4 days into the build of my shed
PostPosted: 17:29 - 21 Feb 2009    Post subject: 4 days into the build of my shed Reply with quote
Obviously not finished yet,but it's the first shed i've built and i'm more than happy with it.
Still got to felt the roof (although i've got waterproof paint on it for now) and put the floor down aswell as loads of other bits and pieces but that'll come eventually.
https://i187.photobucket.com/albums/x13/fronterapics/DSC00103-1.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DSC00102.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DSC00104.jpg
Far from profesional i know,but it'll do the job Very Happy
Probably not the kind of thing anyone on here is interested in but i thought i'd put it up
DRZ-400sm
PostPosted: 17:34 - 21 Feb 2009    Post subject: Reply with quote
How could anyone not be interested? It's a shed. Sheds are blokespace. Anyone not interested in blokespace is either gay or female, and as such, not qualified to express an opinion on blokespace.
PostPosted: 17:35 - 21 Feb 2009    Post subject: Reply with quote
Laughing Thumbs Up
DRZ-400sm
PostPosted: 17:41 - 21 Feb 2009    Post subject: Reply with quote
So far i have:
compressor
arc welder
m.i.g. welder
engineering vice
bench grinder
loads of polishing gear
oxy acet bottles
3 full tool boxes (pretty much everything i could need)
motorbike lift
Woodwork vice and lots of woodwork tools
radio
lighting
calor gas heater
Aswell as loads of other bit's and pieces to go in.
I should'ave built it bigger Smile
DRZ-400sm
steppen22
PostPosted: 18:21 - 21 Feb 2009    Post subject: Reply with quote
For a first go, it's pretty good.
|Don't forget security though: alarms etc.
Also what about electricity - believe me, makes sheds so much more functional if you can thrwo a microwave in there, maybe even a tv.
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
PostPosted: 18:32 - 21 Feb 2009    Post subject: Reply with quote
Although anyone who wants to get into a shed could do with a hacksaw bl;ade.
Cheers Smile
Every joint including the full floor joists are half lapped which took AGES doing them with a hack saw and chisels but i got sick of that and just done butt joints on the roof joists.(probably should have half lapped the roof but it's tiring work)
Security's not really a problem but i'll have some decent locks on the doors.
The boards are just 11mm osb so it wouldn't be that hard to push your way through them.The 8x4 sheets of ply was going to cost £25 per sheet and i ccouldn'treally afford that.(Will be using that for the floor though)
The only thing i'm a bit worried about is the lean angle for the water run-off.The front is 8ft high sloping to 7ft at the back.I hope that's enough.
I also ddidn'tget any planning permission so i'm hoping i dont get into trouble for that,but i doubt it.I built the whole thing in sections so it would be fairly easy to pull down if i had to.
I'll get a few more pics up tomorrow.
EDIT:
I'll have to have electric in there anyway for all my tools and lights.
DRZ-400sm
PostPosted: 19:43 - 21 Feb 2009    Post subject: Reply with quote
In regards to planning permission, I'm sure I read somewhere once that as long as it is no taller and no closer to the road than the main building on the property, you won't need planning permission. I'm probably very very wrong though.
Flip
PostPosted: 19:48 - 21 Feb 2009    Post subject: Reply with quote
I have shed too.
I love shed.
Bikeless
PostPosted: 20:09 - 21 Feb 2009    Post subject: Reply with quote
I used waxoyl(the stuff you underseal cars with)on the roof of my shed before fitting the felt,makes it water tight.
mooserx
PostPosted: 21:05 - 21 Feb 2009    Post subject: Reply with quote
i have a shed, it's ace except for a leaky roof which needs fixing, it also needs moving from the centre of the garden to the back of the garden, it's a bit like a centrepiece at the mo, but it's excellent, my wife is not allowed in my shed, i am man, i have shed rrrrrrooooooaaaaarrrrrrrr!!!!!!!!!! Thumbs Up
TL1000r-handful.
KevTM
PostPosted: 21:10 - 21 Feb 2009    Post subject: Reply with quote
The easy route eh..
I spent a couple of days laying a base, shoveling like mad into the wee mixer, but I'm glad a proper base is built under the actual wood floors etc.
Only problem is, once it's done and you get your stuff in, then your bikes, then you want to work on them you end up thinking.. extension. Laughing
MinhDinh
PostPosted: 21:24 - 21 Feb 2009    Post subject: Reply with quote
Did it cost as much as a already made shed then?
Hit the G spot. Wink
Phoenix
Twisted Firestarter
PostPosted: 21:34 - 21 Feb 2009    Post subject: Reply with quote
Whether or not something needs planning permission is also down to how far away from the house it is I believe, size also comes into it, lots of rules on it, I think Mrs Kickstart deals with that sort of stuff.
It looks like it fills your garden fence to fence? With a flat roof, if the water does drain off it's gonna go everywhere including all over your neighbours gardens, I'm fairly sure you should be required to make the water drain into your own. Without a better view it also looks pretty large and ugly, sticking up over all fences so not sure your neighbours will be too impressed.
