Building a bike from frame
Mudskipper
PostPosted: 16:12 - 11 Mar 2009    Post subject: Building a bike from frame Reply with quote
I've decided I want to do a long term (2-3+ years) project and build a hybrid, unique bike, on a budget, starting from a frame & V5 upwards.
I can't afford the outlay for a project bike or rolling chassis, so decided it would be much more rewarding and challenging to start with a frame and buy parts bit by bit as the bargains turn up, like no-bid collection only bits off ebay, salvage yards/autojumbles etc. Modifying and possibly even making bits as needed.
I also don't have a garage/shed or similar covered space to store/work in.
So, I'm trying to do a bit of a project plan and hoping the good people on BCF will help me out with a few initial ideas and suggestions.
Firstly, I've not entirely nailed down what I want from this bike yet. Rally/show bike? On/off roader? Touring bike?
I do know that I want it to be a hybrid, so in choosing a frame I'm looking for something that is fairly compatible with a decent range of common bikes to give me plenty of choice. I guess I'm looking for a reasonably light frame because of my height/build.
Don't think anything 2T would fit what I'm wanting, nor overly complicated/odd engine setups.
Anyone done anything similar before? What route did you go down, anything you'd recommend? Things you'd do differently/avoid? Problems encountered?
I'm wanting to keep costs to a minimum but do things properly and hopefully end up with a nice looking bike that is uniquely mine, not a seller.
I'm just throwing thoughts and ideas around my own head right now, so any input would be gratefully received.
Possible parameters at the moment:
Fairly light
Not too tall
Probably 500cc+
Accessible to work on (no spark plugs/oil filters hidden behind the frame, weird swingarm setups etc)
Decent handling
Availablity of consumables
I've avoided specifying things like good mpg, reliable etc, cause that's wanting the moon on a stick, and tbh they won't be that important for this!
What yas reckon? Mr. Green
Itchy
PostPosted: 16:22 - 11 Mar 2009    Post subject: Reply with quote
I'd probably say get something which has a basic box section frame sort of like a Hornet in that there is plenty of space under the frame to hang whatever engine you like in it, while sports bike twin spar frames and trelis frames based around the same designs but done with tubes have the same problem.
I think a bandit frame is a good candidate as although its got a frame all the way around the engine the old GSX lump that occupies the middle of it is pretty huge and thus will probably (maybe) fit anything you should choose to put into the frame.
Also I wouldn't buy just a frame the frame might be cheap , but there are 100s if not 1000s of little washers bits of rubber here and there that cost 50p ~ £ 1 each , and bump the costs up considerably. This is when even though I think about doing it I end up buying complete bikes to save on costs.
neatbik
PostPosted: 16:26 - 11 Mar 2009    Post subject: Reply with quote
Ive thought about doing something like this, im busy cracking on with my cg bobber project at the mo so it'll be a fair while i reckon.
Im thinking about building a frame myself, that way i can design it so everything fits.
Obviously thats a lot of work though.
Itchy
PostPosted: 16:28 - 11 Mar 2009    Post subject: Reply with quote
Oh and btw join 100% biker forum there usually averages about 2 frames given away a month for the 7 months I've been on that forum.
Oh the Fazer 1000 frame looks promising too.
NSR Mick
PostPosted: 17:14 - 11 Mar 2009    Post subject: Reply with quote
Choosing any Yamaha FZ/FZR/thunderace 750 / 1000 frame instantly gives you the choice of all the engines that share the same or very similar cases as they all pretty much bolt in.
That lets you use anything from an FZ750 right through to a Thunderace with very little or no modification.
Kal
PostPosted: 17:45 - 11 Mar 2009    Post subject: Reply with quote
Army tent in the garden as a workshop. Planning permision is not required for temporary structures.
Trying to do any sort of long term work without a covered workspace just means you will spend twice as long on it cleaning away your tools every time a rain cloud goes over.
Having a garage has made all the difference in the world to me.*
* It now dosn't matter when I am a lazy fuck and do anything for ages
Kal...
Barry_M2
PostPosted: 17:49 - 11 Mar 2009    Post subject: Reply with quote
As mentioned above, go for something like FZR/FZ, or even CBR6. Parts are plenty available and cheap.
I gave away a ZXR750 chassis a couple of years ago. Just charged the guy a fiver for delivery.
