What grease?
Reppyboyo
PostPosted: 14:33 - 26 Feb 2009    Post subject: What grease? Reply with quote
Hi,
I need to take out the rear hub on my Speed Triple to inspect the bearings and repack them with grease as necessary.
What type of grease should I use for the bearings?
Also, what type for greasing the axle? (As in on the inside where the bearing make contact, on the outside of the hub copper slip is needed)
Thanks all.
EDIT: Also, do you need to repack a needle bearing?
If so, how?
lonner
PostPosted: 14:56 - 26 Feb 2009    Post subject: Re: What grease? Reply with quote
Reppyboyo wrote:
Hi,
Thanks all.
If so, how?
i used general purpose grease on my sprint st which is same as yours
avoid copper slip on moving parts as abrasive (threads-axle ok).
would think the needle bearing will be ok unless yours is shot.
it will pop out of its hole if you are changing it and simple once you get to it Thumbs Up
PostPosted: 15:39 - 26 Feb 2009    Post subject: Reply with quote
Use LM grease for wheel bearings.
Most wheel bearings these days are sealed and do not need to be serviced. You just replace them if they start grumbling.
Use copper grease to stop the spindle seizing. The bearing should not be turning on the spindle.
I'm not familiar with your bike so I'm not sure what the function of your needle bearing is and what type it is.
EDIT: If your wheel bearings are not sealed ones and you are taking them out, I wouldn't put them back in again, I'd replace them with sealed ones from a bearing factors (take the old ones in with you). Bearing factors charge a lot less than motorcycle dealers, usually supply better bearings and almost always have them in stock.
4Stroke
PostPosted: 15:41 - 26 Feb 2009    Post subject: Reply with quote
I'd use Lithium grease.
PostPosted: 16:20 - 26 Feb 2009    Post subject: Reply with quote
Me too.
Bikeless
PostPosted: 16:53 - 26 Feb 2009    Post subject: Reply with quote
I was always told to use constant velocity grease in bearings but i always use lithium as the bearings are sealed anyway.
sickpup
Old Timer
PostPosted: 22:32 - 26 Feb 2009    Post subject: Reply with quote
I would use Lithium on the bearings and Moly between the eccentric adjuster and the swingarm.
B10Hazard
PostPosted: 23:32 - 26 Feb 2009    Post subject: Reply with quote
I used morris k99 water resistant when i di my front wheel bearings.
Allthough i only have a 50 at the moment for the winter so my bike will be going knowhere near as fast and the bearingsw will not be getting as hot. I got told by a bike shop to use this stuff, but im guessing for larger bikes you will need a thinner grease, less sticky grease that can cope with a bit more temperature.
K99 worked well though Smile
No longer any socks
The Artist
PostPosted: 09:41 - 27 Feb 2009    Post subject: Reply with quote
Wheel bearings shouldn't get hot
PostPosted: 12:14 - 27 Feb 2009    Post subject: Reply with quote
Once again, I would like to say that if you've gone to the effort of removing a set of open wheel bearings to grease them, put sealed ones back in. They are not expensive and you probably damaged the old ones taking them out anyway.
It is another one of those things they do on motorbikes that I really don't understand. Surely an open bearing complete with a two part dust seal costs about the same and is more complex to fit than a double sealed one?
In this day and age, there is no good reason to be greasing rolling element wheel bearings when good quality, sealed, service free ones are so readily available.
The last post was made 16 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 65.07 Kb
