all lights keep blowing: peugeot zenith 50.
spudbag
PostPosted: 19:53 - 24 Feb 2009    Post subject: all lights keep blowing: peugeot zenith 50. Reply with quote
on my peugeot zenith 50 i have had to replace all my bulbs 3 times now.. this is because when i put my full beam on the lights on my dash light up really bright and start to flicker then the full beam blows.. but then i have to switch down to low beam which then blows as well after about 5 mins.. then follows through to back light and then brake light..i have taken to a garage where i bought the bike and they charged me £50. to just change the headlight bulb... but they didnt fix the fault.. it seems to be the same sequence every time.. any suggestions.. thanks
lonner
PostPosted: 20:23 - 24 Feb 2009    Post subject: Re: all lights keep blowing: peugeot zenith 50. Reply with quote
hi
well the last time that happend to me was on a yami rs100 about 27 yrs ago and the reason was the rectifier.
changed that and it was fine.
so if you can check the charging volts and see what you get.hth
spudbag
PostPosted: 20:26 - 24 Feb 2009    Post subject: Reply with quote
hi yes i get 14.2 when its running
lonner
PostPosted: 20:33 - 24 Feb 2009    Post subject: Reply with quote
well in that case check any earths you can find and look for any broken damaged wiring and check connector blocks etc although i think its a regulator or rectifier fault .
spudbag
PostPosted: 20:37 - 24 Feb 2009    Post subject: Reply with quote
ok thanks very much.. will try all that tomorow. many thanks
Fisty
PostPosted: 21:33 - 24 Feb 2009    Post subject: Reply with quote
Is it a zenith l or m and what reg is it on? My R plate had a big white connector block under the front fairing whish had got wet through and corroded. The lights kept shorting out and blowing bulbs usually the tail light. It was sorted with some contact cleaner and a brass wire brush.
Tom
Fatter and faster than Fret
The last post was made 17 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 47.14 Kb
