h100 wont start
cammy mack
PostPosted: 16:24 - 24 Feb 2009    Post subject: h100 wont start Reply with quote
hi all
ive just spent the last half hour trying to kick my h100 into life. with no result!. ive checked the spark, points and currently got the battery on charge. if that doesn't work, any ideas??
Yamaha Tdm850
Yamaha fz6
multijoy
PostPosted: 16:32 - 24 Feb 2009    Post subject: Reply with quote
Fuel tap and fuel (and then the related systems)? If it's sparking and the electrics check out, it's the obvious next step.
Tristan.
PostPosted: 16:41 - 24 Feb 2009    Post subject: Reply with quote
3 things needed to start a bike, spark, fuel and compression.
if it sparks then clean the plug and kick it over a couple times, whip the plug out it should be wet, if not that's your problem.
If the kicking over feels normal then compressions probably fine, you can do a pikey compression test by sticking your thumb over the hole and turning it over, the compression will be enough that your thumb gets blown off.
Check the air filter and exhaust arent blocked.
Chances are your carb is blocked, when you've done all the basic stuff then give it a clean.
When was it last used and how?
That won't work. The battery has nothing to do with the spark on an H100, they have a self-exciting ignition. It should start and run even with the battery disconected.
Checked the spark, so I assume there was a nice, fat blue spark? If in doubt, change the plug anyway.
After kicking it for half an hour there should be a strong smell of petrol and the end of the plug should be wet with fuel. Is it?
Has it been running recently or is this the first time you started it for a while?
lonner
PostPosted: 16:52 - 24 Feb 2009    Post subject: Reply with quote
hi m8
as above
when did it last run as this will help Question
cammy mack
PostPosted: 17:00 - 24 Feb 2009    Post subject: Reply with quote
the plug is wet so no probs there,its a new plug thats in it, it was out yesterday for about half an hour but before that it was off road for a few weeks. it has a tendency to start after a few kicks or not at all
Yamaha Tdm850
Yamaha fz6
cammy mack
PostPosted: 17:14 - 24 Feb 2009    Post subject: Reply with quote
if the carb is blocked is there any way to check without ripping the bastard off, will nip down and check the fuel pipe going into the carb. Thumbs Up
Yamaha Tdm850
Yamaha fz6
lonner
PostPosted: 17:18 - 24 Feb 2009    Post subject: Reply with quote
might be worth draining the float bowl as it might have some crap in it (little brass screw at the base of the carb)
cammy mack
PostPosted: 17:48 - 24 Feb 2009    Post subject: Reply with quote
just took it iff and examined it. bowl is fine as is the jets. maybe it just had some tiny piece of crap in it(hopefully)
Yamaha Tdm850
Yamaha fz6
cammy mack
PostPosted: 17:59 - 24 Feb 2009    Post subject: Reply with quote
hmmm put it back on bike and now petrol is pissing out the drainpipe! fucking bike!!! Middle Finger Middle Finger Middle Finger
Yamaha Tdm850
Yamaha fz6
Wil
PostPosted: 18:02 - 24 Feb 2009    Post subject: Reply with quote
Stuck float perhaps, causing the carbs to fill with fuel and then overflow?
'07 Triumph Speed Four
Aw look, a baby driving a car. And look, there's a dog driving a bus!
Tristan.
PostPosted: 18:06 - 24 Feb 2009    Post subject: Reply with quote
Probably, twat em with a nylon hammer or the rubber end of a ratchet.
cammy mack
PostPosted: 18:14 - 24 Feb 2009    Post subject: Reply with quote
you were right wil the bowl was full o fuel. will try and put it back on carefully Thumbs Up
Yamaha Tdm850
Yamaha fz6
PostPosted: 18:21 - 24 Feb 2009    Post subject: Reply with quote
If the jets are clean, fuel is getting through and it is making a spark, there is not much else it can be.
Maybe the spark isn't everything it might be. Check the plug cap is in good nick, check the coil is well earthed to the frame, check there is no muck on the connector.
