| tommybhoy |
 tommybhoy Spanner Monkey
| Itchy |
 Itchy Super Spammer
 Posted: 00:11 - 17 Feb 2009 Post subject: |
I've got a Scotoiler , the non computerised one , it runs of a vacuum line to the carb so only oils when the engine is on.
It works , but since I only have a single sided oiler only one side of the chain is lubed and kept clean. So a double sided oiler is recommended. I have also modded mine to have a super 500ml endurance tank for free if you click my Spain2008 tour link in my sig.
You do have to set them fairly high though as below setting 5 the chain stays somewhat dirty, above 5 the chain is a fair bit cleaner and you can see it 'shinier' due to the wetness.
I keep the scotoiler itself under the seat and have the tube come out between the tail pod , new they cost about £55.
The alternatives are the loobman which is a manual one you need to press everynow and again and John's scat oiler which is just a hamster water bottle thing with a hole in the top, where you open the hole to allow the oil to escape which is a helluva lot cheaper. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| MarJay |
 MarJay But it's British!
| scream aim fire |
 scream aim fire Scooby Slapper
 Posted: 17:01 - 17 Feb 2009 Post subject: |
can't you just use some of THIS STUFF ?
and spray it on say once a week?
edit: just read bendys thread at the top...shuts me up, gonna have to give my chain a clean tomorrow lol ____________________ CBT PASSED 18/01/09 THEORY PASSED 14/04/09 DAS PASSED 17/04/09 3 minors wet test.
Bikes: 2009 Aprilia RS125 (PX'D) - A1P ZX6R - Stolen -Triumph Daytona 600 -wrote off via BMW
Current bike: P7F ZX6R
| MarJay |
| LeeR |
 LeeR World Chat Champion
 Posted: 19:08 - 17 Feb 2009 Post subject: |
I used to use a TUTORO which was cheap and effective, though I secretly hankered after a Scottoiler.
I recently got a bargain off eBay a MK7 Universal Scottoiler (NIB) £40 and it's awesome though, so I passed the Tutoro on to beatnck2.
It's worth having a look on eBay now and again as they sometimes crop-up cheap like that.  ____________________ My claim to fame: Austin Vince nicked my pen... |
| neatbik |
 neatbik World Chat Champion
 Posted: 21:58 - 17 Feb 2009 Post subject: |
And much appreciated it is too Lee
I still havent had a chance to fit it, hopefully i'll do it within the next couple of days so i can enjoy a well lubed clean chain  |
| loply |
 loply World Chat Champion
 Posted: 22:12 - 17 Feb 2009 Post subject: |
I got something like this (but a lot smaller) from B&Q for about 49p:
https://www.aquatics.co.uk/prodimages/small/woaac014s.jpg
And plugged it into the end of my single sided scottoiler.
It was spot-on the right size and now drips oil skilfully onto both edges of the chain.
I set it with the nozzle about an inch or two in front of the bottom of the rear sprocket. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Itchy |
 Itchy Super Spammer
 Posted: 22:16 - 17 Feb 2009 Post subject: |
| loply wrote: | I got something like this (but a lot smaller) from B&Q for about 49p:
I set it with the nozzle about an inch or two in front of the bottom of the rear sprocket. |
I was going to make one myself out of tubes but couldn't be bothered care to show us a close up picture of that on your bike? , as I noticed the innerside was fairly rusted and dry while the outside was fine. (I assume you need two pipes to connect to the end of thatso it actually goes onto the sprocket right?). ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 22:50 - 17 Feb 2009 Post subject: |
Although the scottoiler people say that it'll oil both sides of the chain by "capilary action", it does infact only oil one side. By the time you've got the flow high enough for oil to make it onto the far side of the chain, it'll be flinging off all over the shop. I paid a little extra and got a "dual injector" fitted and it's been much better since. Takes alot of fiddling to get the nozzles sitting just right though! And keeping the nozzles clean is a must, else you'll end up with oil dripping from only one side. Easy to sort, just wipe any crud off the nozzle with a rag, put your finger over the other nozzle and wait until the now-unblocked nozzle starts dripping again.
They might be pricey, but they are waaaay superior to spray lube. Spray lube makes your chain get filthy really fast. Whereas with my scottoiler keeps the chain mostly clean. Still requires cleaning every now and again though. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| tommybhoy |
| G |
 G The Voice of Reason
| alun111 |
 alun111 World Chat Champion
 Posted: 01:17 - 18 Feb 2009 Post subject: |
I actually came up with the same idea a couple of months ago when I realised I really wanted/needed a dual injector... but didn't want to pay £20+ for one.
