DIY Question here
 Topic moved: from Random Banter to Dear Auntie BCF... by G (18 Feb 2009 - 19:46)
binge
Emo Kiddy
PostPosted: 20:48 - 17 Feb 2009    Post subject: DIY Question here Reply with quote
I need to change the silicone around my bath because its starting to split and let water through.
I've done it before no problems, But I always make a right mess when doing it.
Any tips or ways of doing it easily and neatly?
Ben
McGee
O RLY?
PostPosted: 20:51 - 17 Feb 2009    Post subject: Reply with quote
Buy one of those scrapers/edgers made for it, just pipe the stuff on and run it along the edges, makes it nice and clean.
Failing that cut a piece of card and use that.
Its pronounced Jixxer!
swampy
PostPosted: 20:56 - 17 Feb 2009    Post subject: Reply with quote
Run two bits of masking tape, one on the wall the other on the bath with a small gap between them. Then run the silicone in the gap, smooth it down with your finger and remove the tape... Thumbs Up
Bikeless
PostPosted: 21:07 - 17 Feb 2009    Post subject: Reply with quote
As above, Thumbs Up
pyx_e
PostPosted: 21:08 - 17 Feb 2009    Post subject: Reply with quote
As above and:
1/make sure you clean off ALL the old stuff and then wipe the area down with diluted bleach (to kill bacteria that make it go black or you are just sealing them in their new home)
2/ If possible fill the bath with cold water. They do move with weight and if you do this you will get a better seal. Leave the water in for 12 hours to let the seal go off a bit.
3/ don't try and seal it in one go. Do a small filling run right in the crack and leave for an hour or so (force in with finger as below). Then do the final run onto a consistent angle.
4/ Stick your finger in your gob (so it's wet) and run it down the silicone (have a damp cloth in the other hand to wipe off excess and keep it damp) this give a concave curve and forces the sealant into the angle. Don't push too hard just enough to get a nice curve.
Shiney!
Kawasaki: ER5, Versys, VN900.
Bikeless
PostPosted: 21:29 - 17 Feb 2009    Post subject: Reply with quote
Also bathroom sealant is better than silicone as it has mould inhibitors and tends not to shrink as much as silicone.
Wave2k
G's Stalker
PostPosted: 21:40 - 17 Feb 2009    Post subject: Reply with quote
if you are gonna use the finger and masking tape way, make sure you lick or wet your finger a little, its hard enough to get off your hands.
Ducati 1299 Panigale
2009 Corvette C6 z51
pablouk
PostPosted: 21:54 - 17 Feb 2009    Post subject: Reply with quote
Yeah, dip your finger in some water before you run your finger along it each time, it leaves a nice smooth finish.
Keeping The Nation Pissed
Do not anticipate trouble or worry about what may never happen. Keep in the sunlight. ~Benjamin Franklin
K0rnIsAFAGGOT This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Quote Me Happy
PostPosted: 23:03 - 17 Feb 2009    Post subject: Reply with quote
Lick your finger first.
Misc
PostPosted: 23:05 - 17 Feb 2009    Post subject: Reply with quote
Make sure your finger is wet before you begin.
Tonka
PostPosted: 23:07 - 17 Feb 2009    Post subject: Reply with quote
........don't lick your finger during or after tho' Sick Wink
binge
Emo Kiddy
PostPosted: 23:38 - 17 Feb 2009    Post subject: Reply with quote
Any particular Wetness of the finger?
Or just wet.
Ben
MarkJ
PostPosted: 23:44 - 17 Feb 2009    Post subject: Reply with quote
If you can, fill the bath full of water, then put on the new sealant. This pushes the bath down a bit (which will happen when you have a bath or shower) and stops the sealant coming loose when you have baths and showers. Only drain the water once the sealant has set.
The Tot
PostPosted: 23:48 - 17 Feb 2009    Post subject: Reply with quote
Wetness is defined by how much water can be held on by the surface tension of your hand.
As everybody said, lick your finger first. If the sealant does get stuck, then you can wipe off any excess in roxannes ears/noes/eyes and just LOL in her face and say to her that women are useless at DIY.
Never argue with autism
swampy
PostPosted: 00:15 - 18 Feb 2009    Post subject: Reply with quote
Alternatively you could wear a pair of gloves and wet the finger on these. However I suggest you man up and go bareback Very Happy
mad4it028
PostPosted: 00:21 - 18 Feb 2009    Post subject: Reply with quote
rather than wetting your finger use washing up liquid on your finger kinda lubes it as you go for a better finish wait till its dry then rinse the soap off
Robby
Dirty Old Man
PostPosted: 00:25 - 18 Feb 2009    Post subject: Reply with quote
Make sure you put some washing up liquid on your finger.
Catalyst
PostPosted: 00:40 - 18 Feb 2009    Post subject: Reply with quote
Don't forget to put washing up liquid on your finger Thumbs Up .
|--Previous--|:2007 Aprilia SX50...Neutral--Current--|: 2007 Kawasaki ER-6N
SlimRick - I can cook really well - but it's a useless skill, as I'm not a woman and it's their fucking job!
binge
Emo Kiddy
PostPosted: 01:13 - 18 Feb 2009    Post subject: Reply with quote
Any particular brand?
I dont want to dis-colour the Silicone thats all.
Ben
DEN MONKEY
PostPosted: 07:13 - 18 Feb 2009    Post subject: Reply with quote
Ben
You mean your own spit or someone else's.
Personally I'd suggest sticking your grubby finger in someone else's mouth, even more so if you need to re-moisten it mid way through the job.
Not sure how it tastes but best to avoid finding out I'd say Thumbs Up
meh
binge
Emo Kiddy
PostPosted: 20:03 - 18 Feb 2009    Post subject: Reply with quote
No I was on about the washing up liquid.
Ben
Dischord
PostPosted: 20:20 - 18 Feb 2009    Post subject: Reply with quote
whats the point in wetting/lubing your finger?
2012 KTM EXC 250
tutton
PostPosted: 15:08 - 19 Feb 2009    Post subject: Reply with quote
O yeah and one more thing remember to wet your finger!
its so the sealer stuff dosnt stick to your hands dumbie.
lozzypop1
Certified MILF!
PostPosted: 04:34 - 20 Feb 2009    Post subject: Reply with quote
Ben
Use window cleaner.
The last post was made 17 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.19 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 124.58 Kb
