Derbi Senda DRD very weak spark and will not run
Yam500
PostPosted: 20:11 - 11 Feb 2009    Post subject: Derbi Senda DRD very weak spark and will not run Reply with quote
Hi all, I have here a problem with a derbi senda drd that refuses to keep running. Some times it will start but not tick over for long, sometimes it wont start at all. It has a very weak spark, there is fuel to the plug. The carb has been stripped and cleaned. the cdi/coil unit has been changed but still it is the same. Feel that the problem is electrical, but have no idea where to start to look from here. If no idea perhaps some one might be able to recommend a good repair shop around Witham Essex who repairs derbi bikes. Thanks Mike
chillpill
PostPosted: 13:32 - 12 Feb 2009    Post subject: Reply with quote
new spark plug
Cigaro
PostPosted: 14:09 - 12 Feb 2009    Post subject: Re: Derbi Senda DRD very weak spark and will not run Reply with quote
Could be the HT lead or plug cap.
Or, as said, the plug itself.
Yam500
PostPosted: 14:14 - 12 Feb 2009    Post subject: Reply with quote
Hi,
Have fitted a new plug and new HTlead. The problem seems to be before the coil/cdi unit. I dont think it has points and condenser so not sure where to look now. Thanks for suggestions anyway. Mike
03j-sellick
PostPosted: 21:08 - 08 Mar 2009    Post subject: same problem! Reply with quote
Hi mate,
i have exactly the same problem with my senda Thumbs Down
and i've done exactly the same as you. New battery, spark plug, ht lead, plug cap and coil.
have you tried bump starting it? Mine always runs if i bump it but no idea what the problem is?
will sometimes start off the kick and then cut out shortly after.
Let me know if you find out!
Cheers, Jamie.
2005 derbi senda
BenR
PostPosted: 21:14 - 08 Mar 2009    Post subject: Reply with quote
Could be your stator/magneto may be knackered, if it's starting & runs for a bit then cuts out it sounds like it's not producing/holding its charge.
03j-sellick
PostPosted: 21:20 - 08 Mar 2009    Post subject: hmm.. Reply with quote
i have receipts of the previous owner changing the stator shortly before i bought it (around 3 months ago). Thought it could be the tick over or float bowl stuck down but ticks over and runs really well once its been bumped. Think it could be something to do with fuel? It only starts on the kick after being left for a while then cuts out. When bumping it, you have to keep running for a bit with the clutch fully out! runs on a vacuum pump? Cheers.
2005 derbi senda
There is a gap of 264 days between these two posts...
adiii
PostPosted: 20:51 - 28 Nov 2009    Post subject: gilera smt 50 2004 wont start after engine rebuild Reply with quote
hi i have just rebuilt the engine in my gilera smt 50 2004 its the old type derbi engine, reason for rebuild was that the top end seized because the 2 stroke pipe was pulled of i have put new main bearings and seals in the engine and a new race crank and a new 70cc top end but it wont start it has spark and i think it has fuel butim not sure so i put some ful down the spark plug hole n it didnt fire so is it a really weak spark ? because it sparks when i put it on the cylinder head ? im not sure can some one please help as i need the bike to get me from home to school and school to work.
also the kick start fell out when i split the engine i just need to no what position to put it back in ?its kicks it over and releases but doesnt go all the way back some times ?
quick reply pleaseeee.
ashwell-09
PostPosted: 15:00 - 30 Nov 2009    Post subject: Reply with quote
My motorhispania had a problem like this, does it run for a while whilst you're riding it and then just die?
Mine would do that, i used to just take the spark plug out and close the gap a tiny bit, it would sometimes run fine after that, other times it would just die out again.
Its the time of year i think, 50's don't like cold weather. Just try and warm it up before setting off.
Riding as fast as you can sounds like a good speed to me
1988 Yamaha DT 50 > 2004 Motorhispania RYZ 50 > 1988 Honda CBR 400
ashwell-09
PostPosted: 15:04 - 30 Nov 2009    Post subject: Reply with quote
Make sure you're using good quality oil like morris. Also fuel, theres a petrol station near me that my bike really didnt like.
There is a gap of 6 years, 351 days between these two posts...
MOTOEXPERT This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
The last post was made 9 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 67.14 Kb
