if needed then as it goes directly to the battery. No extra wires needed then.
Air horn as said should be directly from battery(fused) to cut any loss in power.
Andy Sez....
F.Y.Y.F.F.
chillpill
PostPosted: 12:57 - 04 Feb 2009    Post subject: Reply with quote
thats wired in series
worse paint diagram attached Laughing
PostPosted: 13:06 - 04 Feb 2009    Post subject: Reply with quote
Very shit.
Either you missed the switch and the heated grips would only come on when you sound the horn, or the horn is on all the time.
Do this.
map
Mr Calendar
PostPosted: 13:14 - 04 Feb 2009    Post subject: Reply with quote
Best thing would be, as you said, to rewire and to add another fuse box.
Look at some of the BMW touring sites or search my-mc.com (search for "fuse box", you get links like this) for ideas.
The fuse box you want is one of the waterproof ones used in boats (marine suppliers/chandelers), bright yellow if I remember.
Wire into a live feed, put a fuse on it with a relay. Then wire your electric gadgets from the fuse box, fitting other relays as appropriate.
PostPosted: 21:53 - 04 Feb 2009    Post subject: Reply with quote
How would I split the single wire from the battery though?
The air horn is on a relay, everything is fused individually.
Now
https://img.photobucket.com/albums/v295/chris-red/my%20pics/now.jpg
should be
https://img.photobucket.com/albums/v295/chris-red/my%20pics/shouldbe.jpg
chillpill
PostPosted: 21:57 - 04 Feb 2009    Post subject: Reply with quote
get the multiple wires , trim the ends and twist them together creating one wire Thumbs Up
looks messy but does the job and can be covered up with insulation tape
loply
PostPosted: 22:15 - 04 Feb 2009    Post subject: Reply with quote
I don't really see the problem with having lots of accessories bolted to the battery terminals. Incidentally some batteries have two screws on the terminals for this purpose.
Sure, it probably makes a bit of a birds nest, but if you're anything like me you probably disconnect, replace or upgrade accessories frequently. Any kind of custom-made wiring harness is going to be a waste of time and effort.
If it's just a nuisance because you have to line up 5 rings each time you d/c the battery then consider soldering the rings together into one - quick, simple and temporary.
You could also consider earthing some of your accessories to nearby frame or engines bolts or other parts of the bike, rather than the neg terminal on the battery. Make sure you do this after any relevant switches though.
This would just reduce some of the birds-nest effect under the seat.
Yamaha SZR660 Caution to the wind, the throttle pinned!
PostPosted: 23:45 - 04 Feb 2009    Post subject: Reply with quote
That should read, you can twist the ends of the wires together then solder them and cover the joint in adhesive backed shrink tube.
That way if you land up selling the bike to stinkwheel at some point in the future, he doesn't have to track you down and shove your insulating tape up your arse after spending two days tracking down an intermittant wiring fault.
EDIT:
How about wiring up a couple of terminal blocks in the following fashion? (less shit paint diagram attached)
You can buy terminal blocks ready to crimp and assemble yourself. Have your accessories on the other half of the block.
Providing the wire is thick enough, this is a tidy and elegant way of doing it. You would be able to unplug the battery from the loom without any tools.
As has been said, connect earths to the frame near where the accessory is. You only need one earth strap going between the battery negative and the frame itself.
This type of connector block is good. They are waterproof. Cost under a tenner.
https://www.vehicle-wiring-products.eu/VWP-onlinestore/connectors/photo/swp5.jpg
chillpill
PostPosted: 23:51 - 04 Feb 2009    Post subject: Reply with quote
Laughing Laughing Laughing
but i couldnt be bothered to type all that Mr. Green
PostPosted: 00:49 - 05 Feb 2009    Post subject: Reply with quote
That block looks useful, where would I get one from?
The problem with having all that shit attached to the battery is that it is really difficult to screw the terminals to the battery as all the connections mean the screw only just gets in far enough to pick up the block.
iooi
PostPosted: 07:11 - 05 Feb 2009    Post subject: Reply with quote
Ever thought of a longer screw..... Rolling Eyes Laughing
Cigaro
PostPosted: 10:16 - 05 Feb 2009    Post subject: Reply with quote
As others have said, a fusebox would be best. Then each device is individually fused.
No it ain't. https://en.wikipedia.org/wiki/Series_and_parallel_circuits
Better diagram:
mr jamez
PostPosted: 10:40 - 05 Feb 2009    Post subject: Reply with quote
vehicle wiring products
Finglonga
PostPosted: 15:14 - 05 Feb 2009    Post subject: Reply with quote
Picture properties? Question Laughing
Andy Sez....
F.Y.Y.F.F.
headgear
PostPosted: 12:56 - 06 Feb 2009    Post subject: Reply with quote
Very shit.
Do this.
What the man^^^^says Thumbs Up
Cover me in tuna and throw me to the lesbians.
PostPosted: 13:04 - 06 Feb 2009    Post subject: Reply with quote
Simplest solution would be to wire a few of the items to the terminal for the starter relay (the terminal connected to the battery).
Earths are easy to find.
NiteMare
PostPosted: 13:30 - 06 Feb 2009    Post subject: Reply with quote
careful Kickstart, you'll be expecting folks to start thinking next Mr. Green
i personally prefer taking un-necessary things out of the harness, as then there's less likelihood of stuff going wrong , no sidestand/clutch switches or un-necessary diodes in my slabby, along with having binned the lights relays, leds where possible to reduce the current draw from the battery/charging system, i also like the choice to be able to turn my lights off
it ain't broke...
i ain't fixed it enough
finpos
PostPosted: 19:16 - 06 Feb 2009    Post subject: Reply with quote
Er, yes, I did mean wire them in parallel, description was right though Smile I think what I meant to say was wire them in series, which is different.
You can wire it as I described to avoid unnecessary "T" type joints and junction boxes etc. Also, there's no need to negative run wires back to the battery, just to the frame by the nearest earthing point.
f.
Phoenix
Twisted Firestarter
PostPosted: 03:08 - 07 Feb 2009    Post subject: Reply with quote
Several things you can safely tap off other circuits to save wiring to the battery. I run exactly the same equipment as you. Heated grips are powered directly off the low beam feed, they only draw about 30watts so are well within the limits of the wiring guage and the headlight fuse.
The cigarette lighter you can run off a thick guage wire to the battery, you can split this wire into 2 further away from the battery and have one go to the air horn relay to save 2 seperate wires onto the battery terminal, just make sure the combined current draw off all circuits doesn't exceed the guage and fuse of the single feed from the battery. So if you have an air horn pulling 20 amps and a cigarette lighter maxing at 20 amps and you join the wiring before the battery, the wire to the battery must be 40 amp while the 2 branches can be 20 amp each, if doing it this way you're best off fusing each branch rather than the main wire.
The last post was made 17 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.04 - MySQL Queries: 15 - Page Size: 135.15 Kb
