Quick Oil Question
Carl_steveo
PostPosted: 10:56 - 07 Feb 2009    Post subject: Quick Oil Question Reply with quote
I have had my NSR125 for about a month now and its due a topping up of 2stroke oil. Only thing is i don't know what oil the previous owner used. So is it okay to just add more oil or should i wait till the oil thats in has ran out to a comfortable level then add my new oil.
Thanks Carl
robbobnob
PostPosted: 11:01 - 07 Feb 2009    Post subject: Reply with quote
If it was me and the bike needed oil i'd put fully syn in it any well known brand would do
Carl_steveo
PostPosted: 11:14 - 07 Feb 2009    Post subject: Reply with quote
I have the oil and its a well known brand i'm just not sure if its a good idea to mix with whats already in.
robbobnob
PostPosted: 11:24 - 07 Feb 2009    Post subject: Reply with quote
I don't see a problem with it. I've done it on my little 125 2 stroke n it's still fine. I just buy what ever fully synthetic oil is at the shops for it Smile
Ariel Badger
PostPosted: 11:41 - 07 Feb 2009    Post subject: Reply with quote
Draw a small sample from the tank and mix with an equal sized sample in a test tube and leave overnight.
If they have not separated you will be fine, If they have separated you will probably be fine.
hmmmnz
PostPosted: 11:50 - 07 Feb 2009    Post subject: Reply with quote
what ever you chuck in will be fine, but the smell of castor based oils is how it should be Very Happy
drain whats in the tank, and fill up with the new oil, the stuff in the lines will get used on your next ride
the humans are dead
I kick arse for the lord
Mudskipper
PostPosted: 12:01 - 07 Feb 2009    Post subject: Reply with quote
I'm sure mixing types of oil will be better than a seized engine?
binge
Emo Kiddy
PostPosted: 12:05 - 07 Feb 2009    Post subject: Reply with quote
Its all going to be burnt anyway. Although I have known oils to react before.
I'd do what has been said and just pop the pipe off the oil pump. Drain out the oil in the tank. Then re-fill with the new oil. That small amount of oil left in the pipe work and the pump will burn off in a few minutes anyway.
Ben
PostPosted: 12:09 - 07 Feb 2009    Post subject: Reply with quote
Chances are 99% likely it will be fine if mixed.
There can be odd reactions with oils, but other than mixing castor based oils and mineral oils I only know one person who has suffered that (and that was diff oil in a car).
cestrian
PostPosted: 12:55 - 07 Feb 2009    Post subject: Reply with quote
Mixing 2T is fine.
Carl_steveo
PostPosted: 15:20 - 07 Feb 2009    Post subject: Reply with quote
Thanks alot people, i don't really have much choice now anyway my oil light has just come on the journey home.
The last post was made 17 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 66.54 Kb
