Anyone heard of this before??
minispacekidu...
PostPosted: 14:02 - 06 Mar 2009    Post subject: Anyone heard of this before?? Reply with quote
Hi there, been out on my cbr600 2day as it been a lovely day for it, only thing is whn i got home heard this hissing noice, and took the seat off and its cuming from the battery, and it looks like it about 2 twice the size! I cant think of wat would cause this? Any one have any ideas??? Rdiding for about 2hs would that have anythink 2 do with it?? Thks Andy
PostPosted: 14:07 - 06 Mar 2009    Post subject: Reply with quote
Blocked battery breather.
tafflade
PostPosted: 14:57 - 06 Mar 2009    Post subject: Reply with quote
if its twice the size then the battery must be hot and under pressure for the plastic to expand, there's something very wrong going on there, I would suspect that one or more of the cells have gone to pot somehow.
Battery acid is nasty stuff so I would be taking precautions incase it went pop to protect myself from an acid shower.
I would switch everything off, disconnect the neg and leave it cool down before trying to do anything else.
sickpup
Old Timer
PostPosted: 15:40 - 06 Mar 2009    Post subject: Reply with quote
sounds like the Reg/rec is blown and massively overcharging your battery.
Finglonga
PostPosted: 15:42 - 06 Mar 2009    Post subject: Reply with quote
Whatever causing it a new battery is needed and check your charging system as well or it will destroy a new one in no time.
When you remove the old one check the electrolyte level to see if you have boiled it dry or if it is a blocked breather.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 15:51 - 06 Mar 2009    Post subject: Reply with quote
You need to be very, very careful if your battery is bulging like that.
Seriously, battery acid is very nasty stuff. I'd be wearing nitrile gloves, a face shield+ goggles and oilskins with a couple of buckets of water standing by.
If it pops, it could blind or permanantly disfigure you.
The gas given off is hydrogen gas which is highly explosive so take care not to make sparks as you remove terminals too.
So, all geared up, I'd remove the cell covers to relieve the pressure first, then remove the battery and dispose of it.
Then you can start looking for the fault.
Odie
PostPosted: 17:24 - 06 Mar 2009    Post subject: Reply with quote
I agree with sickpup on this one, friend had the same on his CBR900rr kit car and it did the same to his battery.
the reg / rec was bolloxed and his battery.
You need to replace the reg / rec and the battery.
Sickpup should be able to help you out with those if you ask nicely
Odie
neatbik
PostPosted: 19:46 - 06 Mar 2009    Post subject: Reply with quote
Yep, sounds like the reg/rec.
The same thing happened on my old Honda cb1, it totally cooked my battery though and left me stranded by the roadside..
yen_powell
PostPosted: 19:49 - 06 Mar 2009    Post subject: Reply with quote
Is there a smell like rotten eggs?
I rode across Eire on my FJ12 and everytime I stopped at lights in small towns I accused my mate of farting.
He kept denying it, got quite annoyed in the end. Turned out it was my battery boiling over, regulator had gone kaput.
XT1200Z and a DR350 in bits
binge
Emo Kiddy
PostPosted: 20:52 - 06 Mar 2009    Post subject: Reply with quote
The CBR400s eat rectifiers. All the CBRs use the same rectifier though, So they are easy enough to get hold of.
Replace it with one like this. It will fit but its the proper heat sink style, Rather than the silicone filled version.
https://cgi.ebay.co.uk/REGULATOR-RECTIFIER-For-CBR-600-900-1100-VFR-750_W0QQitemZ250381140735QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item250381140735&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
I'm not saying buy it from hong-kong. Thats just an example of the type to get.
I used to carry a spare rectifier under the seat of my NC29. It used to fry them every 6 to 8 months!
Ben
hmmmnz
PostPosted: 22:31 - 06 Mar 2009    Post subject: Reply with quote
get a mosfet controlled reg, they are miles better than the usual scr solid state crappers
read this
https://eviltwinsbk.com/forumz/index.php?topic=276.msg2479#new
and all will be explained,
the humans are dead
I kick arse for the lord
Itchy
PostPosted: 22:49 - 06 Mar 2009    Post subject: Reply with quote
Or just put an alloy heatsink on the reg rec and stick a PC fan off it which will run at 12vdc nicely and keep it cool for the hottest of places.
hmmmnz
PostPosted: 22:53 - 06 Mar 2009    Post subject: Reply with quote
thats a fairly time consuming way of doing it, why not fix the problem instead of just masking it?? Very Happy
the humans are dead
Itchy
PostPosted: 22:57 - 06 Mar 2009    Post subject: Reply with quote
That is fixing the problem in that reg/recs die from not being cooled sufficiently, while your solution involves a reg/rec that doesn't generate as much heat. My solution is to cool the reg/rec some more.
And my solution if your reg/rec is working that is costs under 2 quid a new reg /rec is at least £60.
hmmmnz
PostPosted: 23:42 - 06 Mar 2009    Post subject: Reply with quote
only if you buy a new one Very Happy Thumbs Up
im not saying that a fan ect is the wrong way, ive done it myself and it is the best way to deal with them,
but you can get better reg recs that you'll never have a problem with again, surely that is worth the price
the humans are dead
Phoenix
Twisted Firestarter
PostPosted: 02:42 - 07 Mar 2009    Post subject: Reply with quote
It doesn't work either, I fitted a PC heatsink and fan to the regulator on my Fireblade when I first got it, it's since gone aswell, at 24,000miles which is about average, my last Blade one went at about 30K.
minispacekidu...
PostPosted: 06:26 - 07 Mar 2009    Post subject: Reply with quote
thks everyone! That a great help, didnt fancy it exploding on me while riding!! Wink Il let u knw hw it goes Wink
The last post was made 16 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 96.17 Kb