Might also be worth giving the contact faces of the points a clean up with some fine emery paper or a points file.
If you are absolutely happy it is getting fuel and has a spark, maybe check the static timing, there is no seperate adjustment for this, you just set the gap and hope it is in the right ball park. A worn set of points with the correct gap leads to the ignition being too far advanced = Flying machine while running but utter bastard to start.
Points are a piece of piss to change BUT you do need a rotor puller. A genuine Honda rotor pulling tool costs about a tenner, don't even think about trying to do it without one, take it from me, it is simply not worth the hassle.
cammy mack
PostPosted: 18:48 - 24 Feb 2009    Post subject: Reply with quote
thanks for the input guys
the cnut still wont fire up. ordered a set of points on sunday so will fit them when they appear. really dont want to take the flywheel off. its the only thing it can be as ive checked everything today. in hinsight i should have bought a half decent 125. Thumbs Down
Yamaha Tdm850
Yamaha fz6
Wil
PostPosted: 19:17 - 24 Feb 2009    Post subject: Reply with quote
Ah, but once it gets going it'll be a barrel of laughs, all 100cc 2 strokes are Smile
cammy mack
PostPosted: 20:27 - 24 Feb 2009    Post subject: Reply with quote
this is going to sound stupid but how do i check to see if its sparking?. do i take out the plug put it on the ht lead then kick the bike???
Yamaha Tdm850
Yamaha fz6
lonner
PostPosted: 20:37 - 24 Feb 2009    Post subject: Reply with quote
stick the plug in the cap and lay it on the head so its earthed the kick it over Thumbs Up
you may just have a dodgy ht cap if you have changed the plug Thumbs Up
cammy mack
PostPosted: 20:57 - 24 Feb 2009    Post subject: Reply with quote
just checked it and defo getting a spark. it must be the points although they look fine and clean. im totally stumped.
Yamaha Tdm850
Yamaha fz6
hmmmnz
PostPosted: 04:19 - 25 Feb 2009    Post subject: Reply with quote
lol, did you think that through???
if its sparking, then its definitely not the points, Very Happy
they are the old skool equivalent of a cdi.
if it sparks then the points are opening.
i would pull the carb off again, remove all the jets soak them in kerosene or carb cleaner,
blow through all the holes with compressed air or carb cleaner,
the try again,
if still not starting, then pull the barrel off, its just 4 bolts after all,
and check the piston rings and the bore to make sure that all is good,
you need a good seal on the rings for the piston to suck fuel through the carb
the humans are dead
I kick arse for the lord
cammy mack
PostPosted: 08:54 - 25 Feb 2009    Post subject: Reply with quote
surely if the plug is wet with fuel then that's a good sign that there is compression?. i will give the carb a good going over tonight Thumbs Up Karma
Yamaha Tdm850
Yamaha fz6
Wil
PostPosted: 14:34 - 25 Feb 2009    Post subject: Reply with quote
Does the kickstart offer any resistance? Have you done a compression test?
It may be sucking fuel on the intake stroke but I'm not 100% sure that's a definate indicator of compression on a 2 stroke...
cammy mack
PostPosted: 21:02 - 25 Feb 2009    Post subject: Reply with quote
just done a pikey compression test seems ok . it was blowing my thumb off the top of the head. checked carb jets and they are ok, as in not blocked. the only optio left to do is change the points. in the words of toyah "oh its a mystery" Laughing
Yamaha Tdm850
Yamaha fz6
cammy mack
PostPosted: 23:57 - 25 Feb 2009    Post subject: Reply with quote
mystery solved!. bad compression due to ill fitting sparkplug!. something so simple yet totally over looked it. cheers for all the advice Thumbs Up Thumbs Up Karma
Yamaha Tdm850
Yamaha fz6
MaybeGuy
PostPosted: 02:20 - 26 Feb 2009    Post subject: Reply with quote
are you sure its that? could be a stripped or worn thread.
The last post was made 17 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 127.88 Kb
