My garage - are they being idiots(no)? *Result!*
rac3r
PostPosted: 11:54 - 02 Mar 2009    Post subject: My garage - are they being idiots(no)? *Result!* Reply with quote
Following my other post about the brakes I took my bike to a small garage near me called Bob Thomas, pretty much a 2 man crew(old guy and a mechanic). The guy had a quick look at the bike outside the shop and said it may be the calliper is seized on one side 'but you'll have to book it in for a proper look' so I said i'll bring it to him later on in the week. Today I remembered to ask him the costs etc, so I phoned him up and said how much will it cost to have a look at it NOT to repair and
he says 'I don't know until we've had a look at it'
I say ' I'm not asking repair charges i'm talking about having a look'
He says 'but I don't know it might take 1 hour or 10 hours, I don't know till we've had a look'
I say Doh! ' OK so what is your charge per hour'
He says ' £46 per hour'
What should I do? DIY or just chance it and hope he doesn't rip the shit out of me?
Chequered Flag
Hetzer
PostPosted: 11:58 - 02 Mar 2009    Post subject: Reply with quote
No, they're not being "idiots", they're being capitalists.
Pernig
PostPosted: 11:59 - 02 Mar 2009    Post subject: Reply with quote
If you can do it yourself, then do. But it's your brakes. If you're in doubt take it in to a mechanic. It's not something you want to go wrong five minutes down the road Neutral.
H100 Breaking for spares
PostPosted: 12:01 - 02 Mar 2009    Post subject: Reply with quote
Which bike is this on? CBR125? Think it is a single piston sliding caliper on the back. 2 main ways these can stick. Either the pins they slide of stick or the piston in the caliper sticks. I would suspect the pins first. Take the caliper off (should just be 2 bolts, don't undo the hydraulic line) and have a look. Pads will be cheap, but if BOTH pads are pretty equally worn then I would say likely the caliper is not sticking, you have just left the pads too long. See whether you can move the carrier the caliper slides on.
Front will basically be the same, just a 3 piston sliding caliper.
As to the mechanics, sounds like they are just being over cautious with giving you a price. Probably to avoid this kind of accusation.
Itchy
PostPosted: 12:09 - 02 Mar 2009    Post subject: Reply with quote
They are just being sensible , in that if they quote a price and something else is wrong with it? , a builder once quoted my dad a price and wrote it down and signed it...
The builder took down a wall and noticed something very wrong and incurred £3000 of extra costs to fix this problem.
Speedy is the same in that having a look may reveal other problems,
But fir £46 you might as well jump to £70 and get a piston puller.
james169 This post is not being displayed because the poster is banned. Unhide this post / all posts.
rac3r
PostPosted: 12:36 - 02 Mar 2009    Post subject: Reply with quote
That's the thing i'm not really sure what to look for, pads I can check but with the pistons and stuff I'm not sure. I was asking him for the price to have a look at the problem not to repair it, he only told me he doesn't know how long it takes to have a look at the rear brake and that he charges £46 an hour
I don't have a picture of the brake any more but one side of the disc seems do have a dark line along the tracking area and it squeaks when pushing the bike and riding at low speeds. (rear brake)
Chequered Flag
PostPosted: 12:40 - 02 Mar 2009    Post subject: Reply with quote
From his point of view, the pads could have welded themselves to the disk, and so virtually impossible to remove the caliper to check it. More realistically there could be a serious lip on the edge of the disk making it very difficult to remove a sticking caliper to find what on it is sticking.
Suspect the 10 hours mentioned was just basically saying that he cannot really say.
Pie-Roe
PostPosted: 12:53 - 02 Mar 2009    Post subject: Reply with quote
If you let the pads get down too low, they could just be down to bare metal on metal, hence the squeeking grinding noise.
Pyro
rac3r
PostPosted: 12:56 - 02 Mar 2009    Post subject: Reply with quote
Pyro
The pads seem to have enough meat on them, the mechanic said so too. It's not a constant squeak, it does it when it reaches a certain part, its hard to explain
Chequered Flag
Sparks!
Sir Tart-a-lot
PostPosted: 13:11 - 02 Mar 2009    Post subject: Reply with quote
Sounds like the disc is warped?
