Ouch...my tooth
killa
Won't Shut Up
PostPosted: 11:32 - 25 Feb 2009    Post subject: Ouch...my tooth Reply with quote
My bottom front tooth is giving me some discomfort.
There appears to be nothing wrong with it, but every now and again it dishes some pain out.
FYI, i brush regular and look after my teeth, i can't see anything wrong with it. Confused
Quote Me Happy
PostPosted: 11:33 - 25 Feb 2009    Post subject: Reply with quote
Go to a dentist.
killa
Won't Shut Up
PostPosted: 12:11 - 25 Feb 2009    Post subject: Reply with quote
Yeah problem solved i guess, but i can't go there i work all day and its not bad enough to leave.
Just had no idea why it would cause me pain if it looks like theres nothing wrong.
Misc
PostPosted: 13:58 - 25 Feb 2009    Post subject: Reply with quote
Get some clove oil, helps with toothaches. Just wish i had some when i had mine.
mooserx
PostPosted: 14:26 - 25 Feb 2009    Post subject: Reply with quote
Thumbs Up for clove oil,
There could be nowt wrong with your tooth, sometimes teeth just throb, i get it every now and again, especially if i brush to hard, goes off after a day or so. i'd go to the dentist if it keeps up though.
TL1000r-handful.
killa
Won't Shut Up
PostPosted: 15:23 - 25 Feb 2009    Post subject: Reply with quote
Yeah was thinking that might be the cause.
I brush my teeth reguarly, last night i did a full service.
Floss, brush and mouthwash.
Nuked em.
Maybe i just see how it goes. Thumbs Up
PostPosted: 16:03 - 25 Feb 2009    Post subject: Reply with quote
You won't like it, but it works
teaspoon of salt in warm water...rinse gently and repeat
do this and it will ease your pain
Pat
Suitor_Stu
PostPosted: 20:13 - 26 Feb 2009    Post subject: Reply with quote
Clove oil will only really help if there is a path to the nerve of the tooth (usually caused by the decay making a hole to there). If there is no obvious decay then it could be a number of things - gum related, relating to the micro-ligaments that are attached to the tooth, or it could just be transient sensitivity.
What kind of pain is it? Is it sharp shooting pain, or a dull ache. Does it come and go with certain things? Do hot or cold drinks make it worse/better? If you genuinely want the possibility of a little more insight then a picture of tooth and gum may give a bit more info, but in all honesty all I would be able to say to you is that either yes I can see something and you should go to a dentist or no I can't see anything and you should prob go to a dentist!
Sorry, Stu
MattHirst
PostPosted: 21:26 - 26 Feb 2009    Post subject: Reply with quote
Do we have our very own BCF dentist here? Smile
Bikeless
PostPosted: 21:30 - 26 Feb 2009    Post subject: Reply with quote
Think so but he lives bloody miles away from me and my wisdom tooth has been giving me agro for months now, Sad
Handsome
PostPosted: 21:35 - 26 Feb 2009    Post subject: Reply with quote
When my last wisdom tooth started playing up last year I was in agony, tried everything and nothing worked for longer than a few minutes, just happened to have a packet of Palmer Voilets in my pocket and thought fuck it and started eating them, seriously within minutes they'd taken the edge of the pain and kept it off for hours... Thumbs Up
I lived on them for the few days it took for the appointment to roll around...
alliamc
PostPosted: 12:00 - 27 Feb 2009    Post subject: Reply with quote
Get a mirror and have a look behind your tooth, might look ok from the front but you need to check there's nothing at the back!
Alli x
https://www.bikepics.com/members/alliamc/
Bikeless
PostPosted: 13:23 - 27 Feb 2009    Post subject: Reply with quote
I had a tooth pulled out recently which was bad and was obstructing the wisdom tooth,they recommended i had the wisdom pulled aswell but i declined.
Suitor_Stu
PostPosted: 17:23 - 27 Feb 2009    Post subject: Reply with quote
fireblade2102 wrote:
They recommended i had the wisdom pulled aswell but i declined.
Yeah, wisdom teeth are a gits like that - even if you give them enough room to erupt they sometimes don't. You get problems when they partially erupt because you cant clean it very well and it just gets decayed. Think you know what you need to do though!
Stu
hellkat
PostPosted: 17:49 - 27 Feb 2009    Post subject: Reply with quote
Go to the dentist.
Shocked
https://penguindevil.com/blog/blogpics/marathonman2.jpg
Bikeless
PostPosted: 17:57 - 27 Feb 2009    Post subject: Reply with quote
Stu
At the moment it has no other teeth around it,has come out a fair bit and is slightly impacted towards my cheek,i have very few back teeth and planned on keeping it but it keeps giving me pain.Do you think the pain will stop at some point?
Suitor_Stu
PostPosted: 14:24 - 02 Mar 2009    Post subject: Reply with quote
It's hard to say - It really depends on what the pain is like. I mean there is a certain amount of pain that results from teeth erupting (you ever heard a baby when they are teething?!) and if it's associated with that then it should go away with time. However, if the tooth is decayed (a distinct possibility if it was closely related (ie impacted) to the other molar which you got out because - presumably - it was decayed ) and it's toothache pain it's pretty much impossible to do a filling or anything else on something which isn't fully erupted - for most of the materials we use to work well the tooth needs to be kept dry, which isn't an option if there's a bit of gum over it!
In all honesty, it's very hard to give medical/dental advice over the phone or internet since there are so many factors that need to be considered which can be done in about 5mins in a surgery, but are much harder to do over the web!
Sorry I'm repeating it again but best thing to do would be to get yourself to a dentist while it's still not so sore that you don't care what happens to it - this way you may have options.
Cheers, Stu
Dragonfly
PostPosted: 14:33 - 02 Mar 2009    Post subject: Reply with quote
I dont know why that made me LOL Laughing
Bikeless
PostPosted: 14:52 - 02 Mar 2009    Post subject: Reply with quote
Cheers stu,i will put up with it for a bit longer and if it continues i suppose i will have to go back, Sad
jack_zxr400
PostPosted: 15:22 - 02 Mar 2009    Post subject: Reply with quote
is it senistive to orange juice or cold stuff like ice-cream? ;o
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
killa
Won't Shut Up
PostPosted: 15:36 - 02 Mar 2009    Post subject: Reply with quote
Hasn't come back since i calmed down a bit with the cleaning. Think i may have just over done it a little.
Thanks for the advice Thumbs Up
Bikeless
PostPosted: 15:38 - 02 Mar 2009    Post subject: Reply with quote
Sorry killa for slightly hi-jacking your thread, Smile
killa
Won't Shut Up
PostPosted: 16:05 - 02 Mar 2009    Post subject: Reply with quote
Wink Thumbs Up
c_dug
PostPosted: 01:35 - 03 Mar 2009    Post subject: Reply with quote
This seems like a semi appropriate thread to slot this in rather than making my own - who's had alot of pain after root canal? I've heard so many bad stories about it being agony but ive just had root canal done and it didnt hurt at all, not even once... am i wierd or something?
2 hi-jacks in one thread woop woop Laughing
c_dug
The last post was made 17 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 121.8 Kb
