My bike wont move wheel stuck solid - HELP please
Graprilia
PostPosted: 08:43 - 06 Mar 2009    Post subject: My bike wont move wheel stuck solid - HELP please Reply with quote
Went out this morning to find the bike wont move.
On wednesday i put it in the garage and the last 2 nights it has been -5 is it possible the water on the discs / pads has frozen sold?
If so how can i free them?
Piaggo liberty 125 SOLD - CBR 125 - SOLD Aprilia RS 125 - SOLD CBR 400 NC29 - SOLD ZX6R currently own https://bikepics.com/members/Graprilia/
PostPosted: 09:39 - 06 Mar 2009    Post subject: Re: My bike wont move wheel stuck solid - HELP please Reply with quote
If they were frozen then during the day they would thaw again.
Could be that if you put it away with wet disks, the disks have rusted slightly and binded to the pads, but that's usually only with cast iron disks instead of steel.
You haven't left your disklock on have you? Razz
Just give it a shove. Wink
lonner
PostPosted: 09:41 - 06 Mar 2009    Post subject: Re: My bike wont move wheel stuck solid - HELP please Reply with quote
hi
you could pour warm water over them but doubt there frozen Smile
i would say the salt has done the damage and a clean and service is probably needed if you can remove the caliper bolts and then move the caliper side to side on the disc using a little force you should be able to free the pads.
then give the exsposed dirty pistons a clean with brake cleaner etc Thumbs Up hth
Graprilia
PostPosted: 09:41 - 06 Mar 2009    Post subject: Reply with quote
yea the disks would have been soaked , it took two of us to free it in the end its wasnt helped by the fact i had just filled the tank up completely.
But it was the front discs that were jammed solid.
Itchy
PostPosted: 09:44 - 06 Mar 2009    Post subject: Reply with quote
Your brakes have seized , strip and rip to get them moving again, of if you are so inclined like me just ride it as normal giving it more revs.
This is risky as:
#1 it can cook off your brake fluid = no brakes
#2 warp your brake discs
#3 eat up a LOT more petrol than normal
#4 your braking ability is compromised as the discs will already be hot even on a very short ride.
Graprilia
PostPosted: 09:46 - 06 Mar 2009    Post subject: Reply with quote
i have fixed it now , the bike only just had a service week ago with new pads etc so they should be fine it was a combi or water and grit and the fact it was -5 last night didnt help.
PostPosted: 09:57 - 06 Mar 2009    Post subject: Reply with quote
Pads can seize to the disks and I have had this happen loads of times but as mentioned above normally happens with cast iron disks and certain pads.
Thing to watch for is any marks left on the disk from where the pads stuck. This can result in a load of judder on the brakes (I have a pair of barely used disks for the FZ750 that have suffered like this).
Graprilia
PostPosted: 10:02 - 06 Mar 2009    Post subject: Reply with quote
what would be the best way to clean up the discs in your opinons?
PostPosted: 10:07 - 06 Mar 2009    Post subject: Reply with quote
Difficult to say. With the FZ disks I just gave up and bought new ones (would need to get the old ones skimmed to reuse them I think).
Graprilia
PostPosted: 10:13 - 06 Mar 2009    Post subject: Reply with quote
ive heard that if you use a wire brush that it can be quite effective at cleaning them up , removing rust etc.
PostPosted: 10:17 - 06 Mar 2009    Post subject: Reply with quote
If it is just light surface rust then yes, although I would just go for a ride and let that clean up the disks.
ajb
PostPosted: 17:37 - 06 Mar 2009    Post subject: Reply with quote
my front brake was stuck like that the other day, came from with a bit of a shove though and there was a light bit of rust on the disc where the pad had been.
I thought my discs were steel tbh. Confused
CBR125R '05 > CB500 '00 > CBR600F '99
PostPosted: 18:34 - 06 Mar 2009    Post subject: Reply with quote
Standard Suzuki pads are known for rusting to the disc after being stood-up when wet so that's probably what's happened to your bike. They get a heck of a grip on the disc too and come free with a crack. Also leave a black mark on the disc where they were stuck. Once free they should work just fine. I swapped mine for EBC, then Bendix pads and never suffered the problem again.
Noxious89123
PostPosted: 19:22 - 06 Mar 2009    Post subject: Reply with quote
I've got EBC HH sintered pads and EBC discs fitted, and they will rust a little and stick to the disc overnight if put away wet.
Bit of a shove and thy come free with a crack. Short ride just wears the surface rust off, sorted. Thumbs Up
The last post was made 16 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.46 - MySQL Queries: 13 - Page Size: 87.09 Kb