I started making one today after my mate found a suitable 'Y' connector...
All I have to do now is connect it to the delivery tubing on the bike, cable tie it to the swingarm (or whatever), and snip the ends of the black tubing to an angle to sit on the sprocket. There's actually enough give where the two ends cross over to ease them apart and it should fit over the front of the rear sprocket easily and then spring back to give a tight fit. It took all of about 10 minutes to make, a 'Y' connector, a lighter (to mushroom the ends of the black tubing and widen the clear tubing), and the box of scottoiler bits to scavenge from.
Here's a pic:
https://i83.photobucket.com/albums/j319/alun111/18022009036.jpg
PS. If anyone has any ideas for a DIY lube tube - send them this way! ____________________ Summer: '00 Honda CB600F Hornet
Past Bikes: Lifan LF100-5 Lifan LF125-A Honda C70 |
| MarJay |
| Itchy |
 Itchy Super Spammer
 Posted: 11:06 - 18 Feb 2009 Post subject: |
actually in the scotoiler box comes a T junction , I've been thinking of bodging that but its not as good as a Y junction as you need to bend the tubes back much farther. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| G |
| krebsy |
 krebsy World Chat Champion
| tommybhoy |
 Posted: 12:05 - 20 Feb 2009 Post subject: |
I know its a saying never enough oil on your chain,but what concerns me is the access oil.I park my bike in my driveway to the side of the house which is all monoblocked and of course i dont want the other booting my balls  ____________________ Current bike..Honda VFR 800 Vtec
A billion seconds ago it was 1959. |
| Noxious89123 |
 Posted: 21:42 - 20 Feb 2009 Post subject: |
They don't drip oil unless they are running or you've really over-oiled it by having the flow set to high. ____________________
| tommybhoy |
| LeeR |
 Posted: 19:11 - 22 Feb 2009 Post subject: |
I found the Tutoro okay, to be fair for £15 it's a well made piece of kit and the designer/seller clearly cares about the product and isn't seeking to rip us off.
The practicalities of using it are as you suspect, as it is a gravity fed system you will have to turn it off when you leave the bike parked. Yes it will continue to drip and if you have the flow valve open too much you will end up with a puddle.
Also you do get a fair bit of fling, so you will probably get oil on your rear wheel. Personally I found it something I could live with as I'd been using 10w40 engine on my chain for a year or so.
After rain or washing the bike I found it useful to brush on some extra oil just to give the oiler a hand, as it were.
Benefits wise I thought it was doing the job as, the chain ran much quieter, seemed much smoother, and for the couple of months I used it, it may have improved my mpg by around 2% i.e. from 46mpg to 47mpg but that could have been down to warmer weather, etc...
Would I buy one again? Yes - especially as the Scottoiler MK7 has been replaced by the 'V' series oiler @ £84.50 (and I can see no difference).
Do I prefer the Mk7 Scottoiler? Yes - because I'm lazy and forgetful, and only have to fill it up weekly and don't have to remember to turn it off.
I do think the Tutoro is slightly better than the competition though as is more economically priced, and if you remember to turn it on, it just gets on with it, unlike the others that you have to squeeze before setting off. As my commute is 40 miles each way I doubt a squeeze in wet weather would be any better than brushing oil on at the start of the day.
Hope this helps  ____________________ My claim to fame: Austin Vince nicked my pen...
| tommybhoy |
| Villers |
 Villers World Chat Champion
 Posted: 19:46 - 22 Feb 2009 Post subject: |
Ive had the scottoilers on 2 of my bikes. Ive found them so far to be messy and unreliable. Note that Ive never bought one myself, just inherited it with the bike. For me Id rather be in charge of how the chain is lubed, and I couldnt give a shit if it gets me an extra 2k out of a chain by using one. My experience has shown me that the scottoiler is not only untrustworthy but it has poor self discipline and low life goals. The one on my busa worked fine for a bit and it came with a payload full of oil. All was well for about a month then one morning I came to the bike to find it had pissed the oil all over the garage floor. Why would I want something that could do that hovering next to my back tyre?  ____________________ RS125 > CBR6 > SV650S > ZX636R > GSX1300RZ Hayabusa > 06 RSVR Mille > SV1000S > Street Triple 765 RS |
| MarJay |
| alone |
 alone Traffic Copper
The last post was made 16 years, 197 days ago. Instead of replying here, would creating a new thread be more useful? |
