Aprilia Tuono owners?
Sparks!
Sir Tart-a-lot
PostPosted: 13:52 - 04 Mar 2009    Post subject: Aprilia Tuono owners? Reply with quote
Eyeing up my next bike, I am settled on an Aprilia. Originally a Falco but I'm swaying more to pay a bit extra and get a Tuono as I think it may be a bit more comfortable for long distance/tours etc.
Bike is only used for fun, no commuting or work or rainy days. After a 2003 model. Don't like the new ones. The 03's in red and gold are the nicest!
All I've seen/read so far is that its an excellent bike, but hoping for some more info like tank range? reliability etc etc? anyone been touring on one? what they like for pillions? anything I should know?
p.s I 100% want a v twin, it's now rounded down to just Aprilia, so it's between the falco and Tuono.. RSV is too race orientated for what I want.
thanks.
DaveH
PostPosted: 14:00 - 04 Mar 2009    Post subject: Reply with quote
Don't own one, but have ridden one...not sure about being more combortable than the falco; its the RSV with no fairing and flat bars; not that I found it uncomfortable, but rearsets are retained.
So other than that what applies to the RSV will apply to this; re tank range and pillions etc
Will definitely tick the fun box though!
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
Kris
PostPosted: 14:01 - 04 Mar 2009    Post subject: Reply with quote
Nice bikes, the Tuonos. Is it the R model you're after then?
What's your budget btw? (I'm selling my '54 plate SV1000 nekkid if you're interested)
www.prisonplanet.com
Sparks!
Sir Tart-a-lot
PostPosted: 14:03 - 04 Mar 2009    Post subject: Reply with quote
Cheers but I absolutely hate all things Suzuki (except DRZ400) and I've read the SV is a bit bland.. plus I had a SV650 and thought it was a bit tame/bland/boring.
I don't know the difference between Tuono and the R?? but this is the exact model/colour/year I want
https://www.hillsmotorparts.co.uk/uploads/APRILIA%20TUONO%20FIGHTER%20EU03/SDC14540.jpg
My budget was £2000 but I doubt I'd get a Tuono for that. If I decide its worth the extra its going to take a good few extra weeks before I can buy one, but I hope to get it within the next month really.
Sparks!
Sir Tart-a-lot
PostPosted: 14:06 - 04 Mar 2009    Post subject: Reply with quote
p.s I'm insured to ride other peoples bikes so if any kind Tuono owners in the South want to let me have a go I'd be much appricieative of that Laughing
Charlie
PostPosted: 14:10 - 04 Mar 2009    Post subject: Reply with quote
It looks fooking sexy, apart from the scud launcher of an exhaust.
Nom nom
rac3r
PostPosted: 14:31 - 04 Mar 2009    Post subject: Reply with quote
If i'm not mistaken the R version has ohlins, Brembos and stuff
Chequered Flag
MarkJ
PostPosted: 15:14 - 04 Mar 2009    Post subject: Reply with quote
The one in the picture is a standard Tuono. If it's anything like the RSV and RSVR, then the R has Ohlins Suspension all round and lightweight wheels. Should have carbon fiber bits and bobs too.
When I was looking for my RSV I found that Tuono's were generally more expensive than the RSV, would it be worth getting an RSV and putting some high clip-ons on?
PostPosted: 15:21 - 04 Mar 2009    Post subject: Reply with quote
Tuono R :
https://www.motorcyclespecs.co.za/Gallery/Aprilia%20RSV%201000%20Tuono%20R%2003%20%201.jpg
As said, gets the trick forks, shock and wheels from the mille R. A very rare beast though. The early Tuono's themselves are rather rare, the R even more so.
They are by and large reliable expect for the starter clutch if you try and start it with a slightly weak battery. The motor will kick back if the battery doesn't have enough charge, do this a few times and you need a new starter clutch.
The rear brake is notoriously bad. The only way to keep it working properly seems to be using top quality race fluid and regular bleeding.
You can upgrade the standard 12amp battery with a 14amp and it nearly solves the issue.
The clocks are more exposed on the mille and so are a little more prone to water ingress, and check all the buttons on the hideously complicated clocks work too.
Reg/rec failure isn't unheard of, but it is pretty rare.
On the R version the Ohlins seals are prove to leaking if it's left sat for a while. If you redo the seals on the R, only use Ohlins seals.
I've also recently heard reports on another forum that you can't get hold of seals for the calipers anymore, the only way to get the seals is to buy a whole caliper. I'm not sure if it's true or not, but if you're looking to but it's worth looking into that one.
I know people have toured on them, so they aren't too bad. I also know the pillion's boots can rub through the paint/take off stickers pretty easily on the tail.
HTH Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 16:07 - 04 Mar 2009    Post subject: Reply with quote
Thanks for the info so far!
