bike grips
lurer
PostPosted: 19:38 - 24 Feb 2009    Post subject: bike grips Reply with quote
i know this may sound really stupid but how do you get bike grips off especially the throttle side as i dont want to flood the engine ?
cheers
red and carbon fibre peugeot speedfight 50cc
rockers
PostPosted: 19:43 - 24 Feb 2009    Post subject: Reply with quote
if the grips are total useless
i would use a sharp stanley knife and just cut from end to end and there fall off.
Rocky
lurer
PostPosted: 19:46 - 24 Feb 2009    Post subject: Reply with quote
yeah cheers and then for the new grips chuck some vaseline or something like that to get them on ?
PostPosted: 20:00 - 24 Feb 2009    Post subject: Reply with quote
Use hairspray. It acts as lubrication when you put the grip on, and then it dries and holds it in place! Smile
Jamie S
Christ no ! I personally use petrol or thinners wiped around the bars then shove the grip on, some peaople suggest using hairspray, being a lads only household we don't have any here so Ive never tried it.
tommybhoy
PostPosted: 20:21 - 24 Feb 2009    Post subject: Reply with quote
I used utube when i needed to install my hot grips.
Basically get your bar ends off
insert a small scewdriver in between the rubber and the plastic/steel depending what side you on and rotate round to losen any glue.
Then get a bigger screwdriver and insert then spray wd40 into the space and rotate again grip should slip off then clean .
use glue on both sides and slip new grips on, use rubber hammer aswell..
Check utube it will give u hinters
Current bike..Honda VFR 800 Vtec
A billion seconds ago it was 1959.
rockers
PostPosted: 21:21 - 24 Feb 2009    Post subject: Reply with quote
personally i steer clear from using any oil based stuff to get grips on or off, as said hairspray is the best, acts as a lube on and sticks like .... to a blanket.
iooi
PostPosted: 21:27 - 24 Feb 2009    Post subject: Re: bike grips Reply with quote
cheers
Well turn the fuel tap off then........
You can slit them with a stanley knife, but far safer is screwdriver and wd 40.
Then a good clean and hairspray to get the new ones on. I don't like to use glue, as sods law says it will stick and leave them in the wrong place.
stirlinggaz
PostPosted: 21:56 - 24 Feb 2009    Post subject: Reply with quote
hi,
seeing as were talking about using hair products.
why not heat the old grips up with a hairdryer, till they become plyable , then they should be easier to remove.just peel them off.
(dont want to cut through the throttle tube with a sharp knife)
then whip out the hairspray & coat the inside of the new grips/outside of the bar & slide the the new grips on.
cheers,
GAZ
The last post was made 17 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 60.34 Kb
