Bike cut out and died. Think its crap in the carbs... Help?
Visitor Q
$25 whore
PostPosted: 20:25 - 03 Mar 2009    Post subject: Bike cut out and died. Think its crap in the carbs... Help? Reply with quote
Right, bike rode the entire way to work and back today fine.
Get off the motorway, brake for a roundabout, get back on the power and it starts burbling like its going on to reserve. Except it's still got half a tank.
I get in to a layby and it dies the moment I take my hand off the throttle.
Go to start it again, same thing, starts burbles and dies. Trying to rev it just led to more ashmatic noises.
However, with the choke on it started, shot to 5k and sat there racing away like it was about to take off.
Oil light was coming on when it cut off, but apparently this is normal. Wouldn't mind a second opinion though. Oil level seems fine, battery is fine, fuel is fine...
I had it clocked as airflow, carb flow or *shudder* oil seizure.
But what with the weird choke foible, and the oil level being fine... carb over haul?
Anything I could do with getting in to do it?
RS2MATRIX
PostPosted: 20:33 - 03 Mar 2009    Post subject: Reply with quote
yeah oil light will only go off when the engine is running (assuming there is oil pressure)
open the tank filler cap and try and start it. If it starts then clean the filler cap breather.
if not, i suppose you could turn the fuel off, drain the carbs out and turn the fuel back on. might flush any crap out?
Had the tank or anything off lately, might have got a kink in the fuel line? Air filter on properly and clean?
bound to be loads of other little things to check
Reiju RS2 Matrix
Kawasaki ZXR400
Visitor Q
$25 whore
PostPosted: 21:05 - 03 Mar 2009    Post subject: Reply with quote
Aye, all inferring a lack of fuel. But that wouldn't explain the racing with choke on surely?
PostPosted: 08:58 - 04 Mar 2009    Post subject: Reply with quote
Don't worry about the oil light coming on, that's normal on the CBR when the engine goes off as it is a pressure light as oppose to oil level.
Could it be a vacuum line's come off.
Sounds similar to what my GSXR did when I forgot to put a vacuum line back on. It would start up fine on the choke, but would instantly bog down if you touched the throttle. Thinking
Cigaro
PostPosted: 09:22 - 04 Mar 2009    Post subject: Reply with quote
No, it wouldn't explain it, but my bike does that when it's running out of fuel too.
Visitor Q
$25 whore
PostPosted: 13:59 - 04 Mar 2009    Post subject: Reply with quote
Arse. Need a good list of things to try on my day of Friday if I want itworking before next week. Which I do. Trains suck.
So we have breather/general hoses so far. What about stripping the carbs... what would I need to do it? ie, new gaskets? What to clean it with etc?
Bikeless
PostPosted: 14:29 - 04 Mar 2009    Post subject: Reply with quote
I'd agree with that,take your inline filter off and back flush it with petrol.I f you strip the float bowls make sure you have an exact fit phillips screwdriver as CBR float bowl screws are very soft and easy to chew up.
Visitor Q
$25 whore
PostPosted: 19:31 - 04 Mar 2009    Post subject: Reply with quote
Vincent wrote:
I'd leave the carbs alone for now, although if it's easy enough to get one off, it might be worth removing a float bowl and seeing if it's filling up ok. Sounds like it could be the breather as mentioned. Easy to find out if it is, just open the cap. Have you an inline filter on the fuel hose - could be that blocked too. might be time to clean the inside of the tank of any crud that's collected over the years.
Literally replaced the inline filter about 500 miles away.
Could be /lots/ of crud in my tank though Thinking
Will go try the breather idea now.
user
PostPosted: 19:56 - 04 Mar 2009    Post subject: Reply with quote
Umm, am I missing something? Every bike I've owned will race if you put the choke on while the engine is warm Confused
PostPosted: 20:16 - 04 Mar 2009    Post subject: Reply with quote
Similar thing happened to the MZ when the main jet fell out of its holder. It was running on the idle jet and would run on choke but wouldn't rev and would die once the throttle got over a certain amount.
Could be a blocked main jet.
Visitor Q
$25 whore
PostPosted: 22:23 - 04 Mar 2009    Post subject: Reply with quote
Aye, was what I'm thinking. Don't really fancy ferreting about in the carbs.
