| Mez |
 Mez Trackday Trickster
 Posted: 23:03 - 05 Mar 2009 Post subject: Gradual reduction in top speed |
Ok, this is a really really dumb, obvious question but as one or two of you must know by now, I really don't know much about the technical/mechanical aspect of bikes.... anyway...
I bought a brand new 125 last summer, and in the initial few months I could hit 50mph fairly easily, 55mph if I pushed it, but as time has passed, this has dropped to little over 40mph.
What I'm asking is, why does this happen? And can anything be done to bump it back up again? The bike hasn't been particularly well maintained, is it a simple maintenance absence in a certain area? FYI I've just reached 1500km on the clock.
While I'm here... under front end braking, it sort of shudders to a halt... not shudders as such, but kinda start-stops. It's really not as smooth as it was.
When I took it to the garage for it's 2nd service (1st one I did myself with help) I mentioned that the brake fluid level was low as I couldn't see it at all in the little window thing. Having collected it later on and noticing the level had not changed, I asked the guy and he said it was just below the mark and that he would top it up next time I drop in.
Was he wrong? Would a top-up fix the start-stop braking?
Thanks in advance, guys.  ____________________ My deviantArt gallery - My Youtube profile
Honda CG125 -> Baotian BT49 -> AJS JS125 -> Honda CG125-> Kawasaki ZL400 -> Kawasaki GPZ500 |
| Itchy |
 Itchy Super Spammer
 Posted: 23:09 - 05 Mar 2009 Post subject: |
Has the chain been adjusted properly? in that poorly adjusted chains rob you of power. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Mez |
| Kickstart |
 Kickstart The Oracle
 Posted: 23:32 - 05 Mar 2009 Post subject: |
Reduction from ~55mph to around 40mph means a fairly hefty loss of power.
Could be simple things such as a dirty air filter, valve clearances out, etc. Could also be more severe things, such as worn piston / bore.
As to the issue with braking, that will not be down to low fluid. Lightly to be a warped disk, or possibly a contaminated disk (ie, oil in one place on it) or possibly something left on the disk (eg, a buildup on a cast iron disk where the pad has been when parked up after being out in the rain).
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 23:53 - 05 Mar 2009 Post subject: |
Yep, sounds like a warped front disk. Also if your brakes are rubbing/binding, it'll soon kill MPH!!
What sort of 125 is it??
2-strokes also lose power if the exhaust becomes coked up. What 2-stroke oil do you use and how often do you cane the bike? Does it spend much of its life pootling round town sat at lights?
If it is a sports 125 (not a scoot) then your power valve servo might be faulty ... (assuming it has a power valve) ____________________ The purpose of life is to fight maturity. |
| Mez |
 Posted: 08:45 - 06 Mar 2009 Post subject: |
| Kickstart wrote: | Hi
Keith |
| Blue_SV650S wrote: | Yep, sounds like a warped front disk. Also if your brakes are rubbing/binding, it'll soon kill MPH!! Wink
What sort of 125 is it?? |
The bike is a 4-stroke AJS JS-125. I use it for a 16-mile round trip 4 days a week. A good portion of my journey is open straight road so yes, it is ridden "aggressively" at times.
Is there any way I can diagnose a warped disk without taking it to the garage? Is it possible to tell by looking? I'm desperately low on money at the moment so determining the fault and if it's something minor fixing it myself is the best thing. If you're certain it is a warped disk, how much should I expect to pay to get it replaced?  ____________________ My deviantArt gallery - My Youtube profile
| Kickstart |
 Posted: 09:35 - 06 Mar 2009 Post subject: |
Hold the front of the bike in the air and spin the front wheel. It might be obvious. To make it a bit more obvious hold a screw driver against the fork leg with the tip just off the surface of the disk while you do this (the tiny gap makes any tiny warping of the disk more obvious). Or do it properly with a dial gauge.
However to knock that much speed off I would expect the brake would need to be dragging quite hard, and it would likely get very hot when you were riding the bike. Quite likely that would be very obvious (at least from the smell).
| Blue_SV650S |
| Mez |
 Posted: 16:17 - 06 Mar 2009 Post subject: |
Thanks for the replies guys.
Yep, that's the one.
| Blue_SV650S wrote: | if you spin the wheels in the air do they spin freely? |
| Kickstart wrote: |
Hold the front of the bike in the air and spin the front wheel. It might be obvious. To make it a bit more obvious hold a screw driver against the fork leg with the tip just off the surface of the disk while you do this (the tiny gap makes any tiny warping of the disk more obvious). Or do it properly with a dial gauge. |
I stuck it on the centrestand and spun the front wheel. I couldn't notice any deformity, BUT the wheel did not spin freely, and on the ride back from college I was very briefly aware of a scraping sort of sound, whether it was me or not I don't know.
| Kickstart wrote: | However to knock that much speed off I would expect the brake would need to be dragging quite hard, and it would likely get very hot when you were riding the bike. Quite likely that would be very obvious (at least from the smell). |
Now that you mention it, I am on occasion, perhaps 1 in 3, aware of a smell that is a bit like something melting or burning, though the smell is always in a similar area of my trip and isn't always the same one so whether it is me or something in the area I'm riding, I really can't be sure.
It seems likely that the pads are not fully opening and instead remain in light contact with the disc. Am I right to assume this, and how can it be remedied?
Thanks for all your brainstorming so far guys, much appreciated.  ____________________ My deviantArt gallery - My Youtube profile
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 16:26 - 06 Mar 2009 Post subject: |
Is there any warranty left on it? ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Mez |
| Kickstart |
| rockers |
 rockers Scooby Slapper
| Kickstart |
The last post was made 16 years, 339 days ago. Instead of replying here, would creating a new thread be more useful? |
