Pushbike disc brakes...
Method
PostPosted: 16:37 - 25 Feb 2009    Post subject: Pushbike disc brakes... Reply with quote
Panic #2
I have a Saracen Xile, ive fitted new bits left right and center and never realy had a problem, however now i have met my match.
I bought some downhill rims a while ago, with disc brakes mounted to the hubs allready, as i wanted to convert my v - brakes to discs.
So the wheels are in, nice and simple, happy days.
I have a caliper that i borrowed from someone at work, however the caliper wont mount perfectly flush to my frame (only tried the rear brake so far), and the disc wont fit into it - eg it hits the top of the calliper before the axel is seated where it should be.
Ive done a bit of internet looking and i am now totaly confused about what i imagined to be a very simple subject.
So - basically, what on earth do i need now to get disc brakes onto my bike? Its a saracen xile, with i think 160/165mm discs on the rims.
thanks!
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Dischord
PostPosted: 17:45 - 25 Feb 2009    Post subject: Reply with quote
You need smaller discs by the sounds of it. Either that or fabricate an adapter that seats the caliper further out, you should easily be able to make one.
2012 KTM EXC 250
Dischord
Also don't even bother with cable operated discs (doubt you are) but a decent V-Brake setup will out perform them.
2012 KTM EXC 250
Ghost
PostPosted: 18:14 - 25 Feb 2009    Post subject: Reply with quote
You'll need an adapting mount, though chances are the rotors aren't right for the calipers anyway so you'll have funny things going on when you come to put brake pads in and use them. It's for this reason calipers and rotors are normally bought as a set, if you buy a complete disc brake it will come with a rotor and everything. For what it's worth I'd just buy a second hand set of Hope Minis or similar and be done with it. Thumbs Up
cagiva gezzer
PostPosted: 21:17 - 25 Feb 2009    Post subject: Reply with quote
As above. You need a new adaptor plate that's designed for the diameter of the disc.
binge
Emo Kiddy
PostPosted: 00:01 - 26 Feb 2009    Post subject: Reply with quote
Adapter plates can be made easily. I was looking into getting my Hubs Machined on my Pit bike and running Hope brakes front and rear.
Ben
Method
PostPosted: 09:43 - 26 Feb 2009    Post subject: Reply with quote
Ive actually taken a punt on a set from ebay, to see if they work or not.
The callipers are for the same size disc as mine, so we will see if they work - if not, then i have the full set to just put onto my wheels.
However, i dont even know if that will work!
Seriously, motorbikes / cars - Fine! Give me a push bike, im lost!
I've got to put a new crankset in before the 6th March - how on earth am i going to manage that! Laughing
divuk83
PostPosted: 11:20 - 26 Feb 2009    Post subject: Reply with quote
I have cable discs on my GT that I initially though were crap compared to my old V's, however get them set up and aligned correctly and they are pretty damn good.
Dave
The last post was made 17 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 57.35 Kb