Oh and went to try the filler cap trick, except my bike won't give me the key back when it's open.
Will dig out the spare key later and have a go.
Visitor Q
$25 whore
PostPosted: 00:00 - 05 Mar 2009    Post subject: Reply with quote
Just been to check with the spare key, bike still doesn't start Confused
Arse. Won't run with choke now either... Thinking
Any other options then stripping the rat bastard down?
Pie-Roe
PostPosted: 00:05 - 05 Mar 2009    Post subject: Reply with quote
I had a similar problem on a fzr600, a week after I bought it there was so much crap in the tank and lines and stuff. After it cut out, I just put a litre of redex in it, and let it burn the crap out. Of course this is no good to you because you can't get it started.
Obviously you've changed the fuel tap to reserve to make sure it's not just gunk in the 'on' pipey bits?
Pyro
Visitor Q
$25 whore
PostPosted: 15:09 - 06 Mar 2009    Post subject: Reply with quote
Pyro
Checked that now. Hadn't then Embarassed
No joy. Charging the battery up now, then going to check flow through filters etc.
But like I say, what stumps me is the shit running at idle, and fast running at choke. Which makes me think internal gubbins of carbs are knackered.
Is there any problem with running vast quantities of redex et al through the system? I have done the normal addition (say 1:20) a few times, not noticed any difference. Would 1:1 actually be better at causing a noticeable effect?
Visitor Q
$25 whore
PostPosted: 15:33 - 06 Mar 2009    Post subject: Reply with quote
Ah, just took the battery off to charge and optimate reckons its a dead duck.
I'm going to leave it a bit more to see if it changes its mind, then pop down the road to the bike shops and grab a new one. See if that makes any odds.
Just to be certain, the ' Sad ' face indicator means buy a new battery doesn't it?
Robby
Dirty Old Man
PostPosted: 21:52 - 06 Mar 2009    Post subject: Reply with quote
Best stick it on here as well as facebook so I can look cool.
90% of carb problems turn out to be electrical, even though they really seem to be fuelling. Never ever even consider opening up a carb that previously worked perfectly without checking the battery and charging system first.
By charging system I mean the easy check - ~14volts across the terminals at 5000rpm, checked with a multimeter.
In this case the fuel filter was recently changed, the bike previously ran fine, and you haven't been buying fuel in Serbia. The battery is fucked, so change it before breaking other bits.
Visitor Q
$25 whore
PostPosted: 01:44 - 07 Mar 2009    Post subject: Reply with quote
I have done, but it now won't start at all and nothing is catching.
Ie no fuel.
But where Thinking
My thought was just to how rapidly it stopped working, it likely got a blockage somewhere. Will go through the fuelling backwards to see where. Thinking it might be the pump... again. Joy.
Robby
Dirty Old Man
PostPosted: 14:13 - 07 Mar 2009    Post subject: Reply with quote
Open a float bowl drain screw and see if anything comes out. That'll tell you if anything is getting to the carbs.
Then I'd check the fuel tap diaphragm for holes, assuming it's a vacuum feed fuel tap, and check to see if the fuel tap is clogged up inside.
Visitor Q
$25 whore
PostPosted: 16:52 - 07 Mar 2009    Post subject: Reply with quote
You see, that involves dismantling and therefore probably death. I prefer to just see what bits fuel comes out of.
Or more likely, pour fuel in the carb end and see if it works. Will do that Monday when I cry off of work.
Visitor Q
$25 whore
PostPosted: 16:30 - 09 Mar 2009    Post subject: Reply with quote
Sorted. Well, I know what it is.
Pour petrol in carb inlet pipe. Starts but runs crap (not enough fuel)
Pour petrol in fuel pump inlet pipe, it starts (cos I'd filled the carb inlet pipe) but runs crap and the level in the pump inlet doesn't move.
Swap relay (I had a spare, no joy)
Connect pump directly to battery, no pumpage.
So, case closed for now.
Do need some advice on cleaning a gammy fuel tank though, as that is probably the cause. Especially as the last funnel I used for petrol had some horrible white precipitate on it of unknown origin (probably from the petrol). I've some out in my old sump to see what nasties are left.
The last post was made 17 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.39 Sec - Server Load: 4.73 - MySQL Queries: 13 - Page Size: 122.45 Kb