Torn between getting something purely suited to touring or something a bit more fun... thing is, I don't ride /that/ much and due to work I can't do any major touring anyways so I think the Tuono would fit the bill more as a compromise.. fun and capable at touring, just probably not the cheapest bike to tour on..
Hmmm any info on miles to the tank ? from rsv or tuono owners Smile
TUG
PostPosted: 19:46 - 04 Mar 2009    Post subject: Reply with quote
What ever you fucking do dont get it from hills!!!
Haz ER-5, innit!
strag
PostPosted: 19:56 - 04 Mar 2009    Post subject: Reply with quote
I have a 2008 Tuono R (not factory, Ohlins etc) so have no experience of the older ones. I changed form a GSXR 1000 K5 and do not regret it at all. I loved the gixer but I have more 'fun' on the T. Easier in traffic, great on the twisties etc. Have had a bit of a tour on it down to Devon and it was most excellent. Obviously a bit of wind blast but nothing you can't cope with.
The tank range was about 130 to the light...before I put the Akras on, now I get about 90 to the light; that said I need to get it put to map 2 and that will improve it.
An RSVR with Renthals may not be a bad idea, it looks OK and you still retain the fairing if you are hooked on that look (there is a pic on VD in the RSVR show us yer bike thread). Personally its not for me, I love the look and feel of the T as it is.
Big grin factor all round.
carbon bling
rac3r
PostPosted: 20:48 - 04 Mar 2009    Post subject: Reply with quote
Why are tuono's so hard to find? Was there only a limited run or something. It's definitely on my 'one day I'll have one' list Laughing
Chequered Flag
Seb
PostPosted: 23:18 - 04 Mar 2009    Post subject: Reply with quote
Worth considering a Futura as well, under the skin it's the same bike as the rest of the millie/tuono/falco family, but with more weather protection and lazier power delivery. Still a very rapid bike though and imho way easier to hustle along than my SP1 that replaced it. They depreciated massively and you can pick up a tidy 03 plate with factory luggage for under 3 grand with a little hunting.
Short of a few comedy niggles (weak fuel line connector, italian wiring, underspecced battery) they are pretty bomb proof.
It's shockingly quiet for a litre twin though, factor in a set of BEF or Staintunes pipes if you want to give it back some attitude and volume.
2010 Triumph 1050 Sprint ST
tafflade
PostPosted: 23:37 - 04 Mar 2009    Post subject: Reply with quote
Touring, check. This was taken in the Alps a year ago, when we arrived I think I was in less discomfort than my mate on an RSVR.
https://i37.photobucket.com/albums/e94/taffktm/IMG_2066.jpg
https://i37.photobucket.com/albums/e94/taffktm/tuono11.jpg
Tank range is normally 120 ish to the light, I was doing 115ish a day last year and it would normally get filled up before the light came on but any detour would have the light on before the petrol station.
They are a comfortable bike, the riding position for me is absolutely spot on, reach to the bars and arse to peg distance is spot on.
Knee down is a bit of a stretch and if you are a wheely merchant then this will keep you grinning propper.
This one just happens to be for sale 'cos I cant wheely for shit so I've bought a shaftie. Mr. Green
Are you the same Sparks that was on VD and went to Tonymoto's when YoYo organised the trackdays there? If you want a look drop me a PM and we'll organise something.
Sparks!
Sir Tart-a-lot
PostPosted: 03:03 - 05 Mar 2009    Post subject: Reply with quote
Yes thats me, I seem to recognise your name from somewhere too? did you/have you got a KTM enduro and you were at tonymoto b track when I was there on my 300exc with a mate on a wr400? i think Dom was with us on a yellow tank of a drz400.
Might be thinking of someone else.
How much are you after for yours? I'm on a slightly low budget but won't be ready to buy for a few weeks at the very least (waiting on a van sale!) so don't want to mess you around. But thanks v much for the info, definetly sounds like the right bike for me Thumbs Up
tafflade
PostPosted: 08:24 - 05 Mar 2009    Post subject: Reply with quote
Yes mate, I had a 400 EXC but riding tonymoto left my knee in agony for weeks after so I basically stopped riding it, after a while I got rid of it cos it wasn't getting used Sad
anyway, my Tuono is just sitting in my shed atm waiting for the weather to get a bit warmer before I start advertising it, when I do it'll be going up for £3K.
Its bog standard with the exception on a D/b screen and clear indicators. I've owned it for 18 months, it had 4k on it when I got it.
17k miles on it now and generally in good nick, only one small scratch on the RHS tailpiece where the sidestand sunk into soft ground
the last service was the biggy, valve clearances and all fluids done at 14 something K, the tyres are shot but are going to be replaced before sale, the rear wheel bearings have just been replaced, in the time I've owned it I've had no problems with it apart from the wheel bearing, kept on an optimate it starts first time every time.
I honestly wish I could keep it but its not going to get used so there's no point it sitting there doing nothing. Sad
The last post was made 17 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 101.28 Kb