Ride along in a straight line about 20mph then apply front brake only and see if wobbles/grinds or pulls to the side...
rac3r
PostPosted: 13:19 - 02 Mar 2009    Post subject: Reply with quote
Since this problem I've ridden it a few times only using the front brake, haven't used the rear though
Chequered Flag
PostPosted: 13:23 - 02 Mar 2009    Post subject: Reply with quote
From the picture you put in the earlier thread it looks like the pads are down to the metal and chewing up the disk. Other possibility would be that the last pads were doing that and they have been recently changed.
Skudd
I'm sure the mechanic will look at it for free, giving you the wisdom of his knowledge will cost you and the skills of his hands will cost you more.
rac3r
PostPosted: 14:57 - 02 Mar 2009    Post subject: Reply with quote
I'll probably end up taking it to the garage because I'd rather not try and fix it if i'm not sure especially as its the brakes. Is £46 an hour about right for labour charges?
Chequered Flag
Itchy
PostPosted: 15:03 - 02 Mar 2009    Post subject: Reply with quote
Its reasonably cheap actually ESB are about 90 an hour , Speedy 75 an hour, Warricks about £75 an hour.
Remember when they say labour at X an hour they are not putting that all into their pockets , their accountants would have told them to factor in overheads into their labour rate, ie the light/heating/tool wear and tear / business rate costs into the labour rate. But its fairly low for a labour rate though.
But price is not an indicator of how good they are. ESB are a bunch of cowboys and they are expensive, while mr pigs is good and expensive. Peter in Wharf Bury is cheap yet very good, though he moans a fair amount and never does the job 100% , ie you want valve clearances done , he'll do it put the cylinder head back on then give you a call , and will drop your bike off in a partially assembled state where its easy to put back together to save his time and your money I suppose.
nick606
PostPosted: 17:27 - 02 Mar 2009    Post subject: Reply with quote
My mechanic charges about £25 an hour.
Skudd
PostPosted: 19:59 - 02 Mar 2009    Post subject: Reply with quote
Who is that?
nick606
PostPosted: 20:06 - 02 Mar 2009    Post subject: Reply with quote
jeff davenports. Well mike is the mechanic near Morrisons
LeeR
PostPosted: 20:49 - 02 Mar 2009    Post subject: Reply with quote
To be honest you could probably do the inspection yourself; armed with a can of brake cleaner I removed and inspected my calipers the other month.
There's no mistaking a seized piston as you'll struggle to slide the caliper off the disc.
Once I'd got the pads out and cleaned most of the debris away with a toothbrush and brake cleaner I realised I was going to need the caliper overhauling.
I had the pads and piston seals replaced as part of a minor service at the local Suzuki dealer's, they also charge £45/hr which for a main dealer is very reasonable imho. Thumbs Up
As an aside what the hell is going on with the karma on this thread? Keith I think you might need to sort the nadgers out. Wink
My claim to fame: Austin Vince nicked my pen...
Itchy
PostPosted: 21:22 - 02 Mar 2009    Post subject: Reply with quote
The trick if the calipers are seized onto the disc is to wheel the bike backwards slightly after you undo the bolts holding it onto the forks , it should slide down with the disc at which you can pull it off in a more favourable position , you can push it the other way too but you risk damage to the caliper.
Mudskipper
PostPosted: 21:36 - 02 Mar 2009    Post subject: Reply with quote
It was a spammer who copied and pasted pernig's post, to spam their signature links.
Skudd
PostPosted: 21:49 - 02 Mar 2009    Post subject: Reply with quote
Is he still going. I remember when he was the partsman for Tom Collins. Mike is the little guy with a fag attached to his lip? One week translates to two months.
nick606
PostPosted: 21:54 - 02 Mar 2009    Post subject: Reply with quote
nar thats not mike. Mikes is the austrailain been there for about a year now, use to work at mmc.
Skudd
PostPosted: 21:56 - 02 Mar 2009    Post subject: Reply with quote
might have to revisit the place then. Thumbs Up
The last post was made 17 years, 187 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 137.68 Kb
