Pinlock Inserts
pyx_e
PostPosted: 20:41 - 13 Feb 2009    Post subject: Pinlock Inserts Reply with quote
Anyone use the tinted inserts? (Dark, yellow, amber) If so why?
I like the idea of the amber one (for day time) to cut down glare but why have yellow AND amber. Anyone know what the thinking is?
Shiney!
Kawasaki: ER5, Versys, VN900.
Bikeless
PostPosted: 20:43 - 13 Feb 2009    Post subject: Reply with quote
Isn't yellow for better vision in the wet?
iooi
PostPosted: 20:50 - 13 Feb 2009    Post subject: Reply with quote
Yellow or at least certain tints of yellow increase contrast, thus making it easier to spot things.
Method
PostPosted: 10:00 - 14 Feb 2009    Post subject: Reply with quote
Amber is for low sun days to cut the glare as much as possible.
Yellow is actually High Definition Yellow and is designed for dull and gloomy days. The HD Yellow insert effectively drags out the edges and details of your surroundings better, allowing you to see more clearly.
Next time your in a shop, hold them both up infront of you and you will notice the difference Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Louise
PostPosted: 21:15 - 14 Feb 2009    Post subject: Reply with quote
I have tinted and clear.
Clear for nights, dark for days - However my iridum isnt pinlock ready so need to drill.
The dark helps a lot on sunny days.
Method
PostPosted: 11:15 - 15 Feb 2009    Post subject: Reply with quote
Also - it is also worth thinking about what type of insert would suit you better.
If you ride an upright, traditional style bike, then the standard pinlock insert will be perfect.
However, if you ride a sports bike, where you are leant forward, you may want to ask about "High Rise" / "Race" inserts. These inserts cover a larger area of the visor, extending to the top of the visor rather than stopping a little below. This isnt realy needed on taller bikes, but when your leaning forward it can realy help. When leaning forward you tend to look through a different point of your visor, nearer the top - as your head is tilted as such. With a standard insert, you can end up staring straight through the top of the insert, where as the race insert will allow you to look where you normally look, and still cover your vision patch with the insert.
Standard: https://www.newenough.com/image/path/7076/thumb/Default.jpg Race: https://www.feridax.com/graphics_cache/c5/70/02f72a0f8866473499bd7bb71dc3.jpg?o=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
krebsy
PostPosted: 15:43 - 16 Feb 2009    Post subject: Reply with quote
Had a reactive one in the old lid that took a lot of the glare out. Yellow/orange ones are like ski goggles as they'll cut out the glare.
Anyone got a plarised filter? Just got the new shoei XR lid and came with a plain visor, and bought a tinted one as well. The best sunglasses I ever had were not particularly dark but polarised, so if there's an insert that'll do the same then I'm all up for one.. Smile
K.
Oh, got a spare arai condor visor (with plain insert) if anyone wants it. Pulled it off my trashed lid after scudding the back of it on the road. Perfect condition and only had 3 days usage...
1280 x 1024.
Tonka
PostPosted: 16:42 - 16 Feb 2009    Post subject: Reply with quote
I have a dark pinlock insert that I use in my clear visor on a sunny day as sometimes I can't be bothered to carry my tinted and clear visor and I know I'll be riding home in the dark - that's all! Rolling Eyes
pyx_e
PostPosted: 18:30 - 16 Feb 2009    Post subject: Reply with quote
Got a standard yellow one (upright bike), will let you know how it goes when I fit it and wear it a bit.
Shiney!
Kris
PostPosted: 23:34 - 16 Feb 2009    Post subject: Reply with quote
I can't offer advice on the Pinlock branded yellow inserts but I did use a FogCity High Definition yellow insert on my old Shoei helmet for commuting one winter.
During dusk and dawn it does make a slight difference and made the gloomy surroundings much brighter and easier to pick out other vehicles and cyclists etc, although I actually found it a hinderance during normal daylight on bright days - I just couldn't adapt and found myself opening the visor at every opportunity. To be fair, I tend to do that anyway but with a clear visor I am less likely to have to lift it up in heavy rain.
So a general Thumbs Up from me regarding gloomy conditions and transitional periods of low light but a Thumbs Down in normal conditions.
HTH Mr. Green
www.prisonplanet.com
DidierD
PostPosted: 00:44 - 17 Feb 2009    Post subject: Reply with quote
I've got a tinted one on my Arai condor and it works brilliantly ... well it used to. I've taken it out a few times though to clean it and it doesn't seem to quite bend or stick around it's bottom edge now, so it does steam up a bit around the bottom when it's particularly wet or cold.
So my advice is get one but don't take it out too often, if at all, if you can help it.
Bike - '98 Yamaha YZF600 Thundercat Pics
31st March 2008 - Fully converted from four wheels to 2 sets of two wheels Very Happy
MinhDinh
PostPosted: 00:50 - 17 Feb 2009    Post subject: Reply with quote
I have amber and it is pretty good at night and day time when you get use to it. However, I find the glare is still pretty bad when the sun is on you. Polarised lenses are the only things for glare really, but i hate specs.
The clear is great imo. It's really nice to see clearly at night with true colours instead of an amber tone everywhere.
Hit the G spot. Wink
The last post was made 17 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.69 - MySQL Queries: 13 - Page Size: 76.92 Kb
