Irregular tyre wear.
ajb
PostPosted: 14:08 - 13 Mar 2009    Post subject: Irregular tyre wear. Reply with quote
My front tyre has an irregular tyre wear pattern, as in the tread nearer the centre of the tyre 'steps' down across the ridge, so the circumference of the tyre is not perfectly rounded, was just wandering what the cause(s) of this could be?
I am getting a new set in a couple of week anyway, mainly interested if anything else on the bike can cause this.
Thanks.
EDIT- paint diagram added
CBR125R '05 > CB500 '00 > CBR600F '99
PostPosted: 14:14 - 13 Mar 2009    Post subject: Reply with quote
Feathering of the tread is often a sign of the tyre being underinflated, or that you are simply pushing it hard.
ajb
PostPosted: 14:17 - 13 Mar 2009    Post subject: Reply with quote
This is interesting.
When I got the bike the tyre has that blistering type effect on the outter edge like it's been on a track. Also I pumped the tyre up from 36 to 38 PSI (as on the sticker on the swingarm).
Thanks Thumbs Up
PostPosted: 14:41 - 13 Mar 2009    Post subject: Reply with quote
I should add that mine do this too because I preferr them a little under the recommended pressure. They just wear out a bit more quickly is all.
ajb
PostPosted: 17:13 - 13 Mar 2009    Post subject: Reply with quote
any idea on effects to handling? I would have thought it would be detrimental.
PostPosted: 20:01 - 13 Mar 2009    Post subject: Reply with quote
No effect I have noticed until they get very worn, when you ought to have been replacing them anyway.
Kris
PostPosted: 20:21 - 13 Mar 2009    Post subject: Reply with quote
As Stinkwheel says, signs of a front being pushed a bit. Typically found on large tourers and heavier bikes. (Though the Bandit does it a bit too..)
As long as the tyres are within a few psi of recommended I wouldn't worry.
www.prisonplanet.com
The last post was made 17 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 52.96 Kb
