Cruise Control
Bishbash
PostPosted: 11:38 - 23 Feb 2009    Post subject: Cruise Control Reply with quote
About 2 years ago my old man had a heart attack, then a triple heart bypass, he had veins taken out of his right arm and left leg. When riding long distances he finds it hard to hold the accelerator all the time. Obviously this is an issue.
Can you get cruise control added to a bike?
NSR Mick
PostPosted: 11:42 - 23 Feb 2009    Post subject: Reply with quote
Yes.
Clicky
Itchy
PostPosted: 11:43 - 23 Feb 2009    Post subject: Reply with quote
Yes you can, they are about £80 nearly fitted one to my CBR , its sort of like a normal throttle grip but with two switches on it that look like choke switches, you roll it to the desired throttle amount then lock it in place.
You then push the other switch thing and it releases it.
Ged doesn't trust them though as he said he had one lock up on him and his bike was revving away but then again this was one he made himself.
https://www.motorbike-search-engine-shop.co.uk/Shop/Miscellaneous.html
Bishbash
PostPosted: 11:55 - 23 Feb 2009    Post subject: Reply with quote
Super, thanks guys. Thumbs Up
Mr_T
PostPosted: 13:26 - 23 Feb 2009    Post subject: Reply with quote
How about a Scottoiler cramp-buster?
https://www.scottoiler.com/pc/Crampbuster_-_Standard.html
Bishbash
PostPosted: 13:39 - 23 Feb 2009    Post subject: Reply with quote
How is a scotoiler going to help? Confused
Matthie
PostPosted: 13:42 - 23 Feb 2009    Post subject: Reply with quote
Do not question Mr T.
It will help somehow.
multijoy
PostPosted: 14:01 - 23 Feb 2009    Post subject: Reply with quote
Possibly because it's a link to a throttle paddle wossname made by scottoiler?
Mr_T
PostPosted: 14:07 - 23 Feb 2009    Post subject: Reply with quote
mr_T wrote:
Note what's in the bold. I pity the fool that that doesn't read links that are posted in a thread to help.
virus
PostPosted: 14:30 - 23 Feb 2009    Post subject: Reply with quote
Ive got a cable tie in between the switchgear and the rubber off the grip and that works perfectly, Im not advocating it as a safe way of making a cruise control, but as a practice to see if he can get used to cruise control (its a bit wierd to get used to) then its worth a go.
John
own: 81 xs1100g...
Bishbash
PostPosted: 15:50 - 23 Feb 2009    Post subject: Reply with quote
mr_T wrote:
Cool, I just went and ordered him the cruise control, but thanks anyway. Thumbs Up
Peirre oBollox
PostPosted: 16:14 - 23 Feb 2009    Post subject: Reply with quote
S`pose its a bit late to mention THROTTLEMEISTER
its 1 of the best things I have on the bike atm, it looks just like an ordinary bar end weight but acts as a throttle stop
Kal
PostPosted: 16:30 - 23 Feb 2009    Post subject: Reply with quote
Honda Superdream cruise control...
Kal...
PostPosted: 18:03 - 23 Feb 2009    Post subject: Reply with quote
I have full cruise control on my wing. Used it a few times to see if it worked and to give my right hand a rest on motorways. In normal use I hate it, it has a life of its own. The bike accelerates and decelearates to keep the same speed when you go up or down hills or when the wind affects you etc, but its not smooth. If you have it set at 60 the bike will drop to 55 going up a hill, then suddenly surge forward then drop off the gas when it gets above 60. Sick
Very weird.
I suppose you would get used to it, or be able to fine tune it to smooth it out if you were reliant on it.
Triumph Trophy Launch Edition
Itchy
PostPosted: 18:11 - 23 Feb 2009    Post subject: Reply with quote
Its because you sub conciously 'trim' your throttle when going up and down hills to adjust the speed.
Peirre oBollox
PostPosted: 22:11 - 23 Feb 2009    Post subject: Reply with quote
Very weird.
although designed for a car, you can retro fit to a motorbike a similar system , such as Audiovox Cruise Control for around $100 plus shipping.
though AFAIK they work sightly better of you can fit a small vacumn bottle into the inlet curcuit, this eliminates the surging you discribe
The last post was made 17 years, 201 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 96.4 Kb
