ktm sx50 kickstart Problem...
ash-2009
PostPosted: 19:15 - 02 Mar 2009    Post subject: ktm sx50 kickstart Problem... Reply with quote
when i kick the bike it goes to turn over then slips some times it will catch and some times it wont any one have any ideas what it could be ?? Thumbs Up
B10Hazard
PostPosted: 19:21 - 02 Mar 2009    Post subject: Reply with quote
https://www.tazracing.com/images/ktmeng-1.JPG
Take the casing off labeled as 9 i think, undoing all the bolts labeld as 6, and check it out,
All the gears and stuff that will be exposed check them out for damage and things then re post Thumbs Up
No longer any socks
ash-2009
PostPosted: 19:59 - 02 Mar 2009    Post subject: Reply with quote
iv'e just had the side casing off it didnt look like anything was damaged not that i knew what i was really lookin for when iv'e went back and put the casing on theres nothing there at all now when i try and kick it so its something really daft i think... any ideas what ive done there is it coz theres no oil in it now that it wont kick at all
B10Hazard
PostPosted: 20:25 - 02 Mar 2009    Post subject: Reply with quote
There should'nt be oil in there.
Take it off again and make sure the kick start is actually locking onto a gear and actually spinning round
No longer any socks
ash-2009
PostPosted: 21:02 - 02 Mar 2009    Post subject: Reply with quote
yer ive checked when ive got hold of casing i put the vice clamp on it and spun it it did turn the little gear thing cog but then it moved outa place but i suppose thats right as when i looked inside where the casing come off theres grooves that match up to the thing that moves im not good with names of parts lol newb at fixing bikes..
B10Hazard
PostPosted: 22:23 - 02 Mar 2009    Post subject: Reply with quote
Now im lost.
I keep looking at my pic but i really cant think of much
Sad Thumbs Down
No longer any socks
tutton
PostPosted: 22:48 - 02 Mar 2009    Post subject: Reply with quote
Have you got good compression?
only asking as a mate on his old 125 crosser, used to do the same on the kickstart it would nearly kick over and go down really easy then next kick itd kick into life, compression was wayy down on it.
B10Hazard
PostPosted: 22:57 - 02 Mar 2009    Post subject: Reply with quote
Going on tuttons post about you compression, is the spark plug loose in any way.
No longer any socks
ash-2009
PostPosted: 10:42 - 03 Mar 2009    Post subject: Reply with quote
how would i check see if its got good compression also the spark plug wire i think its called a ignition coil i broke the sparkplug cap off it its not one of them that just screws back on its got a little spring inside and i cant get it to go back on how would i fix this could i strip down the ignition coil down to wire on the end and push it into the sparkplug cap and seal it with some type of weather proof tape??
ash-2009
PostPosted: 10:49 - 03 Mar 2009    Post subject: Reply with quote
also does anyone know where the carb screws shud be set right i also wudnt mind cleaning carb if some ones got a diagram for me sorry for all the questions im a complete newbie so pics would be good Very Happy Thumbs Up
B10Hazard
PostPosted: 12:41 - 03 Mar 2009    Post subject: Reply with quote
If your a novice i wouldnt go stripping your carb for no aparent reason, get the kick start sorted first.
To set them is quite simple. Your bike ticking over is also called ideling, to get you idel right find the screw with a spring around it. The more you tighten that the more your revs will be on "idel", you want the idel to be sat nice so your bike will hapilly run without you applying throttle, and when you have reved your bike it should go back to this position without your bike cutting out.
Somewhere else on your carb there will be another screw to ajust your mixture but i am not saying where because i have no idea about your carb and i could be telling you to ajust all kinds of stuff.
No longer any socks
ash-2009
PostPosted: 12:47 - 03 Mar 2009    Post subject: Reply with quote
thanks biohazzard i just bought it as a project off a mate so its just to learn o n really how things work Very Happy thanks for the reply do you know how i could fix the wire to the sparkplug cap as the wires broke from it Crying or Very sad
ash-2009
PostPosted: 12:49 - 03 Mar 2009    Post subject: Reply with quote
or am i best just buyin a new spark plug cap what just screws on the honda shop sell them down here ..
ash-2009
PostPosted: 12:51 - 03 Mar 2009    Post subject: Reply with quote
any one got any pics to show me how to fix my kick it goes to turn over but once its past the first part of the kick it just goes down with like a crunching noise but no sound of it turning over
ash-2009
PostPosted: 14:26 - 03 Mar 2009    Post subject: Reply with quote
Thumbs Up vincent thanks for reply will try that with the old cap first then if not i will buy a new cap and i will take the casing off soon and get pics.. Thumbs Up
ash-2009
PostPosted: 14:29 - 03 Mar 2009    Post subject: Reply with quote
vincent about the sparkplug cap it looks new but the screw that screws into the coil wire has snapped so its a new cap isnt it? i cant get the screw back in the cap by pushing it so i assume its fu*ck*d
sumpgard
PostPosted: 15:10 - 03 Mar 2009    Post subject: Reply with quote
the kick start gear needs to be alined in a certain way you need to remove the spring pull the gear out push it back in so when you turn it the gear moves out you will have to play a bit. when in the right position it will come out and go back in when the kick start comes back replace spring and the plastic sleave this has a notch in that lines up with the spring hope this helps
ash-2009
PostPosted: 15:29 - 03 Mar 2009    Post subject: Reply with quote
right first things first the first two pics are what is behind the kickstarter cover... and the second two are of the acctual casing what the kick is attached to...
The Artist
PostPosted: 15:57 - 03 Mar 2009    Post subject: Reply with quote
On the first and seconds pictures, the part that the kickstart engages to looks very worn. I can't tell from those pictures properly but make sure the teeth are not rounded off.
ash-2009
PostPosted: 16:14 - 03 Mar 2009    Post subject: Reply with quote
right the kickstart gear cog isnt rounded but i think the part tht it spinz on the engine might me not sure what oil do they take inside tht part of the engine ive been told that MOTOREX ATF SUPER has been recomended by KTM but im not sure as some one says above it shouldnt have oil in there but its got a allenkey oil refill point on the casing it says at the side of it 150cc not asin the engine size but assin how much oil or what ever goes in ther
ash-2009
PostPosted: 16:57 - 03 Mar 2009    Post subject: Reply with quote
ive just relised why it could be slipping is it cause i drained the automatic clutch ,gear oil and havnt put none back in could no oil cause the kick to start and slip or would that just cause the auto clutch to slip?
ash-2009
PostPosted: 17:16 - 03 Mar 2009    Post subject: Reply with quote
ive just clicked on its liquid cooled 2 so should i put 2t in the radiator or water??
The last post was made 17 years, 130 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 3.64 - MySQL Queries: 13 - Page Size: 126.39 Kb
