Project CG
TimNorwich
PostPosted: 10:37 - 10 Mar 2009    Post subject: Project CG Reply with quote
Ok well got hold of the CG125 yesterday, 2005, 7K miles, £100. 1 owner from new and a full service history :thumbup: The guy had a car pull out on him and the front end is well and truely screwed.
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1423.jpg
I know it will need the following:
New forks (and maybe yokes)
New front wheel
New exhaust
Headlight
Bit of a paint touch up here and there
MOT + Tax
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1425.jpg
I thought once the front wheel is off the weight of the rear would keep the front held up, however this is not the case, so I bungeed the bike and put a plant pot on the seat, makes it look better too! Clapping
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1430.jpg
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1433.jpg
In the following picture is the bit on the bottom yoke where there is a little pin to stop the handlebars turning all the way left, however this was sheered off in the accident, causing the forks to make a dent in the tank Eh? . So if anybody knows if this problem has to be resolved before it will pass an MOT feel free to tell me Razz .
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1435.jpg
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1437.jpg
And here we have a couple of pictures of the bent wheel, was hoping it would be able to be "trued" out and straightened but thats unlikely having a closer look at it.
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1438.jpg
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Cg125/101_1439.jpg
Thanks for looking!
I would also appreciate any help on the matter of buying new forks, what year CG's forks will fit the 2005?
Will keep you posted.
PostPosted: 11:27 - 10 Mar 2009    Post subject: Reply with quote
Yes you will have to repair the lockstop before you get the bike M.O.Ted.
£100 seems like a bloody good price.
OssY
PostPosted: 12:31 - 10 Mar 2009    Post subject: Reply with quote
I am loving the plant pot mod in the third pic down. Wink
Mudskipper
PostPosted: 13:12 - 10 Mar 2009    Post subject: Reply with quote
I'll give you £110 for it. Thumbs Up Wink
TimNorwich
PostPosted: 13:30 - 10 Mar 2009    Post subject: Reply with quote
Having a bit of trouble getting it fired up, it has stood for a couple of years...
Got the carb out and cleaned it all properly.
The petrol tank had been emptied before it was stored.
What else can I try to get it going?
Mudskipper
PostPosted: 13:50 - 10 Mar 2009    Post subject: Reply with quote
I'd try spark plug and battery next. What's it like when trying to start? Does it turn over ok?
Tavares
PostPosted: 13:52 - 10 Mar 2009    Post subject: Reply with quote
seconded, the battery can't be up to alot after sitting for 2 years.
2006 Eurostrada RX8 125(sold)>2004 Kawasaki ER-5(sold)>2002 Honda CB600F Hornet
TUG
PostPosted: 14:50 - 10 Mar 2009    Post subject: Reply with quote
Oooo you have the gay one with no kick start, yep you'll need a new battery and i'd bung a new spark plug in to. Was it sat for 2 years with no petrol in? I hope so or the tap will be gummed up too an you might want to swill out the tank.
Haz ER-5, innit!
TimNorwich
PostPosted: 17:28 - 10 Mar 2009    Post subject: Reply with quote
It was emptied of petrol yes, I had charged the battery, got it running for around 30seconds. Not had the spark plug out yet but will do that next.
TimNorwich
PostPosted: 18:11 - 10 Mar 2009    Post subject: Reply with quote
More progress:
Managed to get the forks off, undid one of the forks completely, to have a bolt fling out of the top from the spring lol. Also got the exhaust off, and the foot rest bit as one side was bent.
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Picture008.jpg
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Picture007.jpg
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Picture004.jpg
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Picture005.jpg
Bits I dont need:
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Picture009.jpg
Bits I do need:
https://i206.photobucket.com/albums/bb106/timmyboynorwich/Picture006.jpg
Thanks
PostPosted: 18:43 - 10 Mar 2009    Post subject: Reply with quote
Are you not going to keep the fork bottoms or are they damaged too?
a person
PostPosted: 19:34 - 10 Mar 2009    Post subject: Reply with quote
that hub looks ok it the pic ,just get a new rim, spokes and nipples if you can build a wheel (or this is a perfect time to learn)
but if you cant and dont know anyone who can it might work out cheaper to buy a new wheel
alun111
PostPosted: 20:46 - 10 Mar 2009    Post subject: Reply with quote
I was thinking that myself.
I'd also be taking the tyre, and the headlight glass lense if it's salvageable.
Have you checked the headstock of the frame for signs of damage?
Thom
PostPosted: 21:20 - 10 Mar 2009    Post subject: Reply with quote
To repair a damaged lock stop:
File down the remains of the damaged stop until flsuh with the yoke.
Drill a hole to take an M10 or M12 bolt.
Tap said hole to take said bolt.
Screw on a nut (Or two) to the bolt all the way to the head.
Screw bolt into yoke.
If the bolt sits too low and doesnt stop at the lock stop, raise the height of the bolt by backing the bolt out of the hole and using the nut(s) to lock the bolt against the yoke.
jack_zxr400
PostPosted: 21:30 - 10 Mar 2009    Post subject: Reply with quote
damn were do people find all these things for like no money :[
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
TimNorwich
PostPosted: 21:47 - 10 Mar 2009    Post subject: Reply with quote
They are a bit scuffed at the top near the seals, but alot of the forks on ebay come with the fork bottoms.
The headstock bearings are screwed, they stop at 5cm intervals when you are turning the forks.
With regards to the headlight lense, i'll probably just be buying a universal headlight that will go on.
This was through a friend, I very much doubt I would of found something like this in a paper. The guy wrote it off a year-2years ago, and i've known him since he's had the bike, he just never got round to selling it... So by the time i'd asked him he was happy to see the back of it!
PostPosted: 21:52 - 10 Mar 2009    Post subject: Reply with quote
He didn't mean check the headstock bearings, he meant check the headstock for signs of cracking or bends.
You do know you could save the headlight lens and fork bottoms and sell them on Confused
TimNorwich
PostPosted: 22:28 - 10 Mar 2009    Post subject: Reply with quote
All looks well, just the lock stop seems damaged.
alun111
PostPosted: 22:53 - 10 Mar 2009    Post subject: Reply with quote
great minds think alike Thumbs Up
TimNorwich
PostPosted: 21:13 - 15 Mar 2009    Post subject: Reply with quote
The fork bottoms are scuffed, right near the seal too! Also the headlight lense is chipped, so not really sure why anybody would buy these items. Sad
The headstock area looks good all bar the lock stop, however this will soon be resolved as i just won a pair of forks and yokes on egay off a '500mile bike', £103 posted. Will update when i fit them.
So now really what I need to get in order of importance
Wheel
Exhaust
Mudgard
Headlight
Then its all dandy!
The last post was made 17 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 112.33 Kb
