Anything to avoiud using Paraffin on?
Reppyboyo
PostPosted: 16:20 - 05 Mar 2009    Post subject: Anything to avoiud using Paraffin on? Reply with quote
Hi,
Recently been using Paraffin to help degrease the bike and was wondering if there is anything I should keep it away from?
cyberglass
PostPosted: 16:48 - 05 Mar 2009    Post subject: Reply with quote
keep it off your penis creates a warm sensation Twisted Evil
Id try to keep it away from bearing so you dont flush out the grease and you fairing and any painted finishes incase it fades or dulls them
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
veze
PostPosted: 18:35 - 05 Mar 2009    Post subject: Reply with quote
yeah i would say any bearings, e.g. wheel bearings and such like. probably try and keeb it off the forks and shock, and your chain, i would imagine it may damage it depending on what chain you have. anything that needs regular lubrication because the paraffin will thin down the lubricant.
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
Rockhopper
PostPosted: 08:36 - 06 Mar 2009    Post subject: Reply with quote
Paraffin is perfect for cleaning chains. Most chain manufacturers recommend it.
NiteMare
PostPosted: 09:44 - 06 Mar 2009    Post subject: Reply with quote
paraffin i think you'll find is an extremely thin oil (a bit like diesel) i've wiped paintwork and everything down with it in the past ...
also used it to wash engine components when rebuilding
it ain't broke...
i ain't fixed it enough
Bezzer
PostPosted: 11:17 - 06 Mar 2009    Post subject: Reply with quote
Vincent wrote:
Keep it away from anything that has rubber or soft plastic/polyurethane in it, tyres, seat, O or X ring chains. in fact, dump it and get some proper cleaner Wink Auto-Glym degreaser is a good one and, if used right, lasts ages.
If that's right why do manufacturers recommend it in their handbooks for cleaning chains then Confused . Paraffin/Kerosene is safe on chain seals, cheaper and in most cases better at chain cleaning than so called "special" degreasers.
The last post was made 17 years ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 56.98 Kb
