| Drew |
 Drew Banned
| Nebzor |
 Nebzor Trackday Trickster
| Rovman |
 Rovman Scooby Slapper
| iooi |
 iooi Super Spammer
 Posted: 12:05 - 08 Feb 2009 Post subject: |
The adsl side does not need to be filtered, its just the phones that need a filter.
What you have done should work.
If its not then i would add a seperate filter to the sky box and phone.
Adsl side does not need to be filtered, only phone's. So you could (cough) hard wire the router to the back of the BT master socket  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| JonB |
 JonB Afraid of Mileage
| Nebzor |
 Posted: 12:29 - 08 Feb 2009 Post subject: |
I would've thought you've got a noiseless line from the socket to the first filter, then a noisy line going to the splitter as the sky box and phone are interfering with each other hence needing another filter.
But I may be totally wrong. ____________________ Peugeot Speedfight 2 - Honda VFR400 - Honda CB500 |
| Drew |
 Drew Banned
| sickpup |
 sickpup Old Timer
| truslack |
 truslack World Chat Champion
| TheMundy |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 TheMundy Borekit Bruiser
 Posted: 14:23 - 09 Feb 2009 Post subject: |
| iooi wrote: | The adsl side does not need to be filtered, its just the phones that need a filter.
Adsl side does not need to be filtered, only phone's. So you could (cough) hard wire the router to the back of the BT master socket  |
Epic fail on numerous levels.
Your layout is fine by the way. ____________________ Telling it like it is since 1978. |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 15:42 - 09 Feb 2009 Post subject: |
Your layout is fine. Read this.
https://www.adsl-filters.co.uk/tutorial.html ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| iooi |
 iooi Super Spammer
| Charlie |
 Charlie World Chat Champion
| Rovman |
 Posted: 00:08 - 10 Feb 2009 Post subject: |
| Quote: | Are the filters for the phone basically low pass filters? I guess they allow everything through to the phone if it is 4KHz? |
Yes they are low pass analog filters.
I don't see what the argument is about filters here, not really relevant to the question. Yes it's true that the ADSL signal itself itself does not require filtering, but going by the diagram. Everything on the "Right side" of that filter is filtered, no matter how many additional phones/sky boxes/extension leads are added boyond that point, no more filters are required. The only way more filters would be needed there would be if the original filter wasn't there and instead was placed after the splitter but then both the sky box and the telephone would need their own filters. That would be a pretty messy way to do it.
Filters are not only there for your phones also. If you have a master socket with just an ADSL modem connected, then no filters are required. But as soon as you put a phone into the mix a filter is needed, not just to prevent interference on the phone line, but the phone can also interfere with your ADSL connection.
| Quote: | My router is running on a un filtered line straight out of the rear of master phone box This is split and the phone run of one side the router off the other. Each phone in the house is then filtered. |
Thats also a pretty messy setup, i mean yeah it will work fine, but there are better ways. Assuming you have the current standard master socket (NTE5) with removable face plate, the best bet is to get a filtered faceplate. It directly replaces the faceplate of the master socket and has 2 connectors on the front, one for your ADSL and one filtered telephone. Everything plugged into the telephone side is filtered.
Then on the back side of the face plate has the standard IDC connectors used for wiring in your extensions, but these are also filtered.
Using this means you need no actual standard filters anywhere else in the house.
Back to the original post though, as I mentioned before. Your diagram is perfect, there is no other way to wire that up correctly (without using different parts I mean) so I'd start looking at other things that could be the problem. ____________________ Theory Test Passed 01/03/2008 || A2 Test Passed 04/04/08
Kawasaki Ninja 250r 2008 |
The last post was made 17 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