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
PostPosted: 18:11 - 11 Mar 2009    Post subject: Reply with quote
Mudskipper.
At the weekend I am buying a 350 powervalve that I am going to strip for spares. I would be happy to sell you a frame and engine, maybe a tank and stuff as well. I don't think I'd want a lot of money for it and I think I may need the space once it is stripped. The bike doesn't run and had a top end seizure, but the rest of it is OK.
It won't be ready immediately as I need to strip it and decide what parts I want and what parts I don't want, but apparently I'm getting a spare bottom end with it as well as a few other odds and sods.
If you're interested then let me know. A 350 powervalve is a good reliable two stroke. Comfy with a good range and a fun power delivery. The main advantage that I can see however is that it is total childs play to work on. The engine has easy access and can be almost entirely rebuilt without removing it from the frame. Removing it from the frame is supposed to be about an hours work anyway.
Hybrid RD350's are quite a popular build and so there is loads of info out there on how to bodge on different forks, swingarm, wheels etc (which are mainly the bits I need - but I also need the seat, bodywork and tank.) There are loads of spares available on ebay etc, so replacement barrels and heads should be available.
As I said, PM Me if you're interested.
b-f-c
PostPosted: 20:34 - 11 Mar 2009    Post subject: Reply with quote
Got most of a Z400/4 if you're interested - all engine, electrics etc and most of the running gear Smile
Mudskipper
PostPosted: 22:04 - 11 Mar 2009    Post subject: Reply with quote
Thanks for all the input Thumbs Up Smile
Marjay, fjrat - both very good (and EXTREMELY tempting) offers but I need to be realistic in my budget. I don't even have 100 quid spare at the moment. Plus I should really limit my collection distance. Sad
But definite food for thought.
Kal, great suggestion. Thumbs Up As soon as my landlords clear the fridge, sofa, bed, bits of garage, two wheelbarrows full of solid concrete and various other shite (none of which is mine) from my garden, I may just do that.
Itchy, you make a good point about the little bits n bobs that all add up, I might need to save up and at least get a rolling chassis.
I shall continue to plot and plan... Mr. Green Thanks again all
PostPosted: 22:08 - 11 Mar 2009    Post subject: Reply with quote
Fireblade 900 frame?
Or a Harris Magnum frame. Drooling
Mudskipper
PostPosted: 22:14 - 11 Mar 2009    Post subject: Reply with quote
Mudskipper wrote:
... on a budget,...
Mudskipper
PostPosted: 22:21 - 11 Mar 2009    Post subject: Reply with quote
BLUEX5 wrote:
Sound a right load of fannying about TBH.
Although that's coming from someone who had a hissy fit earlier because the GSXR needed it's seat lock and cable lubricating Laughing
Oh I still have shitloads to do on the slabby. But this is longterm, and fannying is therefore a requirement.
PostPosted: 22:26 - 11 Mar 2009    Post subject: Reply with quote
Why not drag the slabby?
Stretch it and fit a turbo. Cool
Ichy
PostPosted: 22:42 - 11 Mar 2009    Post subject: Reply with quote
If I was going cheap I'd probably start with a early '80s GS. Very basic frame layout making it suitable for loads of engines, millions of spares, and stupidly cheap even as a complete running bikes. Guess I'm biased but I think the same could be said for the old GSXF except the frame is hard to modify and it weighs a ton. Still, I've brought two running engines with starter, alternator etc for less than a tenner.
wizzzard
PostPosted: 02:26 - 12 Mar 2009    Post subject: Reply with quote
A great idea and one that would be very interesting to follow if it graced the hallowed pages of show and tell.
I have no advice to offer on the subject sadly, but if you manage to find a frame and need some transport i can always make sure the vans available for the day.
hmmmnz
PostPosted: 07:07 - 12 Mar 2009    Post subject: Reply with quote
i would go with any old oil cooled suzuki frame either the gs or gsxr series bikes, gs if you want a nice simple easy to mod steel frame or gsxr if you want a lighter alloy frame Very Happy
the humans are dead
I kick arse for the lord
Kal
PostPosted: 10:47 - 12 Mar 2009    Post subject: Reply with quote
I have sledgehammers, axes and large crowbars...
