| Reppyboyo |
 Reppyboyo Nearly there...
| lonner |
 lonner Spanner Monkey
| stinkwheel |
 Posted: 15:39 - 26 Feb 2009 Post subject: |
Use LM grease for wheel bearings.
Most wheel bearings these days are sealed and do not need to be serviced. You just replace them if they start grumbling.
Use copper grease to stop the spindle seizing. The bearing should not be turning on the spindle.
I'm not familiar with your bike so I'm not sure what the function of your needle bearing is and what type it is.
EDIT: If your wheel bearings are not sealed ones and you are taking them out, I wouldn't put them back in again, I'd replace them with sealed ones from a bearing factors (take the old ones in with you). Bearing factors charge a lot less than motorcycle dealers, usually supply better bearings and almost always have them in stock. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| 4Stroke |
 4Stroke Scooby Slapper
| chris-red |
| Bikeless |
 Bikeless World Chat Champion
| sickpup |
 sickpup Old Timer
| B10Hazard |
 B10Hazard World Chat Champion
 Posted: 23:32 - 26 Feb 2009 Post subject: |
I used morris k99 water resistant when i di my front wheel bearings.
Allthough i only have a 50 at the moment for the winter so my bike will be going knowhere near as fast and the bearingsw will not be getting as hot. I got told by a bike shop to use this stuff, but im guessing for larger bikes you will need a thinner grease, less sticky grease that can cope with a bit more temperature.
K99 worked well though  ____________________ Current bike .. The police stole it
No longer any socks
Let me take you on a trip . . let me show the world in my eyes. |
| The Artist |
 The Artist Super Spammer
| stinkwheel |
 Posted: 12:14 - 27 Feb 2009 Post subject: |
Once again, I would like to say that if you've gone to the effort of removing a set of open wheel bearings to grease them, put sealed ones back in. They are not expensive and you probably damaged the old ones taking them out anyway.
It is another one of those things they do on motorbikes that I really don't understand. Surely an open bearing complete with a two part dust seal costs about the same and is more complex to fit than a double sealed one?
In this day and age, there is no good reason to be greasing rolling element wheel bearings when good quality, sealed, service free ones are so readily available. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 17 years ago. Instead of replying here, would creating a new thread be more useful? |
