| instigator |
 instigator Super Spammer
 Posted: 20:38 - 06 Jul 2008 Post subject: Replacement HISS key - cheapest method..? |
Unfortunately the server was too busy to search for previous posts covering this topic, which I presume there are many of.
I only have one key for my RRY blade and I don't particularly feel comfortable only having one. So I can get the spare Honda Key for about £10-17 posted. Does anyone have an idea on how much it costs to get the key programmed to the bikes ecu? I live in central London if it helps.
Presumeably Honda won't cut the key either so I'd have to get a keysmith to do that. |
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 21:23 - 06 Jul 2008 Post subject: |
Good timing on this question...
I've got a key blank on it's way to me from David Silvers. There's a locksmiths literally around the corner from me, so going to get them to cut it for me.
Then will likely give george whites in swindon a ring about getting it programmed into the ECU.
Will let you know what i find out
PS. Will be a few weeks yet beore i'll be able to see them about gtting it programmed, but will let you know none th less. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| instigator |
There is a gap of 219 days between these two posts... |
| Noxious89123 |
 Posted: 00:05 - 12 Feb 2009 Post subject: |
Right, huge ressurection on this thread, but fuck it, why start a new one.
I've still got this spare key on my shelf, had it cut ages ago, but when I asked at a dealer about having it coded to the bike, he said he wanted the bike for a full day and £50! Fuck off I thought.
Well, just flicking through my haynes, and it tells you in detail how to do it yourself, and even gives the part # for the special honda tool. Had a quick look on david silvers, and I can get the tool for about £20!
Part # is 07XMZMBW0101 if anyone is interested to know. Just an fyi, the part my haynes lists is 07XMZMBW0100 but the part ending 1 supercedes it.
So before I order this thing and give it a go, would anyone else with a Honda be interested in having a key (or two) coded?
Would help me recoup the cost if a couple of people would want a key doing for the price of a few quid, and would obviously be useful to anyone else needing a key that doesn't want to pay stealership prices. I'm in Leicester, alhough am frequenly in Swindon too.
https://www.davidsilverspares.co.uk/parts/by-part-number/part_07XMZMBW0100/ ____________________
| GeneralXcepti... |
 GeneralXcepti... Nova Slayer
| Noxious89123 |
| Noxious89123 |
 Posted: 00:29 - 21 Feb 2009 Post subject: |
Well I've got the "fancy" tool. It's just a length of wire with a plug in connector in one end to connect to the bikes wiring, and the other end has two crocodile clips to attach to the battery.
Need to get the tank up to access the part of the wiring i need, so am going to change the plugs at the same time. Will let you know how it goes  ____________________
| Noxious89123 |
 Posted: 21:40 - 21 Mar 2009 Post subject: |
Done it! Was pretty easy too. Took a few attempts and a bit of puzzling. The HISS light didn't want to go blinky when it was meant to according to my book, but a bit of trial and error and eventually it did it's thing properly  ____________________
There is a gap of 2 years, 59 days between these two posts... |
| Garnsie |
 Garnsie Two Stroke Sniffer
 Posted: 19:04 - 20 May 2011 Post subject: HISS system special tool?? |
| whitedevil |
 whitedevil World Chat Champion
| Chriss |
 Chriss World Chat Champion
| Ditto |
 Ditto Nearly there...
 Posted: 20:50 - 27 Jul 2011 Post subject: |
Sorry for the bump but I didnt see any point starting a new thread.
I need to get a copy key, ill be buggered if i loose my only one.
Is it just a case of getting on of these:
https://www.davidsilverspares.co.uk/CBR600FY-2000/part_59484/
Getting it cut at a locksmiths, then getting it programmed at a dealer/with that tool?
How much does a dealer charge?
Cheers! ____________________ CG 125 > Bandit 600 > CBR 600 FY > Street Triple R |
The last post was made 15 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