PostPosted: 22:00 - 21 Feb 2009    Post subject: Reply with quote
So far it's cost me about £250 but will be another £100 or so by the time i get the flooring down.
If i bought a ready built type one from B&Q would probably have cost a lot more and would have been a lot smaller so building one myself was the only option really.(and it's fun Very Happy )
Due to the size of my garden i had to put it fence to fence to make full use of the space.
The roof slopes down to the rear slightly and there is a 1ft gap at the rear so any water would end up in my own garden.
I'll take a pic of it from the back door so you can see what it looks like properly.It is quite close to my neighbour to the right's kitchen window,but they are fine about it.
Most other neighbours around me have big shed's in their gardens aswell so it's no big deal to them.(plus i live in a shitty council estate that no one cares about anyway)
DRZ-400sm
Nb
PostPosted: 11:22 - 22 Feb 2009    Post subject: Reply with quote
Nice looking shed, looks much larger than mine. Crying or Very sad Heres a couple of pics of mine Laughing Got a heater in there and a floodlight too. Cool
https://img.photobucket.com/albums/v678/blazebrown/04112007143.jpg
https://img.photobucket.com/albums/v678/blazebrown/13112007144.jpg
SlimRick
PostPosted: 11:24 - 22 Feb 2009    Post subject: Reply with quote
Sheds are beautiful things! I'm assuming you'll have a porn wall?
jack_zxr400
PostPosted: 11:46 - 22 Feb 2009    Post subject: Reply with quote
oooo nice shed Very Happy
i wana build one!
aint it guna be cold in there tho?
put a sofa in there Mr. Green
and yea, alarms, cameras or whatever for security Thumbs Up
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
pablouk
PostPosted: 12:03 - 22 Feb 2009    Post subject: Reply with quote
Yay!! Gotta love a shed/cave!!
It will end up costing more than a pre-build 'cos its your project, and you will do more and more.... Very Happy
If you gonna spend any sort of extended time in there, its worth puting in some cheap insulation and then line it. You will lose about 2" all the way round, and it will be a little extra cost and time, but it will make the WORLD of difference Very Happy Very Happy
Man no like cold cave, must be warm, then spend too much time in there and end up having domestics with 'one who make food'...ugg,ugg.
Keeping The Nation Pissed
Do not anticipate trouble or worry about what may never happen. Keep in the sunlight. ~Benjamin Franklin
strag
PostPosted: 13:38 - 22 Feb 2009    Post subject: Reply with quote
You don't need planning permission for a shed. Did you use marine ply? What are you going to cover the outside in? A 12inch fall is more than enough for water to drain off.
carbon bling
The Original Muzza
PostPosted: 13:52 - 22 Feb 2009    Post subject: Reply with quote
Damn I want to build a second shed now I've seen this.
Current one is only 6' x 8' and has my Triumph, filing cabinet, lawnmower, small collection of my dad's tools I nicked from my mum's shed (like her or my effeminate brother will use 'em), bicycle, and large box full of stuff for the rabbit Smile
Now I need shed to stick all that crap, sans the triumph, so I can have a bike shed devoted to tinkering etc. *grunts*
PostPosted: 15:55 - 22 Feb 2009    Post subject: Reply with quote
*Pics removed*
Nice Thumbs Up definitely looks a bit smaller,but i WILL spend a lot of time in mine,and use it as a workshop Laughing
The other half would kill me! so unfortunately not Crying or Very sad
Security's not really a problem so i'm fine there,and once i get the calor gas heater on the go it should be toasty warm Very Happy
No doubt.
Insulation might be a little over the top though
I was told that anything over 6ft needs planning permission,but i'll just see how it goes.
I just used 11mm osb but will use some heavy duty ply for the base Thumbs Up
DRZ-400sm
PostPosted: 15:57 - 22 Feb 2009    Post subject: Reply with quote
Ha ha.I went to price up the roofing felt today and forgot to take my disk lock off when i left Laughing
Ended up with the bike on top of me and petrol pissing all over my legs Embarassed Then had to spend half an hour trying to remove the gear shifter to straighten it up Embarassed .Give up in the end and just rode home in 3rd gear.
How embarrassing Very Happy
DRZ-400sm
Im-a-Ridah
PostPosted: 16:00 - 22 Feb 2009    Post subject: Reply with quote
I hope you're going to paint that with some decent stuff Smile
The shed here is made of blocks Smile
S1KE
PostPosted: 16:05 - 22 Feb 2009    Post subject: Reply with quote
you dont need planning permission for a shed, you only need it for something if it is going to be permanent,
the garage my dad built up his garden is pre cast concrete and he didnt need planning permission for that Thumbs Up
is the floor gonna be stronger? just thinking if you put a bike in there it wont be to sturdy???
i need to sort my shed out, it needs pulling down there must be a few hundered monster spiders in there Laughing
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
strag
PostPosted: 16:19 - 22 Feb 2009    Post subject: Reply with quote
I need a new shed, can't be arsed to build one so I am going to get a metal shed
https://www.gardenbuildingsdirect.co.uk/Metal-Sheds/Yardmaster-GEYZ
carbon bling
The last post was made 17 years, 133 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 133.01 Kb
