| frazer1981 |
 frazer1981 Nitrous Nuisance
 Posted: 13:59 - 09 Nov 2008 Post subject: Project MTX........ |
Ok i have a mtx125 rwl on a J plate (92 model) and have decided it's time for a complete rebuild from the ground up.
Have decided on a plan of action for this project which goes like this.
1- Total strip down of bike, removel of engine ETC
2- Get to the bottom of the running problem it has, most evidence points towards the woodruf key snapping that holds the fly wheel on which let it rotate slightly on the crank changing the igition timing.
3- Total repaint of the frame from white to black. White as you may already know white is a bitch to keep clean.
4-replace steering bearings, swing arm bearings.
5-New con-rod, bottom end bearings, top end job and rebore to boot.
6- New plastics side panels, headlight cowl etc etc.
I have even looked into getting a set of USD forks from a 92 cr 125 and a swing arm as well so at least there,s disk brakes front and back instead of drum on the rear but that is something i am going to have to resarch ie measurement and fitment.
I intend of posting pictures as well so that you guy's can see the progress but i need to work out how to post pictures. If anybody here has any knowledge of the mtx then any hints or tips would be great. ____________________ 1st bike - chunlan starway 50QF4 (SOLD) 2nd bike - 92 Honda mtx125RW-L ( In my garage awaiting some TLC)
05 Honda xl125v Varadero stolen and recovered but now a write off!
07 Hyosung GTR125R |
| satelliteone |
 satelliteone Nitrous Nuisance
| frazer1981 |
| frazer1981 |
 Posted: 17:09 - 10 Nov 2008 Post subject: |
Started stripping the bike down today. Got as far as taking the engine out everything else like plastics, tank, seat etc etc removed as well.
There where several parts that where a bitch to get off. The air box and battery holder are a one part moulding and it was a nightmare to get off the frame as the rear pillion pegs where in the way so had to take them off and the 2 stroke tank just so i could turn and get the airbox out ( thought id be able to get the airbox off 1st before the 2 stroke tank)
How do i post picture's in my post's, so don't have to put links for them ?? ____________________ 1st bike - chunlan starway 50QF4 (SOLD) 2nd bike - 92 Honda mtx125RW-L ( In my garage awaiting some TLC)
| frazer1981 |
 Posted: 17:52 - 10 Nov 2008 Post subject: |
| satelliteone |
| frazer1981 |
 Posted: 20:15 - 10 Feb 2009 Post subject: |
Quick update..
Today after not much activity on the bike i managed to get the engine out of the frame. One of the nuts on the middle engine mount was mullered so thinking somebody else has had the engine out at some time in the past. Enigne out shock off as well. Have made a list of what needs doing and what i need to get.
Short list below
1, Complete engine gasket set
2, Swing arm bearings and seals (full set)
3, New or serviced rear shock.
4, Fork seals and oil and gators
5, New plastics maybe
I have also got a swing arm and a rear brake caliper from a 92 cr125 which will fit the mtx although looks like i may need to make some spacers and stuff, as i intend to make it a supermoto and can't do this with the drum brake set up on the orignal swing arm.
Also looking at a set of USD forks from the same cr125 the swing arm came from. Would i have to replace the whole front end for these to fit??
Couple of questions.
Can i use a heat gun to strip the paint or will this damage the frame?
Can i use a wire wheel in a drill to strip the frame paint if i cant use the heat gun or failing that some paint stripper ??? ____________________ 1st bike - chunlan starway 50QF4 (SOLD) 2nd bike - 92 Honda mtx125RW-L ( In my garage awaiting some TLC)
| ben350 |
 ben350 Trackday Trickster
| Fnatic |
 Fnatic World Chat Champion
| 400bandit |
 400bandit World Chat Champion
| element |
 element World Chat Champion
 Posted: 10:15 - 11 Feb 2009 Post subject: |
sandblast and powdercoat is £90 down here in plymouth and thats only an industrial finish aswell... ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| 0ddball |
 0ddball World Chat Champion
 Posted: 01:01 - 13 Feb 2009 Post subject: |
Ah so that's what it was. I had one of these when i was about 13 but it was a tatty hand painted field bike so i never knew what it was.  |
| ben350 |
| gwernybwch |
 gwernybwch Nova Slayer
| frazer1981 |
 Posted: 08:42 - 16 Sep 2009 Post subject: |
Quick up date on the project. Due to work comitments i have not had the time nor money to do anything to the bike, untill yesterday.
I have cleaned the frame down and the swing arm ready for stripping and painting. I took the head of as well yesterday to inspect the bore and piston and there is not a single mark on the bore or the piston. No side to side play on the conrod either.
The only problem i have is the forks. They are pretty much dead. The seals are errrrrrr....... well no seal at all will post pictures later.
Nearly every bearing in the rear suspension needs replacing along with the shock as well.
Will post some pictures when i get home from work. ____________________ 1st bike - chunlan starway 50QF4 (SOLD) 2nd bike - 92 Honda mtx125RW-L ( In my garage awaiting some TLC)
There is a gap of 3 years, 18 days between these two posts... |
| Benman |
 Benman Renault 5 Driver
| Hobgoblin |
 Hobgoblin Trackday Trickster
 Posted: 18:24 - 04 Oct 2012 Post subject: |
The last post was made 14 years, 16 days ago. Instead of replying here, would creating a new thread be more useful? |