...could be a good weekend! Twisted Evil
Kal...
stevo as b4
PostPosted: 12:40 - 12 Mar 2009    Post subject: Reply with quote
It still might be worth looking into how much frame kits are for popular special's that have readily available access to compatible parts from a number of suitable bikes.
I'd personally budget allowing rarther start with a specific but basic frame kit that use's alot of parts from a suitable doner bike usually all from one manufactuer. This would allow you to just buy little bits at a time, and what you would save in time and searching for suitable or compatible parts would be time you could spend working on it. The cost of having stuff engineered, machined and welded to make suitable parts and to get random stuff to fit is probably just as much overall or more than getting a frame kit where all the hard work has been done, and all you need is a suitable donor bike/parts, assembly, paintjob, and finishing touches to complete.
Being realistic this is the only way id ever get such a project finished, as id just run out of time, money or patience with a full one off totally custom build, and i don't have the skills or resources to take one such a job really.
Things like a Rickman, Harris, Norman Hyde frame kit would appeal to me, as you could buy the most basic frame kit and slowly build up a bike, knowing what parts from which bikes you need to find, and knowing that things will fit or otherwise just need slight modifications and no major hassle or expense. It would be very similar to building up a kit car i would imagine, but bike parts are easier to work with and take less work to recondition than say a car engine and transmission etc.
The idea of buying something like an FZ600 frame and trying to get an XJR1300 engine fitted into it sounds like fun, but if i did ever manage something like that, the end result would almost definately be not particulary good to ride, un-reliable, and just a bastardized load of crap, compared to a bike that is properly designed and built to work well and be actually decent to ride at the end.
PostPosted: 13:02 - 12 Mar 2009    Post subject: Re: Building a bike from frame Reply with quote
Mudskipper wrote:
Fairly light
Not too tall
Probably 500cc+
Decent handling
To be honest I think you are going to struggle. Accessibility is one of the things most likely to be lost with any kind of special.
Handling is going to be an issue, as anything you do is likely to screw up weight distribution and a good chance any suspension you use will need a fair amount of playing.
I would say to start off with a fairly simple steel cradle frame, from a bike with a fairly large engine (makes fitting anything else in rather easier). And steel can be easily welded for engine mounts, etc. Maybe the Bandit or early Fazer frames suggested earlier.
Engines from a common family can sometimes be a doddle to fit. It should be a doddle to fit an FZR1000 engine into an old FZ750 frame (and being steel it would be easy to chop around the subframe to suit), while fitting a GSXR1100 engine into the same frame would be a complete nightmare (is is difficult enough to fit an oil cooled GSXR11 engine into the frame for a water cooled GSXR11).
Whatever you fit you will need to get the sprockets to line up.
Clocks will likely to be fun if the engine and frame are from 2 different makes. Chances are if you used one set of doner clocks you would land up with a speedo working accuratly or a rev counter working accuratly, but not both.
NSR Mick
PostPosted: 15:03 - 12 Mar 2009    Post subject: Re: Building a bike from frame Reply with quote
They bolt in with zero modification, and from memory so do the forks and swingarm. Thumbs Up
PostPosted: 15:27 - 12 Mar 2009    Post subject: Re: Building a bike from frame Reply with quote
Think it depends on the model. The early FZ750 had rather different rear suspension, and also very different ignition system. You will likely also have issues with the airbox fitting under the tank (and again early and late FZ750s had different shaped airboxes to fit under the tank) and the FZ series seem to be pigs to set up without an airbox.
Mudskipper
PostPosted: 23:05 - 12 Mar 2009    Post subject: Reply with quote
Thumbs Up Laughing
Don't think dragging is the right plan for my main commuter/touring bike.
NSR Mick
PostPosted: 23:13 - 12 Mar 2009    Post subject: Re: Building a bike from frame Reply with quote
When I did it I ran it without the airbox and yes it ran like a bag of spanners low down and in the mid-range.
I used the entire 1000 loom and electrics too.
It wasnt an intended project, I was half way through my never to be finished FZR1000 project and my mate had an FZ with a duff engine and we wanted a bike to take to the IOM so in a week bolted what worked on the FZR onto the FZ and suprisingly it all worked.
I cant remember what year the FZ was but the FZR was a 91 RU.
The last post was made 17 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 143.65 Kb
