spark plug life - 2T bikes
Mord
PostPosted: 21:32 - 21 Feb 2009    Post subject: spark plug life - 2T bikes Reply with quote
How often do you change your spark plugs?
I just changed one in my RS125 after 1600 miles and there is a HUGE improvement. The bike runs smoothly and quicker than ever really (tested on the same road as always).
Maybe because the old one looks like this.. Laughing
https://i244.photobucket.com/albums/gg19/Mordoklej/HPIM4873.jpg
I'm going to change spark plugs more often.
PostPosted: 21:49 - 21 Feb 2009    Post subject: Reply with quote
You could use that plug again. Just needs a clean.
Mord
PostPosted: 22:00 - 21 Feb 2009    Post subject: Reply with quote
Yeah.. I'll use it next time. I need time to clean it Wink
tutton
PostPosted: 23:11 - 21 Feb 2009    Post subject: Reply with quote
Make sure the gaps right as well!
but depends on how your bikes running as to when they need to be changed, with my ill set up over fueling 50, although it sounded nice and was reasonably fast in terms of 50's, used to be every month or so itd need a new one Laughing
But with a standard bike with the jetting standard etc, i would hope for 6 months or more?
PostPosted: 23:24 - 21 Feb 2009    Post subject: Reply with quote
You can't really put it in terms of time, it has to be in terms of mileage. My TZR plugs have lasted over 11 years, but the engine has only been run for about 5 minutes during that time Laughing
I never removed the spark plug from my scooter and did 4,000km. I've no idea how long it had been in there. If it ain't broken, don't fix it Wink
PostPosted: 23:26 - 21 Feb 2009    Post subject: Reply with quote
Wouldn't expect it to be that bad after only 1600 miles. Maybe if you do a hell of a lot of low speed work. Is the bike restricted? Which plug have you got fitted?
Mord
PostPosted: 00:38 - 22 Feb 2009    Post subject: Reply with quote
It was BR8ES in restricted bike.. All 1600 miles in winter time which means choke a bit, warming up for a while (10 minutes or so in low revs), then riding like a granny (for another 10 lol).. then revving it a bit once it's warm enough. And I must add that first 600 miles the bike was in break-in period so I didn't rev it more than 6k.
I will see how it will be going now.. The weather is better now and no more breaking-in Smile
I'm surprised that with that plug the bike never failed to start.. it had the right to do so Wink
Less seriously.. On my favourite private road when I basically ride as fast as the bike can (which is obviously not fast Laughing) I remember just after run in period the bike was doing 83-85mph in one place (slightly down the hill in one place - sort of point of measurement of my bike condition lol).. Lately it hardly was reaching damn 80mph and acceleration was not so good so I was wondering why. Once I changed the plug on the same day I got 86mph there (never been that fast before lol).. WOOHOO Laughing Embarassed Laughing
Mord
PostPosted: 00:51 - 22 Feb 2009    Post subject: Reply with quote
Oh and by the way..
Are Iridium plugs better than standard BR8ES?
Manual says I can use BR10EG plugs in FP RS125. Can I use them in restricted bike too? I was reading about plugs and cooler ones seem to be safer for the engine Razz
PostPosted: 01:46 - 22 Feb 2009    Post subject: Reply with quote
No point using an iridium plug in a 2 stroke. As the plug you have just removed from your bike proves, it won't last long but costs 4 times as much.
You're best just fitting the recommended plug. If it was going to do any damage to the engine, Aprilia wouldn't have fitted it.
PostPosted: 10:06 - 22 Feb 2009    Post subject: Reply with quote
I 'd put a slightly hotter plug in that to see if it helps with the fouling. Try a 7 next time rather than a 8.
PostPosted: 20:35 - 22 Feb 2009    Post subject: Reply with quote
The higher the number with NGK plugs then the colder the plug. However a colder plug will foul up more easily at low revs.
Charlie
PostPosted: 20:39 - 22 Feb 2009    Post subject: Reply with quote
If you let your bike idle for a while then will get the fouling like that.
I am sure it wouldn't take long to clean, all you'd need is a wire brush.
PostPosted: 20:53 - 22 Feb 2009    Post subject: Reply with quote
No longer recommended, as it leaves traces of wire on the insulation allowing it to short out.
Don't leave the bike just idling to warm up for ages. Personally I start up and ride off immediatly (or as near as possible), just keep the revs down until warmed up.
Charlie
PostPosted: 21:03 - 22 Feb 2009    Post subject: Reply with quote
Didn't realise that... so what is recommended?
PostPosted: 21:11 - 22 Feb 2009    Post subject: Reply with quote
Just lob a new one in.
PostPosted: 21:26 - 22 Feb 2009    Post subject: Reply with quote
I've saved broken spark plugs with my Redex spark plug wire brush.
The last post was made 17 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 93.99 Kb
