Wheel/Chain turning in neutral ?
Makaveli_Rydah
PostPosted: 13:15 - 12 Mar 2009    Post subject: Wheel/Chain turning in neutral ? Reply with quote
As per the title - the idle is fine at 1K , i've tried adjusting it down and it makes no difference .
Anyone know what the cause is ?
Bike History:- Vision / Phantom 100 / Aerox 100 / Runner VX125 / Honda VFR400 NC24 / Kwak ZX9R B3 / Honda CBR600 F / ZZR400 & K2 GSXR 750 / Suzuki VZ800
SlimRick
PostPosted: 13:22 - 12 Mar 2009    Post subject: Reply with quote
Is this with the bike on the ground, or on the centre stand?
Makaveli_Rydah
PostPosted: 13:23 - 12 Mar 2009    Post subject: Reply with quote
centre stand mate
not very quickly - maybe 2 revolutions every 10 seconds
Bikeless
PostPosted: 13:26 - 12 Mar 2009    Post subject: Reply with quote
It's normal.
Finglonga
PostPosted: 13:48 - 12 Mar 2009    Post subject: Re: Wheel/Chain turning in neutral ? Reply with quote
Oil between the friction plates causing drag, nothing to worry about.
Andy Sez....
F.Y.Y.F.F.
reckless_b
PostPosted: 17:00 - 12 Mar 2009    Post subject: Reply with quote
I was very suprised yesterday when I started my 900 trophy after its winter lay up and the back wheel didn't spin when idling on the stand
40 years on the road on and sometimes off bikes with a very recent OFF
Makaveli_Rydah
PostPosted: 17:54 - 12 Mar 2009    Post subject: Reply with quote
Good to know - cheers lads Thumbs Up
Incidentally i've tightened the chain up and it's slowed down considerably Confused
el_oso
PostPosted: 18:11 - 12 Mar 2009    Post subject: Reply with quote
make sure you haven't over tightened the chain though. An over tight chain causes resistance in the other direction causing unnecessary wear on the chain and sprockets.
Makaveli_Rydah
PostPosted: 00:33 - 13 Mar 2009    Post subject: Reply with quote
I've left about a half inch of play in it Thumbs Up
PostPosted: 00:44 - 13 Mar 2009    Post subject: Reply with quote
Rare for chain slack to be meant to be less than an inch at the tightest point.
Finglonga
PostPosted: 13:53 - 13 Mar 2009    Post subject: Reply with quote
What does it say in the handbook(or chain guard) it should be?
Andy Sez....
F.Y.Y.F.F.
Cigaro
PostPosted: 13:55 - 13 Mar 2009    Post subject: Reply with quote
Agree with all the above, it's perfectly normal.
arry
PostPosted: 14:10 - 13 Mar 2009    Post subject: Reply with quote
More resistance
Vin
PostPosted: 10:16 - 14 Mar 2009    Post subject: Reply with quote
Rear brake needs attention then Laughing Karma
PostPosted: 10:28 - 14 Mar 2009    Post subject: Re: Wheel/Chain turning in neutral ? Reply with quote
Just a note that it shouldn't be this as in neutral the clutch will be fully engaged Smile.
However, the same thing with the gears, I would presume.
Walloper
PostPosted: 11:37 - 14 Mar 2009    Post subject: Reply with quote
Once things have warmed up this effect should reduce as oil viscosity changes with warm oil.
Nothing to worry about but must be kept in mind if working on the bike and some bellend starts the beast without warning when your handy-pops are entwined in the back end... Embarassed
Take the key out...
Or if you want to be pedant disconnect the battery.... Sad
Ichy
PostPosted: 11:47 - 14 Mar 2009    Post subject: Reply with quote
Did you check the free play with the bike off the stand?
The last post was made 17 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.45 - MySQL Queries: 15 - Page Size: 91.7 Kb
