| Visitor Q |
 Visitor Q $25 whore
 Posted: 23:59 - 23 Feb 2009 Post subject: Making your own manual CCT |
Right, in essence I think its safe to say the CBR has eaten another CCT.
Irritating, especially as I'm poor and David Silver spares wants 50 quid for a new one, and its only been about 10k since the last one.
I've just found out about manual ones, which is news to me as I assumed the camchain actually moved in and out and needed constant variance (ala pedal bike drive chains with that little tensioner behind the rear wheel gear stack).
Having remembered I had an old CCT lying about, and seeing just how simple the manual ones are (despite wanting £50 quid for them), I was wondering if anyone had considered machining their own? Or for that matter, converting the CCT body in to a manual one.
It's not as mad as it sounds, on the CBR one the top off the CCT when hollowed out has a ~6mm thread, and the actual rounded bit that contacts the blade/guide is encased within a sleeve that naturally fits within the CCT and is retained (regardless of spring).
So, if I were to source a long enough bolt and a nut that fitted it, and perhaps use a crush washer on the top (I have a spare CCT gasket kicking about too ) to be extra careful, I could have a rattle free life for sometime, for next to fuck all.
Thoughts? I do only have a rudimentary grasp of mechanics I'll be honest, but to me this seems very painfully obvious (especially given how shite Honda CCT's seem to be). ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 00:02 - 24 Feb 2009 Post subject: |
By the way, this is a manual jobby (as said, sold for £50 )
https://www.bigccracing.com/shopfiles/product/image259_big.jpg ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| chris-red |
 Posted: 00:12 - 24 Feb 2009 Post subject: |
The chain doesn't ride over the bolt - the bolt just presses on the back of the tensioner blade.
Making one of those would be very easy if you had the equipment. All they do is take a normal bolt and turn the head down on it, make a plate, tap it for the bolt, screw it through the plate and fit a nut which is pinned to the end of the bolt. Oil is kept in by a small o-ring on the bolt thread which seals on a countersink in the plate. The big trick is knowing how much tension to put on them. ____________________ a.k.a 'Geri'
| Visitor Q |
 Visitor Q $25 whore
 Posted: 00:16 - 24 Feb 2009 Post subject: |
| chris-red wrote: | I'd worry about the cam chain ripping the the top of the bolt off, you have to make sure it was strong enough for the job. Providing it doesn't leak oil I can't see why it wouldn't be fine. |
The bolt doesn't contact the camchain directly, it pushes in a guid/blade in the centre (which is hinged from one end) which applied pressure for it. And as said, theres a cap over the end of the bolt which is rounded and smoothed off.
I have three concerns;
One, that the thread in the CCT housing already would be too weak to cope.
Two, despite being under next to no oil pressure it might leak around the bolt unless I'm willing to put on a new crush washer every time I adjust it (although apparently thats not very often)
Three, due to being manual it would have no give at all, which may or may not be an issue (the sold products wouldn't either, and loads of people rate them so I doubt it).
It's probably use two nuts to lock it, cos I'm paranoid, but it could definitely work
Might be a clearance issue by adding an extra inch to the CCT though... I'd rather machine the old CCT down a bit, or make a new one, but thats mildly optimistic. ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Visitor Q |
 Visitor Q $25 whore
| mad4it028 |
 mad4it028 World Chat Champion
| Visitor Q |
 Visitor Q $25 whore
 Posted: 00:46 - 24 Feb 2009 Post subject: |
| Geri wrote: | | Quote: | I'd rather machine the old CCT down a bit, or make a new one, but thats mildly optimistic. |
Not optimistic at all. What you'd do is simply tap the tensioner for your bolt thread and machine a bolt to fit. Just find a bolt big enough, or bore the tensioner out and press-in a bush then drill & tap that. Easy job. |
Oh no, I know it is very doable. Would rather CNC it out of a slab of steel etc, but the old one could be done (although it does open out in to a large chamber which would need filling). I just lack the tools, parts and nouse.
I did think about wedging another spring in there as the original is piss weak. Just would be worried that I'd over do it
As mentioned, cbr 600's are just notorious. Mine is a 96, back when they still had the issue it seems. And as said, replacing the chain isn't necessarily going to sort it either. It still runs fine for now, but from last time I remember the rattle gets louder and louder until you eventually snap out of mechanical sympathy.
I heard a theory that it could be through leaving it on the side stand for long times (ie while travelling/uni ), which drains all the oil (CCT is on right), thus doing it no good when you start it dry...
Either, no rush now (famous last words).
Any tips for cheap places to get some bespoke machining? ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| virus |
 virus World Chat Champion
 Posted: 00:48 - 24 Feb 2009 Post subject: |
Getting it machined = yes, making one out of an old one = no.
Ill explain, the automatic CCT on my gpz failed when I was rebuilding the engine, now for those that arent familiar with kwak CCTs, its got a oil seal bolt on the end, then inside is a slot you put a screwdriver in to do your adjusting etc, me being a cheapskate decided to put a much longer bolt in place of the oil seal bolt, with a washer and 2 locknuts on.
All worked well until I fired it up the other day and the bolt dropped out of the CCT, turns out 4mm or so of thread on that oil seal bolt isnt up for the job.
so, your 2 best options are, get on ebay and find another cheap, or get it machined properly into a manual one.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| D O G |
 D O G World Chat Champion
| Visitor Q |
 Visitor Q $25 whore
| D O G |
 Posted: 07:39 - 24 Feb 2009 Post subject: |
| bonny_ricardo wrote: | | Damofo D.O.G. wrote: | I would try the spring mod as previously suggested (perhaps by a CCT from the breakers to modify), or wait a month and get a new genuine one. |
I have my old one still. God bless being a hoarder
Just try to think about tensions, like I say I could just ram a beast in there without causing excess wear to the tensioner blade/camchain  |
I doubt it.
The way to to tension a manual CCT is to screw the bolt in until you feel resistence, start the engine, and loosen until you hear the clatter, then tighten until it goes away, plus an extra 1/4 turn or so.
By putting a very strong spring in there you would no doubt over tension it.
If you have your old one, take it apart, and try and measure the stiffness of the spring by resting weights on it and measuring the squish. I'm sure you could then get a spring to fit with say 25% extra stiffness from a supplier. Hell, if you could get a range of tensions you could test them to find the optimum one, if you have the time and the inclination that is!! |
| Visitor Q |
 Visitor Q $25 whore
| iooi |
 iooi Super Spammer
The last post was made 17 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
