Tyre pressures
Matthie
PostPosted: 23:42 - 12 Mar 2009    Post subject: Tyre pressures Reply with quote
Did a search but didn't find anything really specific or helpfull.
What tyre pressures do you run on the front/rear for road riding and for what bike?
Just wondering what pressure I should set the SV tyres to so I get the most out of them.
Paulington
PostPosted: 23:46 - 12 Mar 2009    Post subject: Reply with quote
This place says:
36psi front
40psi rear.
However, I'd still look around and see if your tyre manufacturer reccommends anything. Thumbs Up
Mr.Everready
PostPosted: 23:57 - 12 Mar 2009    Post subject: Reply with quote
36/42 for my 03 ZX6R, generally the same for most 600's.
Obviously different people prefer slightly pressures but 36/42 is the recommended spec.
Dezeaz
PostPosted: 00:02 - 13 Mar 2009    Post subject: Reply with quote
36/42 cbr f sport 2002
Method
PostPosted: 01:17 - 13 Mar 2009    Post subject: Reply with quote
36 42 on my old SV
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Marcg868
PostPosted: 01:18 - 13 Mar 2009    Post subject: Reply with quote
36/42 on my Hyo, Very Happy
JACK, MISS YOU LOADS YOU LEGEND.
Wozza
PostPosted: 01:29 - 13 Mar 2009    Post subject: Reply with quote
33/33
doggone
PostPosted: 08:15 - 13 Mar 2009    Post subject: Reply with quote
If you can't remember, any bike 35ish will do front and rear.
It does make a difference to handling getting them just right,
It's not that easy though since owners handbook will say one thing but you might have different tyres on.
kawashima
PostPosted: 08:29 - 13 Mar 2009    Post subject: Reply with quote
28/32 (W650)
own:2020 Serow 250
S1KE
PostPosted: 08:34 - 13 Mar 2009    Post subject: Reply with quote
is that a b1h, mine needs some air too Thumbs Up
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
PostPosted: 08:48 - 13 Mar 2009    Post subject: Reply with quote
B1H is 36 front 42 rear. Thumbs Up
sagalout
PostPosted: 09:07 - 13 Mar 2009    Post subject: Reply with quote
42/42 on the zx12r.
It's very sensitive to them as well
Current Bike: Triumph Speed Triple T309
Previous: CBR600F => ZX9R => Triumph Tiger => Honda Blackbird => GSXR 750 => Versys =>ZX12R
Method
PostPosted: 10:07 - 13 Mar 2009    Post subject: Reply with quote
Car: If in doubt - 32 all round.
Bike: If in doubt 38 all round.
Nice safe numbers that will do you happily until you can find out for sure Thumbs Up
neil.
PostPosted: 10:48 - 13 Mar 2009    Post subject: Reply with quote
25 front, 29 or 41 rear (depending on weight) on my YBR.
metalangel
PostPosted: 15:48 - 13 Mar 2009    Post subject: Reply with quote
If the sticker's worn off your swingarm, I'm pretty sure it's 33/36 on the SV. Can't say for sure as I don't have it here with me.
Generally anything around that is good if you're unsure.
PostPosted: 16:03 - 13 Mar 2009    Post subject: Reply with quote
Hi, my bike CB250RS
Front 24psi
Rear 32psi
with pillion
Front 24psi
Rear 36psi
Pat
Don't guestimate it Matthie
m0l0t0v
I usually go for what it says on the tyre Thumbs Up Wink
D O G
PostPosted: 16:17 - 13 Mar 2009    Post subject: Reply with quote
40+ seems like a lot to me.
The SRAD was 36's allround, which I what I go for.
Best bet is to find the manual for the BIKE, ignore what the tyre says, that is simply its operational limits, and can never be the correct pressure for your bike.
m0l0t0v
PostPosted: 16:27 - 13 Mar 2009    Post subject: Reply with quote
TBH, every time I've used the writing on the sidewall it's always been what the owners book says... Confused <shrug>
PostPosted: 16:52 - 13 Mar 2009    Post subject: Reply with quote
Well you've struck lucky then..
As mentioned in loadsa previous posts, use the pressure recommended by the bike maker, even searching on tyre company sites you will find the same advice.
Glad i don't use the psi mentioned on my tyre Surprised
Again as already mentioned, check them cold and check them as often as you can.
Pat
chillpill
PostPosted: 16:59 - 13 Mar 2009    Post subject: Reply with quote
28psi front and 30psi back is what it says in my nsrs manual , i used the manual pressures instead of the pressures written on the tyres , i just thought honda would know how the bikes ment to handle
PostPosted: 17:57 - 13 Mar 2009    Post subject: Reply with quote
NEVER use the pressures on the sidewall as your tyre inflation settings. They are the tested maximum safe inflation pressure for the tyre NOT the working pressure as used on the road. The figures you need are available from the tyre manufacturer and vary with the bike model and tyre model too.
If you use the standard fitment tyre on your bike you can use the pressures on the sticker or in the manual. If not, check out the tyre manufacturer's website for reccomended settings.
neatbik
PostPosted: 18:17 - 13 Mar 2009    Post subject: Reply with quote
I run 33/38 which is recomended by Triumph and Bridgestone Thumbs Up
Acemastr
PostPosted: 18:54 - 13 Mar 2009    Post subject: Reply with quote
26/28 YBR Smile
2016 Toyota Tacoma Limited
chillpill
PostPosted: 20:04 - 13 Mar 2009    Post subject: Reply with quote
this thread inspired me to check my pressures , rear was bang on , front , 0 psi Shocked new tyre time
The last post was made 17 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 130.31 Kb
