help
David
PostPosted: 10:59 - 14 May 2004    Post subject: help Reply with quote
hey everybody would you please tel what the importance of an air screw is and how the hell it works! thanks
David
sv_cath
PostPosted: 11:02 - 14 May 2004    Post subject: Reply with quote
Basically, you need 3 things for combustion - fuel, air and spark. These can all be adjusted to get just the right mix for the engine to fire efficiently (more or less fuel and air, and different heat spark plugs).
Best bet is to refer to your friendly Haynes manual for your bike to see how to set them up.
Hope that helps,
Cath
David
PostPosted: 11:05 - 14 May 2004    Post subject: Reply with quote
cheers mate .see the thing is i bought the bike second hand and the air screw was screwed the entire way in and it was not running properly so we bored it out and put a new one in and it seems to run a bit better
David
PostPosted: 20:30 - 14 May 2004    Post subject: Reply with quote
It is easy to bugger up a carb with the needle screw, and someone tightening it right in hard in the past could well damage it.
Anyway, there is this on carbs in the FAQ section:-
https://www.bikechatforums.com/viewtopic.php?t=17124
The last post was made 22 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 39.5 Kb
