Riding on slippery surfaces - center of gravity
Cigaro
PostPosted: 15:16 - 12 Feb 2009    Post subject: Riding on slippery surfaces - center of gravity Reply with quote
Why are MX bikes always very high up? I would have thought that for riding on slippery and loose surfaces, you want exactly the opposite - a low center of gravity?
The Artist
PostPosted: 15:24 - 12 Feb 2009    Post subject: Reply with quote
You also want good ground clearance, soft suspension so you have more travel without hitting anything. Engine is lowest it can be, really. Only really heavy thing up top is you...
PostPosted: 17:17 - 12 Feb 2009    Post subject: Re: Riding on slippery surfaces - center of gravity Reply with quote
OK I'll limit my Pampera's suspension travel to 2in at the top of its range and see how you do riding off road! :p Smile
iooi
PostPosted: 19:45 - 13 Feb 2009    Post subject: Reply with quote
Which is why to get the best out of one, you stand up to give your center of gravity chance to over come the bikes.
Because you have a higher center of gravity you have a greater range of movement before you get to the point of no return, which makes then easier to control by body lean to counteract the bikes movement.
The other thing is wider bars and lightness make then easier to handle on slippery surfaces.
colin1
Captain Safety
PostPosted: 00:18 - 15 Feb 2009    Post subject: Re: Riding on slippery surfaces - center of gravity Reply with quote
you do get grass track speedway bikes that have low clearance, and they are designed for low centre of gravity
The last post was made 17 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 43.81 Kb
